Unlock Server
Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-27-2012, 02:07   #1 (permalink)
Crazy Poster
Member: 776944
Strange problem with connecting to S5230 via USB...
Hi. I'm starting to deal with USB port so i decided to start with some basics. I choosed S5230, target = get access to modem via AT Commands, butI have a little problem with this...
I sniffed a lot of packets from New PC Studio for beginning, & i see there is few packets to Set Communication mode To AT. So i wrote a lil program to switch to AT Mode, basing on sniffed packets, later few AT queries to test it (GET MODEL, GET IMEI, GET PRODUCT CODE, GET SW VERSION etc) and everything is OK - program works great but... and there's a problem : Communication works properly ONLY When PC Studio is launched! O.o
I checked Sniff log few times (sniffed packets from PC Studio), and i dont see any packet i missed. Interesting thing: When I close PC Studio & run sniffer to sniff my program vs. phone, it shows that phone send response packets for my AT Commands properly, but my program didnt show any packet @ Memo. If I run PC Suite, program works great. Someone can tell me whats goin on?
Here's a part of source (becouse I developed it only for educational purposes, the code looks ugly)
Here's a chain of Initial packets... Packets starting from 0x41 are AT commands...
const ATPacket: Array[0..11] of String = ('00C20100000008', '00C20100000008','7E00A072557E', '810003', '41545A0D0A', '41542B474D4D0D', '41542B4347534E0D', '41542B53575645523F0D', '41542B50524F44554354434F44453F0D0A', '41542B435042533F0D', '41542B435042533D22534D220D', '41542B435042523D');
Here's a part of procedure to send each packet from chain, and display received stuff as string in memo...
var Str: String;
    i: byte;
    F: String;
begin
if USB.USBOpenDriver then //yea, I'm using oOXTCOo's unit to deal with USB :P
  begin
  Memo1.Lines.Add('Successfully Opened');
  Memo1.Lines.Add('Switching to AT-Mode...');
  Pb.Max:=High(ATPacket); //thats only Progress Bar :D
  for i:=Low(ATPacket) to High(ATPacket) do
      begin
        PB.Position:=i; //increase progress bar position
        Str:=USB.RWUSB(ATPacket[i], 255, 200, 'STRING');
        if Length(Str)>0 then // if got some stuff from phone then...
          Memo1.Lines.Add('#:'+Str);
      end;
  Memo1.Lines.Add('Finished');
The Following User Says Thank You to McManiek For This Useful Post:
Old 05-28-2012, 00:01   #2 (permalink)
Moderator
XcachorroX®'s Avatar
Member: 1159099
Sonork: 100.1592508
Hi McManiek,
how send atcommand with usb VB2008 use comport
        rxBuff = ""
        If SerialPort1.IsOpen = False Then SerialPort1.Open()
        SerialPort1.Write("AT+SW?." & vbCr)
        System.Threading.Thread.Sleep(800)
        If SerialPort1.IsOpen = True Then SerialPort1.Close()
        If rxBuff = "" Then GoTo ends
        RichTextBox1.Text = rxBuff
Regards
Pablo A.
Old 05-29-2012, 03:14   #3 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
close pcstudio and use comport communication..
set baudrate...
try to use this component
ComPort Library | Free Communications software downloads at SourceForge.net
br,
ulymar
The Following User Says Thank You to ulymar For This Useful Post:
Old 05-29-2012, 08:07   #4 (permalink)
Crazy Poster
Member: 776944
Yea, works great now Thanks for interesting
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.30681 seconds with 11 queries
