GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-26-2006, 09:20 | #1 (permalink) |
Junior Member Join Date: Jun 2006
Member: 292708 Status: Offline Thanks Meter: 0 | running more then one operator similtaneously We can put more then one operator inf. into one sim card but, at one time we can use just one of them. it is just a switching mechanizm. but; why we can't run more then one operator similtaneously that's infromation are loacated a sim card already could we do it ? thnaks .......... |
07-27-2006, 14:29 | #3 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 3941 Status: Offline Thanks Meter: 636 | yes it's hardware limitation.. phone can't connect to 2 networks at same time.. maybe there is a possibility now with phones which are ready for other technique's like a gsm + 3G phone or gsm + IP calling (skype a like) |
07-27-2006, 14:52 | #4 (permalink) |
Member: 292708 Status: Offline Thanks Meter: 0 | of course if hardware does this, we don't need to think about it infact (that is just my idea) it don't be to hard. if we can show (it can be a phantom entity ) GSM phone as alive (at one time similtaneously more then one operetor) , it'll be enought for us. So if we can control comminication between mobile station (GSM phone) and BTS (opertator's base station) , thats means we can do it (perhaps it could be some hard ). now, we must think how to proggram (to control comm. channel) this channel with java or C. does anyone have a idea abut this issue. thanks .............. |
07-31-2006, 06:46 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | not possible (in GSM for sure) simply because the time slots and time frames set up. every few micro seconds, phone is making communication with network in "time slot". 8 time slot make one frame, so many frame make one super frame then on to hyper frame. if phone was to try and operate on two networks at one time, it would be missing packets in one or both frames. with too many packets lost, it is kicked from network. i think you will be kicked from network in a 477uS |
08-03-2006, 18:49 | #6 (permalink) |
Junior Member Join Date: Aug 2006 Location: india
Member: 323176 Status: Offline Thanks Meter: 0 | ya what u told was write.but i have a confution that is "is all phones recive station command for every 477us?" how would u say that it is exactly 477uS it is common for all stations |
08-25-2006, 22:09 | #7 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | one time slot in GSM900 system is set as 477uS. that is same for every mobile station, base transeiver station, every network, every country, anywhere in the world. it is set in GSM900 specification, and enforced in the handset by crystal oscillators which are controlled by phase control commands tx/rx on the home broadcast channel. if someone is not working 477uS per frame, they are not on the network |
solution for camera K770 "Another application is running.Close, then start the camera | khassene01 | Sony Ericsson Hardware Repair | 4 | 05-20-2010 02:32 |
More then one serial port on Widcomm BT drivers | gsmBTjoco | Bluetooth-Software | 0 | 04-14-2006 09:32 |
SL65 and CX65 dead fo no reason-flashed-then didnt connect more then 25% | crossings | SIEM Service Tools | 2 | 12-03-2005 22:54 |
Why i cant put New Topic in sales Section more then 2 Weeks? | Gsm Experts | Board, Server and Login Problems/Support | 5 | 03-27-2003 11:16 |
