Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-31-2009, 21:07   #16 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
I think there must be many sources out there for delphi in the net already.
Visual studio is a relativly new kind of language, with very few websites helping with serial comms, thats why I post here
The Following User Says Thank You to Dave.W For This Useful Post:
Old 04-01-2009, 00:39   #17 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
Thanks Meter: 192
thx man it s very interesting for beginners !!
br
The Following User Says Thank You to infogsm For This Useful Post:
Old 04-02-2009, 00:46   #18 (permalink)
Member: 993247
Thanks Meter: 5
thanks man i've worked with t290i and AT Command it works well.
now i'll try to make the MCU recieve the msg that the mobile recieve automatically and switch on/off devices
The Following 2 Users Say Thank You to cool_guy4ever15 For This Useful Post:
Old 05-17-2009, 10:44   #19 (permalink)
Member: 128122
Thanks Meter: 256
hi, Dave.W
i got this error when I sent this AT Command AT+CPBR=1,250
that command is for phonebook extraction
System.InvalidOperationException was unhandled
Message="The port is closed."
Source="System"
StackTrace:
at System.IO.Ports.SerialPort.ReadExisting() at SerialPort_Test.Form1.SerialPort1_DataReceived(Obj ect sender, SerialDataReceivedEventArgs e) in C:\Documents and Settings\Administrator\My Documents\Downloads\SerialPort_Test\SerialPort_Tes t\SerialPort_Test\Form1.vb:line 74 at System.IO.Ports.SerialPort.CatchReceivedEvents(Obj ect src, SerialDataReceivedEventArgs e) at System.IO.Ports.SerialStream.EventLoopRunner.CallR eceiveEvents(Object state) at System.Threading._ThreadPoolWaitCallback.WaitCallb ack_Context(Object state) at System.Threading.ExecutionContext.runTryCode(Objec t userData) at System.Runtime.CompilerServices.RuntimeHelpers.Exe cuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state) at System.Threading._ThreadPoolWaitCallback.PerformWa itCallbackInternal(_ThreadPoolWaitCallback tpWaitCallBack) at System.Threading._ThreadPoolWaitCallback.PerformWa itCallback(Object state)
InnerException:
The Following User Says Thank You to dr_aybyd For This Useful Post:
Old 08-17-2009, 22:14   #20 (permalink)
Member: 1096878
it is really easier in C# .net , and specially , You can compile and MSL for later compile for linux.
The Following User Says Thank You to satmosc For This Useful Post:
Old 10-23-2009, 22:24   #21 (permalink)
Crazy Poster
Member: 1147468
Thanks Meter: 4
tnx guys For this Nice topic
Old 02-28-2010, 15:46   #22 (permalink)
costel_mcb's Avatar
Member: 230657
Thanks Meter: 10
Dave.W can explain how can i send nck codes via usb to nokia bb5 phones, i try to use at comand but not all phones have "Phone to Network Lock" facility Enabled
Old 03-08-2010, 20:20   #23 (permalink)
Member: 540787
Sonork: 100.1584126
Thanks Meter: 300
Old 05-26-2010, 19:00   #24 (permalink)
Member: 415170
Thanks Meter: 1,042
Dim i As VariantType
Old 05-26-2010, 19:13   #25 (permalink)
Member: 415170
Thanks Meter: 1,042
The Following User Says Thank You to ufsx002 For This Useful Post:
Old 06-08-2010, 22:28   #26 (permalink)
calvinpower's Avatar
Member: 14229
Thanks Meter: 135
Dave.W
I want to write an application using visualbasic2008 which will run on my PC and communicate to a mobile phone using AT commands. ( nokia 1202, 1203)
like reading phone imei, security code, restore factory state, unlock sp lock
The Following User Says Thank You to calvinpower For This Useful Post:
Old 06-09-2010, 08:15   #27 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
Yes, read post 1 and 2 in this thread!
Old 06-09-2010, 21:37   #28 (permalink)
Member: 14229
Thanks Meter: 135
cool man. but where to find AT COMMANDS
Old 06-10-2010, 08:16   #29 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
Read post number 2, all is posted.
Old 06-10-2010, 10:57   #30 (permalink)
Member: 14229
Thanks Meter: 135
Dave.W
its grateful that u have provided me with such a beatiful and simple tutorial. i was in search of such tutorial for long a time.
I have managed to add a progressivebar and a timer. I am about to start prepairing gsm AT commands like read imei, firmware version, model , make and so forth. please guide me how to send all AT commands at once. and please can you give me AT commands for " read security code, write flash etc...etc..
free video tutorial for VB.net Mind Power GSM Programming & Reverse Engineering 6 10-07-2011 20:08
how to read Cyberflex e-gate cards SN with VB.net GalaxyMan GSM Programming & Reverse Engineering 7 04-19-2010 07:45
Problem Serial Port in Widcomm 5.1.0.1100 Nuker5 Bluetooth-Software 3 07-04-2006 12:45
Using serial port in T720i paulos Motorola P2k 0 06-11-2004 23:58
Flash program for serial port Byteripper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 02-02-2001 18:35
Page generated in 0.25519 seconds with 11 queries
