Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-13-2019, 22:22   #1 (permalink)
Member: 2722459
Sonork: family
samsung
hello pls how can one be able to identify the correct samsung flash file
Old 05-14-2019, 16:18   #2 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 627
in .Net:
Dim com1 As SerialPort = New System.IO.Ports.SerialPort
com1.PortName = "COM6"
com1.Open()
If com1.IsOpen Then
com1.Write("AT+SWVER")
Dim result As String
result = com1.ReadExisting
MsgBox(result)
Else
MsgBox("use search button because com port not open")
End If
I hope I answer your question correctly, and I also hope you are in the right section.
The Following 2 Users Say Thank You to eyestrain For This Useful Post:
Old 05-17-2019, 04:01   #3 (permalink)
Member: 2889809
For delphi
var
iPos : integer;
result , str : string;
begin
ComPort1.Port:='\\.\' + MODEMPORT;
ComPort1.CustomBaudRate:=115200;
if ComPort1.Connected then ComPort1.Close;
ComPort1.Open;
begin
WritePortString('41 54 2B 43 47 4D 52 0D 0A');
Application.ProcessMessages;
sleep(100);
form1.ComPort1.ReadStr(result, 200);
result:= strtohex(result);
iPos := Pos ('0D0A', result);
if (iPos > 0) then
begin
SW := hextostr(Copy(result, iPos + 4, length(result)-20));
sMemo1.Lines.Add('Firmware Version : ' + SW);
end;
The Following User Says Thank You to temporary1221 For This Useful Post:
Page generated in 0.26717 seconds with 7 queries
