Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 06-07-2008, 15:31   #1 (permalink)
aikonmani's Avatar
Member: 304090
What Is Jtag?-joint Test Action Group-fag
This may be useful for our members.........
1.What is JTAG ?
1.1.Where can I get more info about JTAG?
Future JTAG reading:
Here is a download of a 77-page JTAG tutorial from ASSET InterTech. If you'd like a hardcopy of this book sent to you, go to this page and provide your mailing address. You can find more information on JTAG at the ASSET InterTech website
Link to pdf of tutorial
http://www.asset-intertech.com/pdfs/...orial_2007.pdf
Link to mailing address form
http://www.asset-intertech.com/regis...cfm?lnk=primer
Link from ASSET to more JTAG resources
http://www.asset-intertech.com/bound...leadership.cfm
Also:
http://www.inaccessnetworks.com/proj...tag-intro.html
http://www.engr.udayton.edu/faculty/...tag/jtag1.html
http://www.circuitcellar.com/library...99/c109r12.asp
AVR specific
http://www.circuitcellar.com/library...d143/index.htm
Boundary-Scan Tutorial
http://www.ezytech.com/asset/pdfs/bo...n_tutorial.pdf
Very good repository of JTAG references:
http://uclinux.home.at ( got to "JTAGS" directory)
1.2.May I use JTAG interface for remote debugging?
YES , of course – it is what JTAG for!
Sometimes different terms are used, as following:
  • OCD ( On Circuit Debugger)
  • ICE (In Circuit Emulator)
  • BDM (Background Debug Mode)
Future reading
http://www.ocdemon.net/zenofbdm.pdf
1.3.May I use JTAG interface for FLASH memory programming?
1.4.What part of JTAG standard is CPU agnostic?
JTAG specification is in Std IEEE 1149.1 (costs about $100). I don't
have it. Please search at internet for some JTAG related documents.
This is good: http://www-s.ti.com/sc/psheets/ssya002c/ssya002c.pdf
JTAG state machine [insert here]
JTAG standard signal [insert here]
That's all! You just have to write software to go through the states of JTAG FSM (here is the state diagram of this FSM: http://www.inaccessnetworks.com/proj...hine-large.png). TCK and TMS are used to go through the states of FSM. And TDI is used to serially send through this interface your commands and data to JTAG controller on the IC (in your case, to the ARM uC) and read back reply through the TDO pin. The only problem is that some companies do not open all details about available custom JTAG commands (JTAG standard defines only 2 necessary commands: EXTEST and SAMPLE and some optional commmands like INTEST, BIST and others). For example, Texas Instruments do not give an access to the description of commands that are used for In-Circuit Debugging of their TMS DSPs. Instead of, they sell this JTAG ICD with simple software for about 1000$!!! Nice business - such a price for 4 wires and some I/O ICs! ;-)
1.5.What CPUs architectures have a build-in JTAG support?
AVR060: JTAG ICE Communication Protocol for 8-bit AVR Microcontrolers
http://www.atmel.com/atmel/acrobat/doc2524.pdf
ATmega128:JTAG Interface and On-chip Debug System, Page 245 to 272
http://www.atmel.com/atmel/acrobat/doc2467.pdf
Schematics for High-Speed BDM Pod for the Coldfire CPU
http://www.fortunecity.com/campus/ps...93/bdm/bdm.htm
ARM7TDMI build in ICE (see Chapter 5 and Appendix B)
http://www.arm.com/pdfs/DDI0210B_7TDMI_R4.pdf
1.6.JTAG support for ARM architecture?
1.7.What is a usual JTAG header pin-out?
More pin-outs see at http://www.ocdemon.net/pinouts.pdf
1.7.1.14-pin JTAG header
Usual pin-out for 14-pin JTAG header (often used for ARM)
1 -Vddh (+3.3v)
2 - Vss (ground)
3 - nTRST
4 - Vss (ground)
5 - TDI
6 -Vss (ground)
7 - TMS
8 -Vss (ground)
9 - TCK
10-Vss (ground)
11- TDO
12-nRESET (optional)
13- Vddh (+3.3v)
14-Vss (ground)
1.7.2.20-pin JTAG header
Usual pin-out for 20-pin JTAG header (sometimes used for ARM)
1 - Vddh (+3.3v)
2 - Vddh (+3.3v)
3 - nTRST
4-Vss (ground)
5 - TDI
6-Vss (ground)
7 - TMS
8-Vss (ground)
9 - TCK
10-Vss (ground)
11 --------
12-Vss (ground)
13 –TDO
14-Vss (ground)
15 – nRST
16-Vss (ground)
17---------
18-Vss (ground)
19---------
20-Vss (ground)
1.7.3.8-pin JTAG header
Usual pin-out for 8-pin JTAG header, often used for PLD programming
1 – vddh (+3.3v)
2 – TDO
3 – TDI
4 – nTRST
5
6 – TMS
7 – vss (ground)
8 – TCK
2.What hardware do I need to connect to the JTAG interface?
2.1.Where to buy JTAG adapter?
JTAG adapter can be purchased from multiple sources. Many embedded OS companies ( WindRiver and similar) are offering JTAG adapters with their debuggers and other testing software. Unfortunately, these packages are very expensive – usually a few thousand dollars.
Following companies have more or less reasonable product offerings
(Disclaimer: author(s) of this chapter have no direct commercial interest whatsoever in following companies.(Note: please do an appropriate disclaimer for new submissions if otherwise ))
2.1.1.Macraigor Systems LLS
Macraigor Systems (http://www.ocdemon.net/) is known as a vendor of reasonably inexpensive JTAG solutions. Their Wiggler ( $150) parallel port adapter became de-facto a standard for a simple buffered JTAG adapters. Due its simplicity , Macraigor Wiggler is easily cloned by home-made JTAGs ( see more in “How to build JTAG” section)
Macraigor Systems is offered a FLASH programming software ( $500), a free simple On-Chip-Debugger (OCD Commander - http://www.ocdemon.net/ocd_dbgr.exe ) and a free LibRemote daemon for interfacing GDB/Insight remote debuggers ( see CYGWIN version at http://www.ocdemon.com/Windows98NT/A...stallation.exe ).
2.1.2.AZ-Electronics
AZ_Electronics (http://az-electronics.com/item9.htm ) is offering a cheap ( $35) parallel port JTAG adapter.
2.1.3.JtagConnection
JtagConnection (http://www.jtagconnection.com/index.php) is offering a cheap ( $35-40) parallel port JTAG adapter.
2.1.4.Rowley Associates
Rowley Associates introduce its CrossConnect – USB 1.1 fast JTAG adapter with retail price of about £150.
http://www.rowley.co.uk/
2.1.5.Amontec
Amontec sells a very nice programmable JTAG dongle, the Chameleon POD.
It can be programmed as Macraigor Wiggler or Raven.
http://www.amontec.com/chameleon.shtml
2.2.How to build JTAG adapter?
http://www.lart.tudelft.nl/projects/..._schematic.pdf
http://www.lart.tudelft.nl/projects/jtag/
2.2.1.Macraigor Wiggler compatible JTAG adapters
http://jtag-arm9.sourceforge.net/circuit.txt
http://bh.udev.org/filez/wireless/sa...510-ver0.2.pdf
2.2.2.LART JTAG
http://www.lart.tudelft.nl/projects/..._Rev_X1.tar.gz (Gerber file )
2.2.3.Xilinx JTAG
http://www.plis.ru/pic/zip/JTAG_cable.pdf
A simplified non-buffered version may be found at http://axl.freeyellow.com/iPAQ/jtag.htm . Please note that not-buffered JTAG adapter has an increased posibility to damage your host’s parallel port circuit.
2.2.4.ALTERA JTAG
ALTERA ByteBlast Parallel Port Adaptor
http://www.altera.com/literature/ds/dsbyte.pdf
2.2.5.ColdFire BDM Pod
I've made by myself an High-Speed BDM Pod for the Coldfire CPU, i've
found the schematics at
2.2.6.Serial Jtag
http://mspgcc.sourceforge.net/jtagF14x.pdf
http://cvs.sourceforge.net/viewcvs.py/mspgcc/jtag/
http://mspgcc.sourceforge.net/manual...html#pyserjtag
3.What software do I need to use JTAG for remote debugging?
3.1.OCD Commander
3.2.LibRemote for GDB
How to use LibRemote for ARM under CYGWIN environment:
  • TBD
  • TBD
  • TBD
  • TBD
4.What software do I need for FLASH memory programming?
4.1.Intel JFlash
Original Intel program for memory flash for SA1110 dev board. Contains source for Windows utility JFlash.
http://www.intel.com/design/strong/s...ashKit_V12.exe
Works with LART JTAG parallel port adapter (see above).
4.2.JFlash for linux
As a part of LART project, this is a Linux port of Intel JFlash utility.
http://www.lart.tudelft.nl/projects/...h-linux.tar.gz
Some modifications and corrections from TuxScreen hacking project
http://cvs.sourceforge.net/viewcvs.py/tuxscreen/jflash/
5.Open Source JTAG Software Projects
5.1.ARMTOOL from MIDORI distribution
Erwin Authried <eauth at softsys.co.at> is maintaining Embedded Linux & uClinux distribution (MIDORI distribution - http://cvs.home.at/midori/ ) . ARMTOOL is a small, but important utility in this distribution (some part of the source).
ARMTOOL (http://cvs.home.at/midori/sources/armtool/) is a very simple JTAG monitor that supports upload and download a binary image into memory and its execution. ARMTOOL is ARM7TDMI specific (some part of code is derived from GDBICE project), but may work with some of ARM9 cores (to be tested). Current version supports JTAG adapters compatible with Macgraigor Wiggler, Altera ByteBlasterMV and Xilinx Parallel port JTAG adapter.
In addition to ARMTOOL, MIDORI distribution includes patch for GDB/Insight debugger to use JTAG interface for remote debugging.
Also, BOOTLOADER module contain a simple ARM program which maybe used for flashing a new image into FLASH memory ( FLASHPROG).
5.1.1.HOWTO compile ARMTOOL
(outside of full MIDORI source tree)
http://hri.sourceforge.net/tools/armtool.html
Petr Novak wrote a patch that extends armtool capabilities: patch README (updated 20/Jan/2004)
5.1.2.HOWTO compile FLASHPROG
5.1.3.HOWTO compile GDB/Insight
5.2.GDBICE
GDBICE (http://sourceforge.net/projects/gdbice/) is and open source SW/HW project by Ramon Longo <rlongo at users.sourceforge.net>. It is an attempt to design JTAG remote debugging for ARM7TDMI cores. Unfortunately, this project was not pass above an initial “proof-of-concept” implementation and not supported anymore.
However, this project’s source code maybe useful for someone who need a crash introduction into JTAG and its ARM specifics.
5.3.JTAG from OpenWinCE
http://openwince.sourceforge.net/jtag/
by Marcel Telka <marcel@telka.sk>
5.4.JTAG-ARM9
by Simon Wood <simon@mungewell.org>
5.5.FreeICE
http://savannah.nongnu.org/projects/freeice
by Armand ten Doesschate a.doesschate@hccnet.nl
5.6.Ascensit JTAG for ARM7TDMI
http://www.ascensit.com/developers/atmel_eb55/main.php3
by Ascensit
by Christian Pellegrin <chri@ascensit.com>
5.7.JTAGER
http://jtager.sourceforge.net/
5.8.IANJTAG
http://www.inaccessnetworks.com/projects/ianjtag
May be related to the FreeIce
Old 06-07-2008, 17:55   #2 (permalink)
.::skybird::.'s Avatar
Member: 594884
thanks allot bro its really useful post
keep it up
br
.::skybird::.
The Following User Says Thank You to .::skybird::. For This Useful Post:
Old 06-10-2008, 13:04   #3 (permalink)
aikonmani's Avatar
Member: 304090
Somthing About Firmware ,flash,flash Memory
FIRMWARE>
n. Executable software that is stored within a ROM.
USAGE: This term is interchangeable with embedded software and sometimes is used even when the executable is not stored in ROM.
FLASH>
1. v. To download new firmware into a flash memory. A bootloader typically facilitates this process by communicating with a program on the host, erasing the flash memory, and writing the new code. The sector of the flash memory that contains the bootloader's code must not be overwritten in the process.
FLASH MEMORY>
n. A RAM-ROM hybrid that can be erased and rewritten under software control. Abbreviated flash. Flash is an in-circuit programmable nonvolatile memory segmented into blocks called sectors. Each sector can be individually erased, then the data within it rewritten. Flash memory is common in systems that require nonvolatile data storage at very low cost. In some cases, a large flash device can be used instead of a disk drive. Although there is a theoretical limit to the number of times a flash memory can be erased and rewritten successfully, this limit is seldom reached in practice.
The Following 4 Users Say Thank You to aikonmani For This Useful Post:
Old 06-24-2008, 14:27   #4 (permalink)
Crazy Poster
Member: 152989
Check out OpebOCD for those interested in open source free JTAG debugging tools
http://openocd.berlios.de/web/
The Following 2 Users Say Thank You to ben_whiteus For This Useful Post:
Old 08-14-2008, 17:48   #5 (permalink)
g-gabber's Avatar
Member: 192652
Sonork: No
You forgot something ,
Here is the Original Post http://hri.sourceforge.net/tools/jtag_faq_org.html
By Stas Khirman < staskh at users.sourceforge.net>
The Following User Says Thank You to g-gabber For This Useful Post:
Old 09-04-2008, 20:10   #6 (permalink)
aikonmani's Avatar
Member: 304090
Microcontroller Tutorial
Here is a very useful link ...You should Read It....
The Following User Says Thank You to aikonmani For This Useful Post:
Old 09-04-2008, 20:24   #7 (permalink)
aikonmani's Avatar
Member: 304090
A microcontroller is an IC that runs program code that you write, to do what you want it to. This can be based upon inputs, or simply do a task only. It will have inputs and outputs at your disposal, and maybe a few neat features you can take advantage of.
The basic idea of a microcontroller is that it’s a mini computer. It has a CPU that decodes instructions and carries them out. Some come with memory that you use like a clipboard. They also come with an ALU (Arithmetic Logic Unit) to do basic math functions and logic functions. Each microcontroller will have its own set of instructions to create your code with.
The Following 3 Users Say Thank You to aikonmani For This Useful Post:
Old 11-14-2008, 08:47   #8 (permalink)
Member: 900367
Additional JTAG and debugging information and tools: http://www.xverve.com
Hope you'll find it useful.
The Following User Says Thank You to xverve For This Useful Post:
Old 11-14-2008, 19:03   #9 (permalink)
Member: 288615
many thanks friend.... also do u have any good information about nokia dct4 upp ..like datasheets,bootloader and external command code ???
The Following User Says Thank You to Alfaromio For This Useful Post:
Old 02-24-2009, 15:45   #10 (permalink)
Member: 838770
Need new help
I'VE F500 SAMSUNG AND I FLASH IT WITH "[VISTA]U-Medic_v1[1].3.3.exe" PROGRAM .AT FIRST PHONE WAS ON AND WITH SIMCARD RESTARTED.BUT I CHANGE BOOT AREA MISTAKE AND ERORR HAPENING AND THEN NEVER PHONE BE BOOT WITH(4KEY +POWER KEY)AND NOT CONNECTED FOR FLASH AND PHONE COMPLATLY OFF.I HEAR JUST "JTAG"CAN HELP ME .CAN U SIR HELP ME OR GUID ME OR ANY THING.... .WITH TNX MASTER.
The Following User Says Thank You to mehdi1978 For This Useful Post:
Old 10-23-2009, 22:23   #11 (permalink)
Crazy Poster
Member: 1147468
tnx guys For this Nice topic
Old 01-17-2010, 06:09   #12 (permalink)
king_of_rajasthan's Avatar
Member: 227647
Sonork: 100.1603662
thanks Mr.aikonmani
but 1 thing i wanna know is how to calculate the on borad pinout for jatag
1 – vddh (+3.3v)
2 – TDO
3 – TDI
4 – nTRST
5
6 – TMS
7 – vss (ground)
8 – TCK
how to calculae these pinout
only 1 thing vss ( ground ) is every new bie knows but how to calculate other pinouts on phones pcb
Old 01-17-2010, 10:18   #13 (permalink)
Dave.W's Avatar
Member: 7653
Find the data sheet for your processor, inside there will be JTAG pinout.
Old 01-20-2010, 03:22   #14 (permalink)
Crazy Poster
Member: 152989
And if you don't have the datasheet for the processor, you can try jtag finder. Have a look at http://www.elinux.org/JTAG_Finder for more info.
Old 01-22-2010, 10:36   #15 (permalink)
Member: 227647
Sonork: 100.1603662
dear thanks for reply but the most important thing is " i dont wanna buy jtagfinder "
i wanna kno the way by which the jtag finder is working
i wanna know how to calculate by multi-meter
The Following User Says Thank You to king_of_rajasthan For This Useful Post:
What is the Self Test waqasmalik HWK 2 06-16-2007 16:22
What is version new Test Point SX1? controllerz E-Gold Based Phones 1 07-14-2005 22:46
Reflowing - what it is? (dry joints?) slider27 Hardware Repair by brands 4 06-26-2003 08:25
What is JTAG ??? Mitya Hardware Equipments for GSM 1 01-31-2003 22:52
What is the DSP test for on the B-phreaks stuff? Lonegunman Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 03-10-2002 23:41
Page generated in 0.49272 seconds with 12 queries
