Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-29-2011, 19:35   #1 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
SL3 patch unlock (Flash patching) possible or not?
Since now no one told about SL3 patch unlock (Flash patching) possible or not?
lets share here your opinion and answers about this.
Best Regards.
Old 05-29-2011, 19:47   #2 (permalink)
Medusa Lancer's Avatar
Member: 52360
Sonork: 100.1611553
it's not possible for now!!!
Old 05-29-2011, 19:49   #3 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
not possible and even if possible is useless
Old 05-29-2011, 19:58   #4 (permalink)
g-gabber's Avatar
Member: 192652
Sonork: No
Wink
If it would be possible to patch firmware, it would be enough to change one byte to unlock the phone.
br g
Old 05-29-2011, 20:34   #5 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
br g
....Maybe ..............but i don't think changing 1 byte will be enough to unlock SL3 phones.
correct me if i'm wrong :
in SL1, SL2 when code is valid phone change lock flag and using PATCH u need just to change 1 byte (0 or 1) and the phone do the rest, it change flag and phone will be unlocked for ever.
but in SL3 the phone don't make any change because each new SL data need RSA1024 signature, so it need RSA private key !!! phone have only public key to check signtaure .....
./br
The Following 2 Users Say Thank You to angel25dz For This Useful Post:
Old 05-29-2011, 20:49   #6 (permalink)
g-gabber's Avatar
Member: 192652
Sonork: No
./br
In case of SL3 you don't need to manipulate the signature. There is function which is called "is_simlock_open", all what need to do is change a condition jump on right place. Consider there is a hybrid firmware like E71 v300 which supports sl2 and sl3.
br g
Old 05-29-2011, 21:20   #7 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
br g
"IS_SIMLOCK_OPEN" in case of SL3, what it do exactly ??
I see it like this :
1st it check lock flag,
1- if phone unlocked (factory unlocked with provider 244) exit function and phone start unlocked....
2- if phone is not factory unlocked it check PM120,03
a- if empty : phone start locked
b- if there is data in PM120,3, it generate SP and bruteforce RND to compare sha1 hash's
b-1 if sha1 is the same stored in PM120,1 : phone start unlocked
b-2 if sha1 not found phone start : Contact service
the only known way to check validity of NCK is compare SHA1 (SP+RND+IMEI) the reason why phone need to bruteforce salt, if there is another way (permanent way) to check if phone is unlocked or not, why phone need to do bruteforce in every start ???
./br
The Following 4 Users Say Thank You to angel25dz For This Useful Post:
Old 05-30-2011, 01:20   #8 (permalink)
oOXTCOo's Avatar
Member: 2878
if you can exploit the phone to accept patched firmware
then you can do all what you whant
you can completly disable simlock check or you can
write another rsa key for simlock and write the correct
sp code into pm or unlock with calculated code for
the rsa sign wich you have written...
problem is more.. how to exploit the phone to accept
patched firmware and not how it is protected...
it dose no matter how its protected... with patching
you can change everything...
correct me if iam wrong.
better discuse how to make phone to accept patched firmware.
The Following 5 Users Say Thank You to oOXTCOo For This Useful Post:
Old 05-30-2011, 01:30   #9 (permalink)
lam_spiderman's Avatar
Member: 1129593
Best Regards.
not now, wait come .
Old 05-30-2011, 23:53   #10 (permalink)
kamiran's Avatar
Member: 223973
i like the idea of finding an exploit ... like devs do in ios or android based phones to install custom (patched) firmwares.
K@mi
Old 05-31-2011, 06:08   #11 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
K@mi
Android has different firmware structure. open source kernel. nokia is really different.
B/R
Sub4t4
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 05-31-2011, 08:54   #12 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
./br
I'am really beginer in Nokia, so correct me if wrong.
1.This value, in fact is not random value, it's stored in some space in phone.
(cripted,hashed by some algo no matter).
2.To acces secure storage area need modified loader , but..... if use nokia C++ and make small aplication to colect some data from phone?
Upload this to phone and execute and save this data to memory card?
Is same like acces private filesistem from outside and from inside.
Idea is to acces some phone security function from inside not from outside
and execute this function.
Exist posibility to catch this value used in code verification algo ?
The Following User Says Thank You to orbita For This Useful Post:
Old 05-31-2011, 09:42   #13 (permalink)
Member: 8843
"...CORRECT ME IF I AM WRONG..." i like the idea...
Old 05-31-2011, 09:54   #14 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
You post this only to post some?
If have some usefull to write, write.
If not, not need post nonsense.
Is so "hot" in Africa now ?
Old 05-31-2011, 10:28   #15 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
I'm a beginner too
Salt is totally random, this is why phone must bruteforce it to check NCK validity....
why ?? all needed data u can get it using custom loader.... even u make this kind of app, i don't think it can be able to access to secure storage...it need to find and exploit a system hole like bufferoverflow or other kind of holes....
yes......
./br
The Following User Says Thank You to angel25dz For This Useful Post:
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.38747 seconds with 11 queries
