-   GSM Programming & Reverse Engineering (http://forum.gsmhosting.com/vbb/f83/)
-   -   samsung (http://forum.gsmhosting.com/vbb/f83/samsung-2605384/)
millerman10 05-13-2019 22:22
samsung
hello pls how can one be able to identify the correct samsung flash file
eyestrain 05-14-2019 16:18
in .Net:
Dim com1 As SerialPort = New System.IO.Ports.SerialPort
com1.PortName = "COM6"
com1.Open()
If com1.IsOpen Then
com1.Write("AT+SWVER")
Dim result As String
result = com1.ReadExisting
MsgBox(result)
Else
MsgBox("use search button because com port not open")
End If
I hope I answer your question correctly, and I also hope you are in the right section.
temporary1221 05-17-2019 04:01
For delphi
var
iPos : integer;
result , str : string;
begin
ComPort1.Port:='\\.\' + MODEMPORT;
ComPort1.CustomBaudRate:=115200;
if ComPort1.Connected then ComPort1.Close;
ComPort1.Open;
begin
WritePortString('41 54 2B 43 47 4D 52 0D 0A');
Application.ProcessMessages;
sleep(100);
form1.ComPort1.ReadStr(result, 200);
result:= strtohex(result);
iPos := Pos ('0D0A', result);
if (iPos > 0) then
begin
SW := hextostr(Copy(result, iPos + 4, length(result)-20));
sMemo1.Lines.Add('Firmware Version : ' + SW);
end;
Page generated in 0.14474 seconds with 5 queries
