Hello guys.I am preparing a program on sony devices.How do I write and send data in Delphi ?
I am using this unit but unfortunately it did not work...
PHP Code:
unit USB;
interface
Uses SysUtils, Forms, Windows;
{* USB - Read / Write Unit *}
{* by Harald Kubovy *}
{* How To USE: *}
{* Sending and Reading Data to Device: *}
{* string_result:= RWUSB('DATA TO SEND IN HEX', Read, Timeout); *}
{* EXAMPLE (ONLY SENDING): *}
{* s:= RWUSB('FF FF FF'); *}
{* s is String Result of Readed Data from Device *}
{* 'FF FF FF' is Data to Send in Hex (this will send FFFFFF to Device *}
{* EXAMPLE WITH READING AFTER WRITING: *}
{* s:= RWUSB('FFFF', 16); *}
(* 16 = How mutch to Read / 0 for no Reading *)
{* EXAMPLE WITH TIMEOUT: *}
{* s:= RWUSB('FFFF', 16, 100); *}
{* 100 is the Reading Timeout, Standart is 500/ms. *}
{* Copyright - Do whatever you whant with it ;o) *}
type
TSetofChars = Set of Char;
Function USBOpenDriver:boolean;
Function USBCloseDriver:boolean;
function USBReadText(BytesRead: cardinal; timeout: cardinal = 500): string;
function USBReadHEX(BytesRead: cardinal; timeout: cardinal = 500): string;
function RWUSB(frame: string; readLen:integer = 0; ReadTimeout: integer = 500; Typ : String = 'HEX') : string;
procedure USBWriteHEX(frame: string);
implementation
{ Get Handle of DeviceDriver }
var USBPORT:Thandle = INVALID_HANDLE_VALUE;
{$HINTS OFF}
{ Open USB Driver }
begin
// Open Device Path \\?\USB#Vid_058b&Pid_0015#5&25ea51ff&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
USBPORT:= CreateFile('\??\USB#VID_0FCE&PID_ADDE#5&dc4a972&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed}', GENERIC_WRITE or GENERIC_READ,
FILE_SHARE_WRITE or FILE_SHARE_READ, nil, OPEN_EXISTING, FILE_FLAG_OVERLAPPED OR FILE_ATTRIBUTE_NORMAL, 0);
USBOpenDriver:= USBPORT <> INVALID_HANDLE_VALUE;
if USBPORT = INVALID_HANDLE_VALUE then // error at open port
begin
result:=false;
end else result:=true;
end;
{$HINTS ON}
begin
USBCloseDriver := CloseHandle(USBPORT);
USBPORT := INVALID_HANDLE_VALUE;
end;
function NurBestimmteZeichen (const aValue : String; aChars : TSetofChars) : String;
var
i: Integer;
newString : string;
begin
newString := '';
for i := 0 to Length(aValue) do
begin
if aValue[i] in aChars then
begin
newString := newString + aValue[i];
end;
end;
result := newString;
end;
Function HexToStr(s: String): String;
Var
i : Integer;
Begin
Result:=''; i:=1;
While i<Length(s) Do
Begin
Result:=Result+Chr(StrToIntDef('$'+Copy(s,i,2),0));
Inc(i,2);
End;
End;
Function StrToHex(s: String): String;
Var
i : Integer;
Begin
Result:='';
If Length(s)>0 Then
For i:=1 To Length(s) Do Result:=Result+IntToHex(Ord(s[i]),2);
End;
Function USBReadTEXT(BytesRead : dWord; timeout: cardinal = 500) : string;
var
d: array[0..10000] of byte; {Readed Data}
s, buffer: string;
i, Tmp: Integer;
Ovr : TOverlapped;
count :cardinal; {Count = How mutch Readed Bytes}
begin
Result := '';
count:=0;
Fillchar( d, sizeof(d), 0 );
FillChar(Ovr, SizeOf(TOverlapped), 0);
Ovr.hEvent := CreateEvent(nil, true, FALSE, nil);
if not ReadFile(USBPORT, d, BytesRead, count, @ovr) then
if GetLastError=Error_IO_Pending then
if WaitForSingleObject(ovr.hEvent, timeout) = WAIT_OBJECT_0 then
GetOverlappedResult(USBPORT, ovr, count, false)
else CancelIo(USBPORT);
CloseHandle(Ovr.hEvent);
s := '';
for i := 0 to count-1 do
begin
Tmp:=ord(d[i]);
s := s + Char(Tmp);
end;
{Convert to String Text}
s := strtohex(s);
buffer:='';
for i:=1 to length(s) do
begin
if Odd(i) then
begin
buffer := '';
buffer := hextostr(s[i] + s[i+1]);
buffer := NurBestimmteZeichen(buffer,['0'..'9','a'..'z','A'..'Z','.'..':',' '..'?']);
result := result+buffer;
end;
end;
end;
Function USBReadHEX(BytesRead : dWord; timeout: cardinal = 500) : string;
var
s: string;
i, Tmp: Integer;
Ovr : TOverlapped;
begin
Result := '';
count:=0;
s := '';
begin
Tmp:=ord(d[i]);
s := s + Char(Tmp);
end;
Result := strtohex(s);
end;
Function _USBWritePointerA(bp : Pointer; SizeToSend : DWord; timeout: integer) : Cardinal;
var
Ovr : TOverlapped;
begin
Result := 0;
if not WriteFile(USBPort, bp^, SizeToSend, Result, @ovr) then
GetOverlappedResult(USBPORT, ovr, Result, false)
end;
var
BytesWritten: DWord;
begin
while Pos(' ', FRAME) > 0 do Delete(FRAME,Pos(' ', FRAME),1);
frame:=hextostr(frame);
WriteFile(USBPORT, (Pchar(frame))^, SizeOf(frame), BytesWritten, nil);
end;
Function USBWritePointerA(bp : Pointer; SizeToSend : DWord) : boolean;
begin
Result := _USBWritePointerA(bp, SizeToSend, $688) = SizeToSend;
end;
Function USBWriteStringA(SendString : String) : boolean;
var
StrSize : Word;
begin
StrSize := Length(SendString);
Result := _USBWritePointerA(@SendString[1], StrSize, $688) = StrSize;
end;
begin
if length(frame) >0 then USBWriteStringA(hextostr(frame));
Application.ProcessMessages;
sleep(ReadTimeout);
if (ReadLen >0) and (Typ='HEX') then result:=USBReadHEX(readLen, ReadTimeout);
if (ReadLen >0) and (Typ='STRING') then result:=USBReadText(readLen, ReadTimeout);
end;
end.
