Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 06-15-2012, 19:08   #1 (permalink)
oOXTCOo's Avatar
Member: 2878
TRACE32 C166 SIMULATOR -> need some help...
Can someone please be so kind and help me how to get started using TRACE C166 SIMULATOR Tool by Lauterbach?
i whant to simulate a infineon C166 based 4mb flash dump.
but this tool seems very complicated...
if someone could help me to understand that tool, would be realy great for me..
with IDA is not possible to simulate, but with trace32 should be possible.
what i need to set, how i need to load it?
hope some expert can give me some help with that tool...
thanks!
Old 06-16-2012, 08:30   #2 (permalink)
Member: 1723215
Offtopic.
One question. On the infenion's site there are a few software for emulation and debugging:
Emulators/Debugger Development Systems - Infineon Technologies
What is this program TRACE32 better than others?
Old 06-16-2012, 18:10   #3 (permalink)
oOXTCOo's Avatar
Member: 2878
if another tool is able to simulate, i also would be happy..
its mutch more easy when i can simulate instead of static analyze.
so it seems that trace32 simulator is the most advanced tool for that.
so nobody can or whant help?
where are the good old siemens reversers?
Old 06-16-2012, 22:00   #4 (permalink)
Member: 1723215
saw russans forums about siemens. but who cares about it now, only google cach
Old 06-16-2012, 22:23   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Craciing Xgold1 ?
Grab some original KEIl tools maybe.
Old 06-16-2012, 22:44   #6 (permalink)
Moderator
Gecko_UK's Avatar
Member: 961957
Sonork: Jabber: gecko@neko.im
you probably seen these already
https://www.keil.com/demo/eval/c166.htm
TASKING - Embedded software development tools from Altium
The Following User Says Thank You to Gecko_UK For This Useful Post:
Old 06-17-2012, 03:41   #7 (permalink)
oOXTCOo's Avatar
Member: 2878
Originally Posted by karwos View Post
Craciing Xgold1 ?
no... iam not interessted in nokia
i have some cheap ulc2 phones.. direct unlocking is easy.. but i whant to reverse the nck algo..
Old 06-17-2012, 17:47   #8 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
IDA support this CPU 100%
I was reversing Xgold1 Hash encryption - Reversing taking a little more, as this is generally 16-bit CPU, but addressing 24-bit addressing mode (something like 16bit mode on x86, diffrent pointer for data segment, diffrent pointer for 16-bit offset), so usually pointers are passed as two registers.
Example from 1616 RSA Verification routine:
mov [-r0], r15
mov r12, #0Fh ; Verify PKCS1 Header
mov [-r0], r12
mov r12, #0Ah
add r12, r0
and r12, #3FFFh
mov r13, DPP1
mov r14, r9
mov r15, r6
calls 0E5h, memcmp ; r8 - len, r14 r15-src ptr, r12 r13 - dst ptr
add r0, #2
mov r15, [r0+]
cmp r4, #0
jmpr cc_NZ, loc_C747A4
Read about Addressing mode for this CPU.
As far as I remember, addresing also depends of current set DPP, and for example is calculated like:
(R12 * 0x10000) + offset (R13)
but off course addressing varying from call to call. Read C166 docs and you will cleary see diffrence.
BTW - VERY ugly CPU
hope this helps.
The Following 3 Users Say Thank You to karwos For This Useful Post:
Old 06-18-2012, 23:55   #9 (permalink)
zulea's Avatar
Member: 5325
Can use Keil.
BR,
Zulea
The Following User Says Thank You to zulea For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 3.18036 seconds with 11 queries
