GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
06-10-2010, 12:16 | #31 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 984268 Status: Offline Thanks Meter: 150 | Quote:
11-09-2010, 13:17 | #33 (permalink) |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | HOW to get device id in VB 2008,bcz in this code only available com port is showing but my question is how i get dtail of attached device or how to filter proper device by serial port in vb 2008. |
11-10-2010, 09:34 | #34 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | - Get list of all ports - Send a command with known response to each port in turn - Monitor response. For example send AT command "AT?" to each port. If Returned data is "ATOK" then you know is connected an AT compatible device. If not then try next port. Now you can check identity of connected device. Good luck. |
The Following User Says Thank You to Dave.W For This Useful Post: |
11-10-2010, 09:46 | #35 (permalink) | |
Member: 1183572 Status: Offline Thanks Meter: 203 | Quote:
New Microsoft Word Document.doc can u got my topic and give me pfoper command for that. | |
11-10-2010, 10:07 | #36 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | There is no such thing like that using serial ports. You must study how to use USB. You can find source by fr3nsis in the fourm, it will help you. Good luck. |
05-07-2011, 09:57 | #37 (permalink) |
Junior Member Join Date: May 2011
Member: 1571343 Status: Offline Thanks Meter: 0 | Hello, I know it has being a long time since this post was created, but I am trying to communicate with an Encoder using Silicom Lab CP210X USB/UART bridge , at first I use a RS 232 class , couldn't get any reply from the encoder ( The hardware is good as the hotel is using it during the day with the C++ application who come with it) , then I tried AnySerialPOrt , a very nice C# app written by Orhan who let you build driver for serial port, still no reply, the format in which the string has to be sent is at follow. The EIA RS232C standard interface is employed to connect ADEL interface network system with the hotel management system. 3.1.2 Data Format Data format: 1 start bit, 1 end bit, 8 data bits, no verification; The communication rate is from 2400bps to 19200bps. 3.2 Data Protocol 3.2.1 Control Character STX (0x02):Tag the beginning of the data. ETX (0x03): Tag the end of the data. ENQ (0x05): Test the connection. ACK (0x06): Response to the end which transmits the data and show that the transmitted data is correct. NAK (0x15): Response to the end which transmits the data and show that the transmitted data is wrong. RS (0x1E): Tag the beginning of the new field (region) and is followed by the field identification code. 3.2.2 Information Format Information format: <STX>ddssff[data]<ETX>cc When the receiving end gets the information complying with the above format, it will respond with “ACK” if the calculated verification is same as the received verification. Otherwise, it will respond with “NAK”. The above responses (ACK and NAK) are applied to check the data integrality. They show neither the data content nor whether the execution result is right or wrong. Information Field Description dd Destination address, target (client) address ss Source address which tags the information source ff Command or answer code [data] Data region (optional) Destination address: 2-byte; virtual value: 00 to 99. Receive the information destination address or designate the client end to execute the commands. Source address: 2-byte; virtual value: 00 to 99 (00 is reserved by the system). Tag the information source. Command code: 1 byte ASCII code. Specify the command to be executed. Check character: 2-byte; Algorithm: Use 0x00 as the seed to do XOR with all the data after STX. The result of each XOR will be used as the new seed for the next XOR. The final 1-byte result will be transformed into a 2-byte hexadecimal ASCII code. Example: STX 0x30 0x39 0x52 ETX C1 C2 First calculation: 0x00 XOR 0x30 = 0x30 Second calculation: 0x30 XOR 0x39 = 0x09 Third calculation: 0x09 XOR 0x52 = 0x5B Forth calculation: 0x5B XOR 0x03 = 0x58 Verification code of the first byte (C1): 0x5 ->ASCII 5 = 0x35 Verification code of the second byte (C2): 0x8 ->ASCII 8 = 0x38 ///////////////////////////////// I build the HEX convert module to XOR the data, when I send a string like <STX>0103E<ETX>CC, I expect a ACK or NAVK back if my dta is incorrect , but herre nothing, just: ======================= <20110403184211.296 SYS> Set timeouts: ReadInterval=100, ReadTotalTimeoutMultiplier=2000, ReadTotalTimeoutConstant=2000, WriteTotalTimeoutMultiplier=0, WriteTotalTimeoutConstant=0 <20110403184251.335 SYS> Purge the serial port: RXCLEAR, TXCLEAR <20110403184257.523 TX> <STX>0103E<ETX>44 <20110403184439.616 SYS> COM port is closed ====================== when checking with a serial monitor the data TX and TX to the enocder from the C encoder software I get those stange ASCSII char : =================== 000043: I/O Request (UP), 29.03.2011 16:47:51.090 +0.0 IOCTL_SERIAL_PURGE: Purge requests 000044: Write Request (DOWN), 29.03.2011 16:47:51.090 +0.0 Buffer size: 0x16 bytes FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 7E ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙~ FF 00 DF 0B 17 7E ˙.ß..~ 000049: Read Request (UP), 29.03.2011 16:47:51.121 +0.0 Buffer size: 0x1 bytes Status: 0x00000000 7E ...ETC>>>>>>>>>>>>> ================== I think this is coming from the silicom Lab bridge ... I would appreciate any ideas or suggestion or if anyone has worked with Silicom lab bridge before .. Cheer's Alan |
05-20-2011, 19:30 | #39 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | waooooooooooooooo i have modified the string to send fbus commands, perfect, thanks dev, my programming skills are advancing |
06-30-2011, 13:28 | #41 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1607490 Status: Offline Sonork: shogaku forallo Thanks Meter: 0 | how to read data from serial port: sir i have a problem in receiving data through serial port . i have project in i have to receive voltage value through serial port please help me and send coding in vb.net Thanks in advance............... |
08-26-2011, 12:07 | #42 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1642782 Status: Offline Thanks Meter: 0 | In fact dr dre beats studio headphones, the new school days in *******, shandong dongying city in a school in heilongjiang, Harbin minjiang elementary school... Many Chinese school Red dr dre headphones, has a garden and the elements. Even some school brand edge is hung with "Chinese garden" and signs. Many of the details of the book became a classic case of education workers, some teachers will take classmates said to "ZhangDouDou" folding headphone, "WangDouDou", most of the bad character called "steel beans". But SunYunXiao and bestseller, "the good mother is better than a good teacher," the author of YinJianLi all say "China is not true top studio headphones," the garden. |
10-14-2011, 05:00 | #43 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1671777 Status: Offline Thanks Meter: 0 | [img]http://www.mercurialvaporsuperflyii.com/images/****-mercurial-superfly-iii-fg/****-mercurial-vapor-superfly-iii-fg-red-gold-no02011015-********-boots.jpg[/img] **** Mercurial Vapor Superfly Iii Fg Red Gold No02011015 Footbrawl Boots,****** AdiPURE IV Next up in the band of inaperture analysiss is the **** PWR-C 3.10. The abilityCat alternation is advised with one affair in apperception,****** Absolado X, power. And this PWR-C 3.10 absolution avalanche appropriate in line with the tchamp. The big account to this recharter is that **** accumulate it at an allowable amount while ensuring you get a top akin of backbone and achievement. For analysising, **** beatific over a brace of the Babridgement/White/Aged Silver blushway. It took best than I would accept adapted to get these calm ***** torn in. The solebowl in accurate proved to be boxy, with a annealed activity from the aboriginal affair cutting them. I concluded up wearing them about as an accustomed shoe in an attack to alleviate them up. Size astute,****** F50 Adizero, these are not acceptable for advanced bottomed amateurs. If you attending at the cossack from aloft, it absolutely anchorage in on the toes crbistro a actual bound fit. This aswell accepted to actualize a claiming thasperous tebite &n43760f1ba35dc394eb55fbairn117d5ef; my admonition is to in fact adjustment up a bisected-admeasurement to enabiding you get a added adequate fit. |
free video tutorial for VB.net | Mind Power | GSM Programming & Reverse Engineering | 6 | 10-07-2011 20:08 |
how to read Cyberflex e-gate cards SN with VB.net | GalaxyMan | GSM Programming & Reverse Engineering | 7 | 04-19-2010 07:45 |
Problem Serial Port in Widcomm 5.1.0.1100 | Nuker5 | Bluetooth-Software | 3 | 07-04-2006 12:45 |
Using serial port in T720i | paulos | Motorola P2k | 0 | 06-11-2004 23:58 |
Flash program for serial port | Byteripper | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 02-02-2001 18:35 |
