Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 04-09-2011, 20:15   #16 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Hash find OK:
SHA1 TEST [35691803114350] = 8D1C71F10A3F36FAFCFEB60B8B3D10E341E4B78D
SHA1 Hash [35691803114350] = 8D1C71F10A3F36FAFCFEB60B8B3D10E341E4B78D
Mastersp = 065222098608403
Mastersp = 065222098608403 = 0605020202090806080403
Saved as:356918031143509.cod
[IMEI]
356918031143509
[HASH]
[MASTERSP]
[SPCodes]
#pw+126673811028371+1#
#pw+496488505802080+2#
#pw+036354749939345+3#
#pw+270409004584725+4#
#pw+873365185473830+5#
#pw+352514663105275+6#
#pw+415369813640620+7#
saved as : 356918031143509_SPCodes.txt
end;
end.
Best Ragards.
Mourad.
Old 04-13-2011, 16:26   #17 (permalink)
Member: 679176
Sonork: 1585224
5230
Asic ID : 000000010000022600010006400C192101051103
Public ID : 09D000195C4C0052361BB18066BD07986282618E
Hash : 479C6DDE3942E12C429C1D6ADED80371
Hardware ID: 400C192101051103
from this info how is look a log file can someone learn me??
Old 04-15-2011, 18:59   #18 (permalink)
Member: 30623
Does someone tried to make this optimization for SL3 with the http://www.zorinaq.com/talks/breaking-unix-crypt.pdf
Old 04-17-2011, 21:38   #19 (permalink)
Member: 78543
Sonork: 100.1603369
SL3 is using SHA1, thing you posted is something else.
Anyway, don't worry about optimization for SL3 I'm sure when there comes something new, everyone will talk about it.
Old 07-25-2012, 12:00   #20 (permalink)
Member: 1789379
Hello I'm a bit lost I've tried reading tutorials and guides but still this is something very new to me.
What I want is using Cyclone Box read the hash and the codes needed to do Bruteforce with ighashgpu.
With Cyclone I get a lot of .bat files and for Ighashgpu I only need to enter a command line.
I got:
imei=351539041897580
hash=005DE892A9E68469F40507AB5E217E365A7E8001902CB 11B74958F5213F030E03A6F52CC45A15E252BC808510EEDE5B 4486407F2401F1044E3E4837336DCE3CD50146461288B1CBDE 47C1508805DF528373A3B13E8EC4BF2A9B7A254ED570095AB1 C44F0D8546753DDD63CE57521E69FE8938AD12371E465AA68C 97E029722490594AF0E7717DF53039F63026C7AF6EF82E12FF 069311C81ACD0EAD806590798
And im trying this command in ighashgpu:
ighashgpu -t:sha1 -salt:351539041897580 -h:005DE892A9E68469F40507AB5E217E365A7E8001 -uh:00010203040506070809 -min:15 -max:15
pause
But it´s not working, I've read I have to use this format:
ighashgpu -t:sha1 -salt:00[imei]00 -h:[hash] -uh:00010203040506070809 -min:15 -max:15
But the -uh:[] it's always the same or I have to put a code I retreived from Cyclone?
Sorry I know I'm very lost I'm trying to learn if you could give me a hand with the right command for ighashgpu I would really appreciate it.
Thank you
Old 08-12-2012, 20:44   #21 (permalink)
Member: 13445
Hello!
probably your [imei] its incorrectly 15 bytes long. its only 00[14-bytes-imei]00
the .bat files are the correct command line ready to run with oclhashcat-lite, which is as speedy as ighashgpu (or maybe more )
3310 problem display disappears after input pin simonb Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 01-09-2009 09:37
how to input unlock code??? skedone Infineon C16X M51 & ARM7 M52 BASED 1 08-07-2002 11:45
How to input nck by keyboard? ren777 Mitsubishi 2 02-16-2002 14:47
restore T9 text-input siemens S35 baronx x1x to x45/x50 0 01-03-2002 22:16
Nck input problems, on mc9224.1m dollyb Infineon C16X M51 & ARM7 M52 BASED 0 04-05-2001 21:27
Page generated in 0.25681 seconds with 11 queries
