Unlock Server
Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-20-2012, 18:18   #1 (permalink)
Member: 9848
Some thoughts about ICERA based modems eg. Nokia CS1x series.
Until now there is only 1 non-released solution for ICERA-based modems like Nokia CS-1x series / Option AT&T 322 Orange 515m / Vodafone K-3806-Z
During analysis of fimware updater for Nokia CS-15 I found some files in firmware directory.
One of this file is asn1_tool.exe
When you start this app in a DOS-Box you get:
c:\>asn1_tool
AUDIO_CFG asn1 encoder/decoder version 1.3
CUST_CFG asn1 encoder/decoder version 7.9_04_1.2
Default usage:
asn1 -s <SPEC_TYPE> [-q] [-u] (-e|-d|-g) <file.bin> <file.xml>
-to generate default: asn1 -s <SPEC_TYPE> -g -x <file.xml> -b <file.bin>
-to encode from XML: asn1 -s <SPEC_TYPE> -e -x <file.xml> -b <file.bin>
-to decode from binary: asn1 -s <SPEC_TYPE> -d -b <file.bin>
SPEC_TYPE values:
- PLAT_CFG
- EXTHDR
- CUST_CFG
- AUDIO_CFG
- AUDIO_ECAL
- AUDIO_TCAL
Optional flags:
-q (quiet mode)
-u (values equal to default not encoded)
And c:\>asn1_tool -s CUST_CFG -d -b nocd.iso.wrapped
<CustomerConfig>
<crossBootCheck>
<secondaryBootUpda****able><false/></secondaryBootUpda****able>
<loaderUpda****able><false/></loaderUpda****able>
<factoryTestsUpda****able><false/></factoryTestsUpda****able>
<appliUpda****able><false/></appliUpda****able>
<crossBootCheckEnable><true/></crossBootCheckEnable>
<massUpda****able><false/></massUpda****able>
</crossBootCheck>
<preferredSystem><wcdmaPref/></preferredSystem>
<serviceDomain><csPs/></serviceDomain>
<bandConfiguration>
<bandGroupScan><emeaFirst/></bandGroupScan>
<w1900BeforeW850><false/></w1900BeforeW850>
<preferredBand>
<Band><none/></Band>
</preferredBand>
<bandCapabilities>
</bandCapabilities>
<diversityOnBand>
<Band><fddBandI/></Band>
<Band><fddBandII/></Band>
<Band><fddBandV/></Band>
</diversityOnBand>
</bandConfiguration>
<customMepData>
<personalisationsActivated>2</personalisationsActivated>
<personalisationsEnabled>31</personalisationsEnabled>
<personalisationKeyPS>
<Uint16>0</Uint16>
</personalisationKeyPS>
<personalisationKeyPN>
<Uint16>0</Uint16>
</personalisationKeyPN>
<personalisationKeyPU>
<Uint16>0</Uint16>
</personalisationKeyPU>
<personalisationKeyPC>
<Uint16>0</Uint16>
</personalisationKeyPC>
<personalisationKeyPP>
<Uint16>0</Uint16>
</personalisationKeyPP>
<keyRetryPS>10</keyRetryPS>
<keyRetryPN>10</keyRetryPN>
<keyRetryPU>10</keyRetryPU>
<keyRetryPC>10</keyRetryPC>
<keyRetryPP>10</keyRetryPP>
<networkIds>
<SimPlmnAsn>
</SimPlmnAsn>
</networkIds>
<networkSubsetId>
<Uint16>0</Uint16>
</networkSubsetId>
<serviceProviderId>
<Uint16>0</Uint16>
</serviceProviderId>
<corporateId>
<Uint16>0</Uint16>
</corporateId>
</customMepData>
<copsInitPlmn>
<mcc>4095</mcc>
<mnc>4095</mnc>
<mncThreeDigitsDecoding>0</mncThreeDigitsDecoding>
</copsInitPlmn>
<copsInitNwSelMode>0</copsInitNwSelMode>
<cgdcont>
<cid>0</cid>
<pdpType>IP</pdpType>
<apnName></apnName>
<pdpAddr></pdpAddr>
<dComp>0</dComp>
<hComp>0</hComp>
</cgdcont>
<cgeqreq>
<cid>0</cid>
<trafficClass>0</trafficClass>
<maxBitRateUplink>0</maxBitRateUplink>
<maxBitRateDownlink>0</maxBitRateDownlink>
<guaranteedBitRateUplink>0</guaranteedBitRateUplink>
<guaranteedBitRateDownlink>0</guaranteedBitRateDownlink>
<deliveryOrder>0</deliveryOrder>
<maxSduSize>0</maxSduSize>
<sduErrorRatio>0E0</sduErrorRatio>
<residualBER>0E0</residualBER>
<deliveryOfErrSdu>0</deliveryOfErrSdu>
<transferDelay>0</transferDelay>
<trafficPriority>0</trafficPriority>
</cgeqreq>
<cimiDisabled><false/></cimiDisabled>
<ati1String>Icera, Inc.</ati1String>
<ati2String></ati2String>
<ati3String></ati3String>
<ati4String></ati4String>
<ati5String></ati5String>
<ati6String></ati6String>
<ati7String></ati7String>
<cfunModeAtStart>1</cfunModeAtStart>
<operator1Enhancements><false/></operator1Enhancements>
<usb>
<idVendor>6531</idVendor>
<idProduct>769</idProduct>
<bcdDevice>1</bcdDevice>
<manufacturer>Icera Inc.</manufacturer>
<product>Datacard</product>
<serialNumber>0.0.1</serialNumber>
<idProductMassStorage>773</idProductMassStorage>
</usb>
<softwareVersionNumber>99</softwareVersionNumber>
<customerLabel></customerLabel>
<specificationVersion>7</specificationVersion>
<specificationRevision>9</specificationRevision>
<ignoreWwanDisableFunct><true/></ignoreWwanDisableFunct>
<extension>
<versioning>
<swVersion></swVersion>
<date></date>
<time></time>
<model></model>
<drvVersion></drvVersion>
<control></control>
</versioning>
<customerIdVersion>04_1.2</customerIdVersion>
</extension>
<engineeringMode>
<access><disabled/></access>
<engineeringKey>
01 23 45 67 89 AB CD EF FE DC BA 98 76 54 32 10
A1 B2 C3 D4
</engineeringKey>
<factoryAccess><passwordEnabled/></factoryAccess>
<factoryEngineeringKey>
78 5E DE 9F E2 D1 EE 62 5F 43 E6 D1 69 B6 AE 46
C4 7F 14 8E
</factoryEngineeringKey>
</engineeringMode>
<csVoiceDisabled><false/></csVoiceDisabled>
<operatorEnhancements>
<operator2Enhancements><false/></operator2Enhancements>
</operatorEnhancements>
<hspaCategories>
<hsdpaCategory><cat8/></hsdpaCategory>
<hsupaCategory><cat5/></hsupaCategory>
</hspaCategories>
<modelIdString></modelIdString>
<manufacturerIdString></manufacturerIdString>
<temperatureSafety>
<temperatureThr0>400</temperatureThr0>
<temperatureThr1>400</temperatureThr1>
<temperatureThr2>400</temperatureThr2>
</temperatureSafety>
<cipheringA53Enabled><false/></cipheringA53Enabled>
<batteryMonitoring>
<vbatCriticalThr>0</vbatCriticalThr>
<pwrRedLBGmskVoltage>0</pwrRedLBGmskVoltage>
<pwrRedLBGmskPowerVal>0</pwrRedLBGmskPowerVal>
<pwrRedLB8pskVoltage>0</pwrRedLB8pskVoltage>
<pwrRedLB8pskPowerVal>0</pwrRedLB8pskPowerVal>
<pwrRedHBGmskVoltage>0</pwrRedHBGmskVoltage>
<pwrRedHBGmskPowerVal>0</pwrRedHBGmskPowerVal>
<pwrRedHB8pskVoltage>0</pwrRedHB8pskVoltage>
<pwrRedHB8pskPowerVal>0</pwrRedHB8pskPowerVal>
<rfPaOnThrUmts>10000</rfPaOnThrUmts>
<rfPaOnThrGsm>10000</rfPaOnThrGsm>
</batteryMonitoring>
<gprsAttachAtPowerOn><true/></gprsAttachAtPowerOn>
</CustomerConfig>
Anybody know how to read out this information from a live modem?
Anybody know how to enter the factory mode?
From another source I got the following:
<customMepData>
<personalisationPSEnabled><true/></personalisationPSEnabled>
XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX
XX XX XX XX
XX XX XX XX
XX XX XX XX
XX XX XX XX
<networkIdsList>
<SimPlmnAsn>
<mcc>4095</mcc>
<mnc>4095</mnc>
</SimPlmnAsn>
</networkIdsList>
<networkSubsetIdsList>
<Uint16>255</Uint16>
</networkSubsetIdsList>
<serviceProviderIdsList>
</serviceProviderIdsList>
<corporateIdsList>
</corporateIdsList>
<personalisationKeyLockErase>
XX XX XX XX
</personalisationKeyLockErase>
</customMepData>
All keys are the same (XXed by me).
Anybody know how to send personalisation commands to modem?
Some commands are in config directory when you install Nokia_Internet_Modem.exe. Files are readable SQLite 3 databases.
Old 05-21-2012, 19:35   #2 (permalink)
Crazy Poster
Member: 731821
where is
Old 05-21-2012, 20:41   #3 (permalink)
Member: 9848
C:\program files\nokia internet modem\firmwares
The Following User Says Thank You to german gsm team For This Useful Post:
Old 06-16-2012, 17:22   #4 (permalink)
Member: 9848
AFAIK Icera softmodem is based on embedded linux.
NAND Flash uses Yaffs filesystem.
Old 06-16-2012, 18:00   #5 (permalink)
Member: 1723215
Do you have a program that sends the correct sequence on the modem? If so catch this no problem
Old 06-16-2012, 18:55   #6 (permalink)
Member: 9848
The Icera updater writes files to the filesystem.
Perhaps someone can patch it to read it.
Here is a standalone updater from finnish operator Elisa for Nokia CS-17
http://www.elisa.fi/elisa/docimages/...er-0.1.0.5.exe
Old 06-16-2012, 19:15   #7 (permalink)
Member: 1723215
nevermind, how and who stores files. isnt modem connected to com-port virtual or phisical? hang up tracer and log traffic. all we need program sends right sequence to the modem
Old 06-17-2012, 11:51   #8 (permalink)
Member: 9848
There is a file Nokia_Internet_Stick_CS-10_RD_flashing_instructions.doc on the net.
But unfortunarely the python script is missing.
Screenshot from the word file:
Old 06-17-2012, 17:55   #9 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Nice R&D, I will buy few sticks and check what's going on
The Following 2 Users Say Thank You to karwos For This Useful Post:
Old 06-20-2012, 08:56   #10 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
And you will need hexrays update support for this cpu. No opcodes, no debugger etc for these cpus
Old 06-20-2012, 12:14   #11 (permalink)
Member: 9848
I doubt that Icera ported linux to a completely new CPU architecture.
If someone finds a way how to unpack the modem.wrapped file we will see. It's zlib with Icera header.
Until now I didn't find the zlib header.
Old 06-21-2012, 05:59   #12 (permalink)
Moderator
Member: 73
Sonork: 100.86913
1. Uniextract by legroom
2. modem.wrapped ?!?!?!
0A04E81C40000000D3A43E0000000088
0000000101000000DD730BA400000000
81004040000298DB58DCCB98DCCC4C8
A80C182B8C0000000000000000000000
00001E71C0C000000 C3A23E00
78DAC4BD0B585357BA30BCF7CECE9500
9B9B606B3409A060B5265CBCB4C506D08A1DAD58
- IN RED -> Compressed part size (big endian)
- IN YELLOW -> Compressed data
0x78, 0xDA -> ZLIB extra compression (level 9) CUT TO HERE!!!
3. Use attached exe to decompress.
D:\test>zlibc.exe -d modem.wrapped mdm
Irgendeine Taste zum Abbrechen druecken!
Dekomprimiere modem.wrapped nach mdm. Prozent fertig:  99%
Status: Erfolg
D:\test>
Regards: Victor
The Following 2 Users Say Thank You to Victor For This Useful Post:
Old 06-22-2012, 19:42   #13 (permalink)
Member: 26596
Status: Erfolg
D:\test>
Regards: Victor
...and what is next step after unzlib
maybe dxp disassembler ))))
Regards,
Latigido922
Old 06-23-2012, 04:49   #14 (permalink)
Moderator
Member: 73
Sonork: 100.86913
No idea ... I just help with unpacking.
Who want reverse let's reverse.
i do all huawei modems by imei.
Old 06-25-2012, 17:55   #15 (permalink)
Member: 15022
Sonork: 100.53452
Yeah but here problem is that no tools out there for us =))
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.86799 seconds with 12 queries
