GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
05-30-2010, 14:49 | #1 (permalink) |
Junior Member Join Date: May 2010
Member: 1314304 Status: Offline Thanks Meter: 1 | which usb comand to read nokia SL3 security code commnad i used for SL1 and SL2 didnot works .. any idea.. |
The Following User Says Thank You to khim_khim For This Useful Post: |
06-03-2010, 06:36 | #2 (permalink) |
Member: 1314304 Status: Offline Thanks Meter: 1 | some more .. in n97 etc pm field 308 sub field 5 didnot exist .. thats why cant read secrutiy code.. i have made search over all pm fields but couldnot found hint.. any idea masters.. |
06-04-2010, 09:12 | #3 (permalink) |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | if you had N97 on hand without security code and just set your own security code on it, something simple like 98765 then you should look for something like 39383736353 or any value=x x9x8x7x6x5x and then you would find it. Other easier way is if you take that N97, perform full fbus flash and full factory set after flash the security code would be reset or erased, read all pm values after flash before turn phone on, then read all pm values after phone is on for first time then again , create your own security code and read full pm again and compare all pm values betwen files. Good luck |
06-05-2010, 20:46 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Pm file are normal text file, not hex file. Use text mode or notepad for search code. |
The Following User Says Thank You to bananin For This Useful Post: |
06-06-2010, 01:59 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | SL3 have special command? Funny. Look on 6303 - SL3, but have code on same field. Comand for reading? It is just read field and nothing more. All new SmartPhones have decrypted or hidden field for code. |
06-06-2010, 08:51 | #9 (permalink) | |
Member: 1314304 Status: Offline Thanks Meter: 1 | Quote:
i know for 6303 and 6700 etc they are same bec they have 308 sub field 5 present... how to Code: All new SmartPhones have decrypted or hidden field for code how to get this one. | |
06-07-2010, 10:31 | #11 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Bucharest Romania Age: 40
Member: 8530 Status: Offline Sonork: 100.1601224 Thanks Meter: 29 | hi via usb is 1B0010230012000D0004013400050000000000000000000A and the answer from phone is 1B100023001E0D340005000100000000000000180000000A31 3233343500000000000000 sec code is 3132333435=12345 1B100023001E0D340005000100000000000000180000000A39 3939393900000000000000 sec code is 3939393939=99999 |
The Following 4 Users Say Thank You to balanel For This Useful Post: |
06-07-2010, 12:25 | #12 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | About the 3132333435 = 12345 The security code (say 12345), this is in character format. If you find the ascii code of each digit you get like: 0 = 48 1 = 49 2 = 50 4 = 51 etc etc You can look this up in ascii - char tables online or convert in code. Now, bus transmission needs to be in hexadecimal form, so we must find hex equivalent of the ascii code: 48 becomes 0x30 49 becomes 0x31 50 becomes 0x32 etc etc If you can convert dec to hex then this is easy (in software its very simple). Just to say its nothing "magical" just fun*****tal computer stuff The following site hopefully explains all: Ascii Table - ASCII character codes and html, octal, hex and decimal chart conversion |
The Following User Says Thank You to Dave.W For This Useful Post: |
06-07-2010, 13:06 | #13 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
./wbr | |
06-07-2010, 14:40 | #15 (permalink) |
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | don't work with N97 & N86.... after comparing 02 PM's files with 02 different user code, I think the security code is stored in field 308 subfield 1, but I don't know how it's stored ! |
The Following User Says Thank You to angel25dz For This Useful Post: |
