GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-06-2009, 12:38 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: The land of Cyrus The Great Age: 43
Member: 587800 Status: Offline Sonork: 100.1582587 Thanks Meter: 73 | what is the best language for gsm programing? and another question. is vc++ an Obsolete language? I want to start learning . please guide me . which is best for gsm programing? |
09-07-2009, 03:40 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | C++/C#,VB,Delphi (Pascal) ***/disassebler and understand algo for reverse WBR, |
The Following User Says Thank You to boucettay For This Useful Post: |
09-07-2009, 16:26 | #3 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | If your really new, you may like to check out SMALL BASIC Its a new language / concept introduced by Microsoft to get more people working with programming. I had a small mess about with the release and it seemed quite cool! If you feel like a more advanced tool, check out http://www.microsoft.com/express/ where you can download free versions of Visual Basic and Visual C++ (latest dot net versions). Good luck! |
The Following 7 Users Say Thank You to Dave.W For This Useful Post: |
09-07-2009, 19:04 | #4 (permalink) | |
No Life Poster Join Date: Oct 2006
Member: 365730 Status: Offline Thanks Meter: 84 | Quote:
with out that classes the tool is of less use for only students would you share there are how many editions of vc++ and any free edition with mfc classes regards | |
09-08-2009, 12:50 | #5 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | No, VC++ dot net is a very useful tool for students, its the latest technology! There is no MFC because its an old technology. Take VC++ 2008, select new project, select project type: CLR, select template: Windows Form Application, and enjoy! For students, take the CLR console application, its for more "low level", embedded style software. |
The Following 4 Users Say Thank You to Dave.W For This Useful Post: |
09-08-2009, 17:03 | #6 (permalink) | |
09-11-2009, 22:32 | #9 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Hutan
Member: 263378 Status: Offline Thanks Meter: 42 | Assembly, is the core of programming. Not recommended for regular programmer. Hard to maintain. Its easily to learn & understand VisualBasic Dot Net. Pascal/Delphi not very popular these days, may be left in future. This world (of computing) is already belonged to Microsoft, so what to say.......... MS products have better future compatibility. I vote .NET languages. BR HPDebug |
The Following 4 Users Say Thank You to HPDebug For This Useful Post: |
09-16-2009, 04:06 | #10 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: EasyLinks
Member: 520336 Status: Offline Thanks Meter: 50 | Quote:
For the time being delphi is used by SaraSoft, MSTool, PS Tool (products by setool team), Zulea products (i think) Br, | |
09-16-2009, 08:00 | #11 (permalink) |
Registered User Join Date: Jun 2007 Location: Philippines
Member: 528692 Status: Offline Thanks Meter: 65 | you can use any language as long as it will fit to your needs. for server side you can use php, asp and etc.. as long as you can managed it. for win32 application you can use vb, delphi, vb.net, c#, vsc++, borland c++ and even java, But you must consider the security and no problem in deployment of your software. I love to use borland product, can be easily deploy even exe only. no need to install environment or framework . br |
09-16-2009, 08:29 | #12 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1120604 Status: Offline Thanks Meter: 0 | .Net products create what we call "intermediate code". These arent in the "portable executable" (normal .exe) format that is common. Thats why there is this dependency on the .Net framework to be installed on the client computer. Thats one reason why I dont recommend it. (Not easy to port your code then, meaning to make code run on other platforms without much modification.) http://www.bloodshed.net/ - start with that for C++ if you wish. If you directly want to get down and dirty with serial/usb port programming, start with Visual Basic (get the OLD version from somewhere if possible, i.e. 6 or 2005) Get some component/library thats used for serial/usb communication and you`re good to go. If you want to play with RAW data communication with serial/usb devices, to learn how protocols work, use "HyperTerminal" bundled with the Microsoft Windows installation. If I am not wrong, they`ve stopped providing HyperTerminal from Vista onwards. In that case, download Putty - http://www.chiark.greenend.org.uk/~s.../download.html (Its the best in either case ;-)) |
09-16-2009, 08:31 | #13 (permalink) | |
Member: 7653 Status: Offline Thanks Meter: 823 | Quote:
For someone who has done no / little programming before, why start by learning out of date information? Especially when the latest stuff is all there for free, with good support? These threads always run the same way, some people suggest ASM etc and talk about cracking/reversing firmware. Just remember, the original poster has probably never even made some "hello world" application before, creating a commercial unlock solution is a long, long way in the future! | |
The Following 3 Users Say Thank You to Dave.W For This Useful Post: |
09-21-2009, 16:53 | #14 (permalink) |
Insane Poster Join Date: Sep 2009
Member: 1111849 Status: Offline Thanks Meter: 17 | Start with simple C, then CPP, then arm-asm for loaders and ROM binaries. Delphi is for lazy coders :P ps: BASIC the best |
The Following User Says Thank You to kr0m For This Useful Post: |
09-22-2009, 09:14 | #15 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, We have to keep in mind that this world is not only Windows. There is Linux, Mac and also hundreds of embedded devices that run ARM cpus. So the choice is clear: C This is the only platform independent language - code written for Linux can be ported in minutes on Windows or even run on small ARM cpu. About Pascal (Delphi) - the reason is so widely used - many of the GSM programmer are from ex-communist countries - this rubbish(Pascal) was forced on all of us in the UNI (i had to learn Fortan even in high school). There is no other reason for it still being alive. Regarding VB 6.0 and .Net - for me VB 6.0 was good start in programming, but .Net seems to take you into direction you don't want to go. You might as well learn Java and kill yourself. BR, Alex |
The Following 7 Users Say Thank You to Bph&co For This Useful Post: |
What is the best box for LG for Unlock | raulka2003 | Off Topic Zone | 7 | 09-17-2010 04:07 |
What is the best "Unlimited Remote Control" Program..? | LoveLess | Nokia Multimedia | 1 | 10-07-2008 20:33 |
What is the best tool for backing up the original firmware? | CDMA Sucks | Motorola ODM | 3 | 03-29-2008 14:20 |
What is the BEST liquid for ultrasonic cleaner? | GsMen | Hardware Repair by brands | 1 | 04-08-2002 19:21 |
What is the best programmer for use with simscan?? | unlockgod | Sim Cloning and Scaning | 1 | 03-28-2002 22:29 |
