GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-13-2016, 05:45 | #1 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2453951 Status: Offline Sonork: tego101 Thanks Meter: 4 | T-Mobile / Metro PCS unlock app MOD I de-compiled the t-mobile unlock .apk to take a look how this app unlocks your device. Apparently the app reaches out to the server and the server returns a flag depending on the flag the application denies or unlocks the device. My thought here is edit the source to return a positive Flag so the app unlocks your device no matter what. Anyone have any experience working with Java that can help me build this quicker? Files h t t p s : / / drive . google .com / file / d / 0B_oJWXRyPW2PRnl2QTNRTGZUOEE / view ? usp = sharing had to space out the link to bypass the post/link rule the forum has. |
The Following User Says Thank You to tego101 For This Useful Post: |
04-15-2016, 02:18 | #5 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1414809 Status: Offline Thanks Meter: 155 | You need to contact idone from idoneapps he might give you info regarding apk files because he made the sprint unlock apk way before anyone else figured out how to unlock sprint phones. |
08-03-2017, 19:12 | #8 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2438620 Status: Offline Thanks Meter: 156 | https://www.androidfilehost.com/?fid=817550096634790368 Apk download. I Really hope you can do something with this!! Good luck |
08-10-2017, 00:32 | #10 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | This part caught my eye... Code: .class public Lcom/tmobile/simlock/TrustletProtocol; .super Ljava/lang/Object; # interfaces .implements Lcom/tmobile/simlock/w; # static fields .field private static final END_TIME_SIZE_BYTES:I = 0x4 .field private static final EXPIRY_TIME_OFFSET_BYTES:I = 0x14c .field private static final HMAC_SIZE_BYTES:I = 0x20 .field private static final IMEI_SIZE_BYTES:I = 0x10 .field private static final MAC_SIZE_BYTES:I = 0x20 .field private static final MILLS_PER_SECOND:I = 0x3e8 .field private static final RESPONSE_MESSAGE_LENGTH_OFFSET:I = 0x2 .field private static final SERVER_ERROR_MESSAGE_LENGTH_OFFSET:I = 0xc .field private static final SERVER_ERROR_MESSAGE_OFFSET:I = 0x10 .field public static final SERVER_URL:Ljava/lang/String; = "https://unlock.t-mobile.com/unlock/unlock" .field private static final SIGNATURE_SIZE_BYTES:I = 0x100 .field private static final SIMLOCK_SETTINGS_LENGTH_BYTES:I = 0x4 .field private static final SIMLOCK_SETTINGS_VERSION_MAJOR_OFFSET:I = 0x0 .field private static final SIMLOCK_SETTINGS_VERSION_MINOR_OFFSET:I = 0x2 .field private static final START_TIME_SIZE_BYTES:I = 0x8 .field private static final TAG:Ljava/lang/String; = null .field private static final UNLOCK_REQUEST_FIXME:I = 0x4 .field private static final UNLOCK_REQUEST_PARTIAL:I = 0x3 .field private static final UNLOCK_REQUEST_PERMANENT:I = 0x2 .field private static final UNLOCK_REQUEST_RESERVED:I = 0x0 .field private static final UNLOCK_REQUEST_TEMPORARY:I = 0x1 .field private static final UNLOCK_SERVER_RESPONSE_TYPE:B = 0x28t .field private static mSimLockJniLoaded:Z # instance fields .field private mHttp:Lcom/tmobile/simlock/n; .field private mLockedUntil:J .field private mRebootRequired:Z .field private mUseAttestation:Z .field private serverMessage:Ljava/lang/String; # direct methods .method static constructor <clinit>()V .locals 2 const-class v0, Lcom/tmobile/simlock/TrustletProtocol; invoke-virtual {v0}, Ljava/lang/Class;->getName()Ljava/lang/String; move-result-object v0 sput-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const/4 v0, 0x0 sput-boolean v0, Lcom/tmobile/simlock/TrustletProtocol;->mSimLockJniLoaded:Z :try_start_0 const-string v0, "simlockjni" invoke-static {v0}, Ljava/lang/System;->loadLibrary(Ljava/lang/String;)V const/4 v0, 0x1 sput-boolean v0, Lcom/tmobile/simlock/TrustletProtocol;->mSimLockJniLoaded:Z :try_end_0 .catch Ljava/lang/UnsatisfiedLinkError; {:try_start_0 .. :try_end_0} :catch_0 :goto_0 return-void :catch_0 move-exception v0 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v1, "Cannot load simlockjni library!" invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V goto :goto_0 .end method .method public constructor <init>(Lcom/tmobile/simlock/n;Landroid/content/SharedPreferences;)V .locals 1 invoke-direct {p0}, Ljava/lang/Object;-><init>()V const/4 v0, 0x0 iput-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z const/4 v0, 0x1 iput-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mUseAttestation:Z iput-object p1, p0, Lcom/tmobile/simlock/TrustletProtocol;->mHttp:Lcom/tmobile/simlock/n; sget-boolean v0, Lcom/tmobile/simlock/TrustletProtocol;->mSimLockJniLoaded:Z if-nez v0, :cond_0 new-instance v0, Ljava/lang/ExceptionInInitializerError; invoke-direct {v0}, Ljava/lang/ExceptionInInitializerError;-><init>()V throw v0 :cond_0 return-void .end method .method private static native createAttestationRequest([B)[B .end method .method private static native createRegisterKeyRequest([B)[B .end method .method private static native createUnlockRequest([BI)[B .end method .method private static native processResponse([B[B)[B .end method .method private static native requestSLBReset()V .end method .method private runProtocol([B)V .locals 12 const/4 v11, 0x1 const/4 v10, 0x0 new-array v1, v11, [B aput-byte v10, v1, v10 :goto_0 if-eqz p1, :cond_5 iget-object v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mHttp:Lcom/tmobile/simlock/n; invoke-virtual {v0, p1}, Lcom/tmobile/simlock/n;->a([B)[B move-result-object v2 aget-byte v0, v2, v10 const/16 v3, 0x28 if-ne v0, v3, :cond_0 invoke-static {v2}, Ljava/nio/ByteBuffer;->wrap([B)Ljava/nio/ByteBuffer; move-result-object v0 sget-object v3, Ljava/nio/ByteOrder;->BIG_ENDIAN:Ljava/nio/ByteOrder; invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->order(Ljava/nio/ByteOrder;)Ljava/nio/ByteBuffer; const/4 v3, 0x2 invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->getShort(I)S move-result v3 sget-object v4, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v5, Ljava/lang/StringBuilder; invoke-direct {v5}, Ljava/lang/StringBuilder;-><init>()V const-string v6, "lenOfMessage: " invoke-virtual {v5, v6}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v5 invoke-virtual {v5, v3}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder; move-result-object v5 invoke-virtual {v5}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v5 invoke-static {v4, v5}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V const/16 v4, 0xc invoke-virtual {v0, v4}, Ljava/nio/ByteBuffer;->getInt(I)I move-result v4 sget-object v5, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v6, Ljava/lang/StringBuilder; invoke-direct {v6}, Ljava/lang/StringBuilder;-><init>()V const-string v7, "lenOfServerError: " invoke-virtual {v6, v7}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v6 invoke-virtual {v6, v4}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder; move-result-object v6 invoke-virtual {v6}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v6 invoke-static {v5, v6}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V add-int/lit8 v4, v4, 0x10 add-int/lit8 v4, v4, 0x4 add-int/lit8 v4, v4, 0x2 invoke-virtual {v0, v4}, Ljava/nio/ByteBuffer;->getShort(I)S move-result v4 sget-object v5, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v6, Ljava/lang/StringBuilder; invoke-direct {v6}, Ljava/lang/StringBuilder;-><init>()V const-string v7, "minVersion: " invoke-virtual {v6, v7}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v6 invoke-virtual {v6, v4}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder; move-result-object v6 invoke-virtual {v6}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v6 invoke-static {v5, v6}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V if-nez v4, :cond_4 add-int/lit16 v3, v3, -0x14c invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->position(I)Ljava/nio/Buffer; :goto_1 invoke-virtual {v0}, Ljava/nio/ByteBuffer;->getLong()J move-result-wide v4 invoke-virtual {v0}, Ljava/nio/ByteBuffer;->getInt()I move-result v0 int-to-long v6, v0 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v3, Ljava/lang/StringBuilder; invoke-direct {v3}, Ljava/lang/StringBuilder;-><init>()V const-string v8, "Extracted unlock ending time (milliseconds): " invoke-virtual {v3, v8}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 invoke-virtual {v3, v4, v5}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder; move-result-object v3 const-string v8, " + " invoke-virtual {v3, v8}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 invoke-virtual {v3, v6, v7}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder; move-result-object v3 const-string v8, " seconds" invoke-virtual {v3, v8}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 invoke-virtual {v3}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v3 invoke-static {v0, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V const-wide/16 v8, 0x3e8 mul-long/2addr v6, v8 add-long/2addr v4, v6 iput-wide v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J :cond_0 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v3, "runProtocol: processing the response..." invoke-static {v0, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V invoke-static {v2, v1}, Lcom/tmobile/simlock/TrustletProtocol;->processResponse([B[B)[B move-result-object v0 if-nez v0, :cond_1 sget-object v3, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v4, "runProtocol: processResponse returned null!" invoke-static {v3, v4}, Lcom/tmobile/simlock/s;->b(Ljava/lang/String;Ljava/lang/String;)V :cond_1 aget-byte v2, v2, v10 const/16 v3, 0x3c if-ne v2, v3, :cond_2 if-eqz v0, :cond_2 new-instance v2, Ljava/lang/String; const-string v3, "UTF-8" invoke-static {v3}, Ljava/nio/charset/Charset;->forName(Ljava/lang/String;)Ljava/nio/charset/Charset; move-result-object v3 invoke-direct {v2, v0, v3}, Ljava/lang/String;-><init>([BLjava/nio/charset/Charset;)V iput-object v2, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String; const/4 v0, 0x0 :cond_2 sget-object v2, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v3, Ljava/lang/StringBuilder; invoke-direct {v3}, Ljava/lang/StringBuilder;-><init>()V const-string v4, "Server message: " invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 iget-object v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String; invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 invoke-virtual {v3}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v3 invoke-static {v2, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V aget-byte v2, v1, v10 if-eqz v2, :cond_3 iput-boolean v11, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z :cond_3 sget-object v2, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v3, Ljava/lang/StringBuilder; invoke-direct {v3}, Ljava/lang/StringBuilder;-><init>()V const-string v4, "Need to reboot? " invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v3 iget-boolean v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Z)Ljava/lang/StringBuilder; move-result-object v3 invoke-virtual {v3}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v3 invoke-static {v2, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V move-object p1, v0 goto/16 :goto_0 :cond_4 add-int/lit16 v3, v3, -0x14c add-int/lit8 v3, v3, -0x10 invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->position(I)Ljava/nio/Buffer; goto/16 :goto_1 :cond_5 return-void .end method .method private unlock(ILjava/lang/String;)V .locals 3 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v1, Ljava/lang/StringBuilder; invoke-direct {v1}, Ljava/lang/StringBuilder;-><init>()V const-string v2, "onUnlock called, with unlock type of " invoke-virtual {v1, v2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1, p1}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v1 invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v1, Ljava/lang/StringBuilder; invoke-direct {v1}, Ljava/lang/StringBuilder;-><init>()V const-string v2, "Using IMSI: " invoke-virtual {v1, v2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1, p2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v1 invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V if-eqz p2, :cond_0 invoke-virtual {p2}, Ljava/lang/String;->getBytes()[B move-result-object v0 :goto_0 invoke-static {v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->createUnlockRequest([BI)[B move-result-object v0 invoke-direct {p0, v0}, Lcom/tmobile/simlock/TrustletProtocol;->runProtocol([B)V sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v1, "Succesfully ran the unlock protocol" invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V return-void :cond_0 const/4 v0, 0x0 goto :goto_0 .end method # virtual methods .method public getServerMessage()Ljava/lang/String; .locals 1 iget-object v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String; return-object v0 .end method .method public isRebootRequired()Z .locals 1 iget-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z return v0 .end method .method public partialUnlock(Ljava/lang/String;)V .locals 1 const/4 v0, 0x3 invoke-direct {p0, v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->unlock(ILjava/lang/String;)V return-void .end method .method public permanentUnlock(Ljava/lang/String;)V .locals 1 const/4 v0, 0x2 invoke-direct {p0, v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->unlock(ILjava/lang/String;)V return-void .end method .method public registerKey(Ljava/lang/String;)V .locals 3 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v1, Ljava/lang/StringBuilder; invoke-direct {v1}, Ljava/lang/StringBuilder;-><init>()V const-string v2, "Using IMEI: " invoke-virtual {v1, v2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1, p1}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v1 invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V iget-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mUseAttestation:Z if-eqz v0, :cond_0 if-eqz p1, :cond_1 invoke-virtual {p1}, Ljava/lang/String;->getBytes()[B move-result-object v0 :goto_0 invoke-static {v0}, Lcom/tmobile/simlock/TrustletProtocol;->createAttestationRequest([B)[B move-result-object v0 invoke-direct {p0, v0}, Lcom/tmobile/simlock/TrustletProtocol;->runProtocol([B)V :cond_0 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v1, "Succesfully registered the key" invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V return-void :cond_1 const/4 v0, 0x0 goto :goto_0 .end method .method public resetSLB()V .locals 2 sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; const-string v1, "SLB reset not available" invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V return-void .end method .method public temporaryUnlock(Ljava/lang/String;)J .locals 4 const-wide/16 v0, 0x0 iput-wide v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J const/4 v0, 0x1 invoke-direct {p0, v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->unlock(ILjava/lang/String;)V sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String; new-instance v1, Ljava/lang/StringBuilder; invoke-direct {v1}, Ljava/lang/StringBuilder;-><init>()V const-string v2, "temporaryUnlock: until: " invoke-virtual {v1, v2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder; move-result-object v1 iget-wide v2, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J invoke-virtual {v1, v2, v3}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder; move-result-object v1 invoke-virtual {v1}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String; move-result-object v1 invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V iget-wide v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J return-wide v0 .end method |
08-10-2017, 20:02 | #11 (permalink) |
Junior Member Join Date: May 2017
Member: 2720516 Status: Offline Thanks Meter: 0 | I have the apk for the lg v10 but its a copy of what i tried to decompile and recompile and i did not sign it yet.but you can still read it .i will share the raw tmo sim lock apk when i get hands on the v10 again.for now take a look at this copy of the v10 apk i had saved on my sd card that i was trying to edit. https://drive.google.com/file/d/0B-F...w?usp=drivesdk Also another user has sent me his v20 tmo sim lock apk here https://drive.google.com/file/d/0B5L...ew?usp=sharing Last edited by jass65; 08-10-2017 at 20:07. |
08-16-2017, 15:43 | #13 (permalink) |
Junior Member Join Date: Mar 2007
Member: 466649 Status: Offline Thanks Meter: 0 | Anyone know if there is a similar device unlock for the LG G5 H830 on tmobile?? The device unlock app for the LG G5 H830 on tmobile can be found here. xda-developers T-Mobile LG V10 T-Mobile LG V10 Q&A, Help & Troubleshooting tmobile unlock app hack? by brigantti post 18 |
