Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-05-2009, 12:02   #1 (permalink)
Member: 128122
Thanks Meter: 262
Sync Phonebook using OBEX and AT+commands
Hi, i am new here in OBEX and AT commands.(don't want to use any commercial ocx for this time )
I want to start a project which can sync phonebook of my SE W550i using OBEX and AT+commands.
And save or view it in my pc.
How can I send at commands and use obex to do that? Using visual basic 6.
Anyone have a sample codes for that? so i have an idea to start. Thanks!
br,
aybyd
The Following User Says Thank You to dr_aybyd For This Useful Post:
Old 05-05-2009, 12:13   #2 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 763
br,
aybyd
AT+CPBS Phonebook storage
Description: Selects phonebook memory storage <storage>, which is used by other
phonebook commands. If setting fails in a ME error, +CME ERROR: <err>
is returned.
Read command returns currently selected memory and, when supported
by manufacturer, number of used locations and total number of locations
in the memory.
Test command returns supported storage as compound value.
Note: Each one of the defined profiles corresponds to one (and only one)
list of allowed callers.
Set command: AT+CPBS=<storage>[,<password>]
Read command: AT+CPBS? Displays the current <name> setting.
Read command
response: +CPBS: <storage>
Test command: AT+CPBS=? Shows if the command is supported.
Test command
response: +CPBS: (list of supported <storage>s)
AT+CPBR Phonebook read
Description: Returns phonebook entries in location number range <index1>...<index2>
from the current phonebook memory storage selected by AT+CPBS. If
<index2> is left out, only location <index1> is returned. Entry fields returned
are location number <indexn>, phone number <number> (of format <type>)
and text <text> associated with the number.
When the Received Calls list (RC), the Missed Calls list (MC) or the Dialled
Calls list (DC) is selected, the two additional fields <text_date> and
<text_time> containing date and time is returned. In this case the <text>
field containing text associated with the number has to be extracted from
one of the phonebooks (SIM, ME or TA).
Note: Flags are used to indicate the contact field where the number is
stored. See <contact_flag> below.
Set command: AT+CPBR=<index1>[,<index2>]
Set command
response: +CPBR:
<index1>,<number>,<type>,<text>[,<text_date>,<text_time>]<CR><LF>
+CPBR: <index2>,<number>,<type>,<text>[,<text_date>,<text_time>]
Test command: AT+CPBR=? Shows if the command is supported.
Test command
response: +CPBR: (list of supported <index>s),<nlength>,<tlength>.
Good Luck
The Following 2 Users Say Thank You to loca|host For This Useful Post:
Old 05-05-2009, 12:22   #3 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 763
Hope attached file can help
The Following User Says Thank You to loca|host For This Useful Post:
Old 05-05-2009, 12:45   #4 (permalink)
Member: 128122
Thanks Meter: 262
@localhost
do you have any sample in vb6?
Old 05-05-2009, 13:45   #5 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 812
VB6 is a dead language since 2005, try VB .NET (its free!).
All you need is here: Serial Port in VB .NET 2008
Also on that page is serial port example in VB6, but really its better to upgrade to the latest tools
The Following User Says Thank You to Dave.W For This Useful Post:
Sony J7 and AT Commands Lykos1986 Old Ericsson Phones & Sony Phones 2 11-22-2006 08:15
Siemens and AT commands vz x1x to x45/x50 1 09-10-2004 08:10
How to send & read sms using AT commands? HossamSharara GSM Programming & Reverse Engineering 0 04-16-2004 14:59
nokia 8210 and at commands Vocoder Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-18-2001 00:44
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-15-2000 07:35
Page generated in 0.52104 seconds with 9 queries
