Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 04-13-2016, 05:45   #1 (permalink)
Member: 2453951
Sonork: tego101
Thanks Meter: 4
Lightbulb T-Mobile / Metro PCS unlock app MOD
Just wanted to see if this would work before I spent a whole lot of time on something that was not worth the time.
I de-compiled the t-mobile unlock .apk to take a look how this app unlocks your device. Apparently the app reaches out to the server and the server returns a flag depending on the flag the application denies or unlocks the device.
My thought here is edit the source to return a positive Flag so the app unlocks your device no matter what. Anyone have any experience working with Java that can help me build this quicker?
Files h t t p s : / / drive . google .com / file / d / 0B_oJWXRyPW2PRnl2QTNRTGZUOEE / view ? usp = sharing
had to space out the link to bypass the post/link rule the forum has.
The Following User Says Thank You to tego101 For This Useful Post:
Old 04-13-2016, 06:06   #2 (permalink)
Member: 2453951
Sonork: tego101
Thanks Meter: 4
The gold is in C0043m && C0052w
Old 04-15-2016, 01:46   #3 (permalink)
Member: 469257
Thanks Meter: 34
Hi, there´s been any advance in this?
Old 04-15-2016, 02:13   #4 (permalink)
Member: 2453951
Sonork: tego101
Thanks Meter: 4
Nope no one has pitched in
Sent from my SM-N920W8 using Tapatalk
Old 04-15-2016, 02:18   #5 (permalink)
ElBerryKM13's Avatar
Member: 1414809
Thanks Meter: 155
You need to contact idone from idoneapps he might give you info regarding apk files because he made the sprint unlock apk way before anyone else figured out how to unlock sprint phones.
Old 07-18-2017, 04:57   #6 (permalink)
Crazy Poster
Member: 2638916
Thanks Meter: 9
SOrry for pushing an old thread, but did anybody take this further. How does it work ?
Old 08-03-2017, 12:00   #7 (permalink)
Cheater -Don't Deal with him-
Member: 2351344
Thanks Meter: 40
send me the latest version of tmobile app. I will try to decompile and study it .
Old 08-03-2017, 19:12   #8 (permalink)
Member: 2438620
Thanks Meter: 156
https://www.androidfilehost.com/?fid=817550096634790368
Apk download. I Really hope you can do something with this!! Good luck
Old 08-04-2017, 04:53   #9 (permalink)
Member: 2351344
Thanks Meter: 40
I already done for s7 tmobile app. but only work for s7. I already know the flow chart of the tmobile app for s7
Old 08-10-2017, 00:32   #10 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 115
This part caught my eye...
.class public Lcom/tmobile/simlock/TrustletProtocol;
.super Ljava/lang/Object;
# interfaces
.implements Lcom/tmobile/simlock/w;
# static fields
.field private static final END_TIME_SIZE_BYTES:I = 0x4
.field private static final EXPIRY_TIME_OFFSET_BYTES:I = 0x14c
.field private static final HMAC_SIZE_BYTES:I = 0x20
.field private static final IMEI_SIZE_BYTES:I = 0x10
.field private static final MAC_SIZE_BYTES:I = 0x20
.field private static final MILLS_PER_SECOND:I = 0x3e8
.field private static final RESPONSE_MESSAGE_LENGTH_OFFSET:I = 0x2
.field private static final SERVER_ERROR_MESSAGE_LENGTH_OFFSET:I = 0xc
.field private static final SERVER_ERROR_MESSAGE_OFFSET:I = 0x10
.field public static final SERVER_URL:Ljava/lang/String; = "https://unlock.t-mobile.com/unlock/unlock"
.field private static final SIGNATURE_SIZE_BYTES:I = 0x100
.field private static final SIMLOCK_SETTINGS_LENGTH_BYTES:I = 0x4
.field private static final SIMLOCK_SETTINGS_VERSION_MAJOR_OFFSET:I = 0x0
.field private static final SIMLOCK_SETTINGS_VERSION_MINOR_OFFSET:I = 0x2
.field private static final START_TIME_SIZE_BYTES:I = 0x8
.field private static final TAG:Ljava/lang/String; = null
.field private static final UNLOCK_REQUEST_FIXME:I = 0x4
.field private static final UNLOCK_REQUEST_PARTIAL:I = 0x3
.field private static final UNLOCK_REQUEST_PERMANENT:I = 0x2
.field private static final UNLOCK_REQUEST_RESERVED:I = 0x0
.field private static final UNLOCK_REQUEST_TEMPORARY:I = 0x1
.field private static final UNLOCK_SERVER_RESPONSE_TYPE:B = 0x28t
.field private static mSimLockJniLoaded:Z
# instance fields
.field private mHttp:Lcom/tmobile/simlock/n;
.field private mLockedUntil:J
.field private mRebootRequired:Z
.field private mUseAttestation:Z
.field private serverMessage:Ljava/lang/String;
# direct methods
.method static constructor <clinit>()V
    .locals 2
    const-class v0, Lcom/tmobile/simlock/TrustletProtocol;
    invoke-virtual {v0}, Ljava/lang/Class;->getName()Ljava/lang/String;
    move-result-object v0
    sput-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    const/4 v0, 0x0
    sput-boolean v0, Lcom/tmobile/simlock/TrustletProtocol;->mSimLockJniLoaded:Z
    :try_start_0
    const-string v0, "simlockjni"
    invoke-static {v0}, Ljava/lang/System;->loadLibrary(Ljava/lang/String;)V
    const/4 v0, 0x1
    :try_end_0
    .catch Ljava/lang/UnsatisfiedLinkError; {:try_start_0 .. :try_end_0} :catch_0
    :goto_0
    return-void
    :catch_0
    move-exception v0
    sget-object v0, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    const-string v1, "Cannot load simlockjni library!"
    invoke-static {v0, v1}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V
    goto :goto_0
.end method
.method public constructor <init>(Lcom/tmobile/simlock/n;Landroid/content/SharedPreferences;)V
    .locals 1
    invoke-direct {p0}, Ljava/lang/Object;-><init>()V
    const/4 v0, 0x0
    iput-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z
    const/4 v0, 0x1
    iput-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mUseAttestation:Z
    iput-object p1, p0, Lcom/tmobile/simlock/TrustletProtocol;->mHttp:Lcom/tmobile/simlock/n;
    sget-boolean v0, Lcom/tmobile/simlock/TrustletProtocol;->mSimLockJniLoaded:Z
    if-nez v0, :cond_0
    new-instance v0, Ljava/lang/ExceptionInInitializerError;
    invoke-direct {v0}, Ljava/lang/ExceptionInInitializerError;-><init>()V
    throw v0
    :cond_0
    return-void
.end method
.method private static native createAttestationRequest([B)[B
.end method
.method private static native createRegisterKeyRequest([B)[B
.end method
.method private static native createUnlockRequest([BI)[B
.end method
.method private static native processResponse([B[B)[B
.end method
.method private static native requestSLBReset()V
.end method
.method private runProtocol([B)V
    .locals 12
    const/4 v11, 0x1
    const/4 v10, 0x0
    new-array v1, v11, [B
    aput-byte v10, v1, v10
    :goto_0
    if-eqz p1, :cond_5
    iget-object v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mHttp:Lcom/tmobile/simlock/n;
    invoke-virtual {v0, p1}, Lcom/tmobile/simlock/n;->a([B)[B
    move-result-object v2
    aget-byte v0, v2, v10
    const/16 v3, 0x28
    if-ne v0, v3, :cond_0
    invoke-static {v2}, Ljava/nio/ByteBuffer;->wrap([B)Ljava/nio/ByteBuffer;
    sget-object v3, Ljava/nio/ByteOrder;->BIG_ENDIAN:Ljava/nio/ByteOrder;
    invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->order(Ljava/nio/ByteOrder;)Ljava/nio/ByteBuffer;
    const/4 v3, 0x2
    invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->getShort(I)S
    move-result v3
    sget-object v4, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    new-instance v5, Ljava/lang/StringBuilder;
    invoke-direct {v5}, Ljava/lang/StringBuilder;-><init>()V
    const-string v6, "lenOfMessage: "
    invoke-virtual {v5, v6}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    move-result-object v5
    invoke-virtual {v5, v3}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder;
    invoke-virtual {v5}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String;
    invoke-static {v4, v5}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V
    const/16 v4, 0xc
    invoke-virtual {v0, v4}, Ljava/nio/ByteBuffer;->getInt(I)I
    move-result v4
    sget-object v5, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    new-instance v6, Ljava/lang/StringBuilder;
    invoke-direct {v6}, Ljava/lang/StringBuilder;-><init>()V
    const-string v7, "lenOfServerError: "
    invoke-virtual {v6, v7}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    move-result-object v6
    invoke-virtual {v6, v4}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder;
    invoke-virtual {v6}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String;
    invoke-static {v5, v6}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V
    add-int/lit8 v4, v4, 0x10
    add-int/lit8 v4, v4, 0x4
    add-int/lit8 v4, v4, 0x2
    invoke-virtual {v0, v4}, Ljava/nio/ByteBuffer;->getShort(I)S
    move-result v4
    const-string v7, "minVersion: "
    if-nez v4, :cond_4
    add-int/lit16 v3, v3, -0x14c
    invoke-virtual {v0, v3}, Ljava/nio/ByteBuffer;->position(I)Ljava/nio/Buffer;
    :goto_1
    invoke-virtual {v0}, Ljava/nio/ByteBuffer;->getLong()J
    move-result-wide v4
    invoke-virtual {v0}, Ljava/nio/ByteBuffer;->getInt()I
    move-result v0
    int-to-long v6, v0
    new-instance v3, Ljava/lang/StringBuilder;
    invoke-direct {v3}, Ljava/lang/StringBuilder;-><init>()V
    const-string v8, "Extracted unlock ending time (milliseconds): "
    invoke-virtual {v3, v8}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    move-result-object v3
    invoke-virtual {v3, v4, v5}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder;
    const-string v8, " + "
    invoke-virtual {v3, v6, v7}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder;
    const-string v8, " seconds"
    invoke-virtual {v3}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String;
    invoke-static {v0, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V
    const-wide/16 v8, 0x3e8
    mul-long/2addr v6, v8
    add-long/2addr v4, v6
    iput-wide v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J
    :cond_0
    const-string v3, "runProtocol: processing the response..."
    invoke-static {v2, v1}, Lcom/tmobile/simlock/TrustletProtocol;->processResponse([B[B)[B
    if-nez v0, :cond_1
    sget-object v3, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    const-string v4, "runProtocol: processResponse returned null!"
    invoke-static {v3, v4}, Lcom/tmobile/simlock/s;->b(Ljava/lang/String;Ljava/lang/String;)V
    :cond_1
    aget-byte v2, v2, v10
    const/16 v3, 0x3c
    if-ne v2, v3, :cond_2
    if-eqz v0, :cond_2
    new-instance v2, Ljava/lang/String;
    const-string v3, "UTF-8"
    invoke-static {v3}, Ljava/nio/charset/Charset;->forName(Ljava/lang/String;)Ljava/nio/charset/Charset;
    invoke-direct {v2, v0, v3}, Ljava/lang/String;-><init>([BLjava/nio/charset/Charset;)V
    iput-object v2, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String;
    const/4 v0, 0x0
    :cond_2
    sget-object v2, Lcom/tmobile/simlock/TrustletProtocol;->TAG:Ljava/lang/String;
    const-string v4, "Server message: "
    invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    iget-object v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String;
    invoke-static {v2, v3}, Lcom/tmobile/simlock/s;->a(Ljava/lang/String;Ljava/lang/String;)V
    aget-byte v2, v1, v10
    if-eqz v2, :cond_3
    iput-boolean v11, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z
    :cond_3
    const-string v4, "Need to reboot? "
    iget-boolean v4, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z
    invoke-virtual {v3, v4}, Ljava/lang/StringBuilder;->append(Z)Ljava/lang/StringBuilder;
    move-object p1, v0
    goto/16 :goto_0
    :cond_4
    add-int/lit8 v3, v3, -0x10
    goto/16 :goto_1
    :cond_5
    return-void
.end method
.method private unlock(ILjava/lang/String;)V
    .locals 3
    new-instance v1, Ljava/lang/StringBuilder;
    invoke-direct {v1}, Ljava/lang/StringBuilder;-><init>()V
    const-string v2, "onUnlock called, with unlock type of "
    invoke-virtual {v1, v2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    move-result-object v1
    invoke-virtual {v1, p1}, Ljava/lang/StringBuilder;->append(I)Ljava/lang/StringBuilder;
    invoke-virtual {v1}, Ljava/lang/StringBuilder;->toString()Ljava/lang/String;
    const-string v2, "Using IMSI: "
    invoke-virtual {v1, p2}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    if-eqz p2, :cond_0
    invoke-virtual {p2}, Ljava/lang/String;->getBytes()[B
    :goto_0
    invoke-static {v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->createUnlockRequest([BI)[B
    invoke-direct {p0, v0}, Lcom/tmobile/simlock/TrustletProtocol;->runProtocol([B)V
    const-string v1, "Succesfully ran the unlock protocol"
    return-void
    :cond_0
    const/4 v0, 0x0
    goto :goto_0
.end method
# virtual methods
.method public getServerMessage()Ljava/lang/String;
    .locals 1
    iget-object v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->serverMessage:Ljava/lang/String;
    return-object v0
.end method
.method public isRebootRequired()Z
    .locals 1
    iget-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mRebootRequired:Z
    return v0
.end method
.method public partialUnlock(Ljava/lang/String;)V
    .locals 1
    const/4 v0, 0x3
    invoke-direct {p0, v0, p1}, Lcom/tmobile/simlock/TrustletProtocol;->unlock(ILjava/lang/String;)V
    return-void
.end method
.method public permanentUnlock(Ljava/lang/String;)V
    .locals 1
    const/4 v0, 0x2
    return-void
.end method
.method public registerKey(Ljava/lang/String;)V
    .locals 3
    const-string v2, "Using IMEI: "
    invoke-virtual {v1, p1}, Ljava/lang/StringBuilder;->append(Ljava/lang/String;)Ljava/lang/StringBuilder;
    iget-boolean v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mUseAttestation:Z
    if-eqz v0, :cond_0
    if-eqz p1, :cond_1
    invoke-virtual {p1}, Ljava/lang/String;->getBytes()[B
    :goto_0
    invoke-static {v0}, Lcom/tmobile/simlock/TrustletProtocol;->createAttestationRequest([B)[B
    :cond_0
    const-string v1, "Succesfully registered the key"
    return-void
    :cond_1
    const/4 v0, 0x0
    goto :goto_0
.end method
.method public resetSLB()V
    .locals 2
    const-string v1, "SLB reset not available"
    return-void
.end method
.method public temporaryUnlock(Ljava/lang/String;)J
    .locals 4
    const-wide/16 v0, 0x0
    iput-wide v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J
    const/4 v0, 0x1
    const-string v2, "temporaryUnlock: until: "
    iget-wide v2, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J
    invoke-virtual {v1, v2, v3}, Ljava/lang/StringBuilder;->append(J)Ljava/lang/StringBuilder;
    iget-wide v0, p0, Lcom/tmobile/simlock/TrustletProtocol;->mLockedUntil:J
    return-wide v0
.end method
Old 08-10-2017, 20:02   #11 (permalink)
Member: 2720516
I have the apk for the lg v10 but its a copy of what i tried to decompile and recompile and i did not sign it yet.but you can still read it .i will share the raw tmo sim lock apk when i get hands on the v10 again.for now take a look at this copy of the v10 apk i had saved on my sd card that i was trying to edit.
https://drive.google.com/file/d/0B-F...w?usp=drivesdk
Also another user has sent me his v20 tmo sim lock apk here
https://drive.google.com/file/d/0B5L...ew?usp=sharing
Old 08-16-2017, 12:56   #12 (permalink)
Member: 466649
Anyone know if there is a similar device unlock for the LG G5 H830 on tmobile??
Old 08-16-2017, 15:43   #13 (permalink)
Member: 466649
The device unlock app for the LG G5 H830 on tmobile can be found here.
xda-developers T-Mobile LG V10 T-Mobile LG V10 Q&A, Help & Troubleshooting tmobile unlock app hack? by brigantti post 18
Old 08-16-2017, 18:44   #14 (permalink)
Member: 466649
or
https :// forum. xda- developers. com / tmobile -lg -v10/ help/ tmobile- unlock- app- hack -t3506608 / page2
Old 08-16-2017, 18:50   #15 (permalink)
Member: 2102926
Thanks Meter: 6
I haven't seen a post this informative in a while. Ill be willing to donate to who ever figures it out.
The Following User Says Thank You to 2kris33 For This Useful Post:
Page generated in 0.37581 seconds with 8 queries
