GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
03-18-2010, 04:32 | #31 (permalink) |
Junior Member Join Date: Oct 2004 Location: Thailand. Tel.+66868618833 Age: 69
Member: 85366 Status: Offline Thanks Meter: 17 | Wiggler Then I purchased Banyan-U ARM debugger interface from China (from Mr. Jason) and used it for 5 years as a debugger and flash memory programmer tool. This is really a great product, I enjoyed using it very much. I also used DigiView logic analyzer to debug JTAG communications between the target board and the JTAG interface. It cost me nearly $400.- including the shipping cost. It is working perfectly but now Mr. Jason is no longer updating this excellent product any more. So it has become a bit outdated and I had no choice other than migrating to J-Link. J-Link is an excellent product I believe, however the new JLink.EXE version 4.12 is not without some bugs. If you feel that something is wrong you have to restart this program and continue your work Last edited by De Fault; 03-18-2010 at 04:41. |
03-18-2010, 04:51 | #32 (permalink) |
Member: 85366 Status: Offline Thanks Meter: 17 | Debugging JTAG communications with logic analyzer We can debug JTAG communications between the target board and the JTAG interface with the help of a logic analyzer. I am using DigiView logic analyzer. |
The Following User Says Thank You to De Fault For This Useful Post: |
01-22-2011, 10:49 | #33 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Rajasthan Age: 41
Member: 227647 Status: Offline Sonork: 100.1603662 Thanks Meter: 311 | If you can't find the jtag pinouts for your phone model,you have to find it by yourself.It is also easy,not difficult. For example: We know a CPU whose jtag pinouts are like as below. AA14 - NTRST P11 - TMS Y13 - TCK N11 - RTCK AD19 - RST_n AC16 - TDI Y14 - TDO OK,you can desolder the CPU from the phone board firstly.Then look for where its AA14,P11,Y13,N11,AD19,AC16,Y14 are connected to by multimeter.You will get the right jtag pinouts for this model in this way.When you find it,you can solder the CPU back to the phone board. |
01-22-2011, 10:52 | #34 (permalink) | |
Member: 227647 Status: Offline Sonork: 100.1603662 Thanks Meter: 311 | Quote:
& here is the way ........... If you can't find the jtag pinouts for your phone model,you have to find it by yourself.It is also easy,not difficult. For example: We know a CPU whose jtag pinouts are like as below. AA14 - NTRST P11 - TMS Y13 - TCK N11 - RTCK AD19 - RST_n AC16 - TDI Y14 - TDO OK,you can desolder the CPU from the phone board firstly.Then look for where its AA14,P11,Y13,N11,AD19,AC16,Y14 are connected to by multimeter.You will get the right jtag pinouts for this model in this way.When you find it,you can solder the CPU back to the phone board. | |
01-22-2011, 11:33 | #35 (permalink) |
Junior Member Join Date: Dec 2004 Age: 40
Member: 101829 Status: Offline Thanks Meter: 0 | Does someone know which is the good software for J-link to deal with Qualcomm series ( internal and external memory) except PSAS (QMAT)? I ask for that coz I'm working with MSM6290 but PSAS does not support that kind of CPU. Thanks in advance. |
02-15-2011, 11:52 | #36 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Points/Wires Basic Info
VCC Power - Supplies VCC (5 V, 10 mA, typically) to the cable. To target system VCC GND Ground - Supplies ground reference to the cable. To target system ground TCK Test Clock - Drives the test logic for all devices on a JTAG chain. Connect to system TCK pin. TDO Test Data Output - data from the target system is read at this pin. Connect to system TDO pin. TDI Test Data Input - this signal is used to transmit serial test instructions and data. Connect to system TDI pin. TMS Test Mode Select - this signal is decoded by the JTAG state machine to control test operations. Connect to system TMS pin. Note TRST is an optional pin in the JTAG (IEEE 1149.1) specification, and is not used by XC9500 CPLDs. If any of your non-Xilinx parts have a TRST pin, the pin should be connected to VCC. |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
02-15-2011, 11:55 | #37 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | What is PS_HOLD ? What is PS_HOLD ? The idea is If you can’t keep phone powered on PS_HOLD will do it for you PS_HOLD is a Test Point that designed to keep cpu powered up while supplying a battery power . Some Power Management IC’s are not able to hold dead handsets powered up and it affects operating while JTAGGing them that’s why they have PS_HOLD Points It is required to make PS_HOLD Connection if it is exist on the pcb just to make sure everything will be stable while you are repairing the phone There is another way to keep the phone up is : Keep pressing the power button ! How to use : Dead Qualcomm handsets sometimes require PS_HOLD Connection on the board and purpose of this powering up the phone’s cpu by force Basic connection is connecting PS_HOLD to VBAT with a resistor . What is the Value of resistor that you should use : Since VBAT Source differs on different phones which average is 3.6V to 4.2V we should use something between 1K and 4.7K Source : Master Manual in support area! My question is Can you tell me if something you do not understand , or will that be better if i make PS_HOLD connections with pictures ? VREF is Voltage displayed top of the software shows some voltage values . |
03-11-2011, 22:18 | #38 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | What DCC is What DCC is.... Digital Command Control ...... READ MORE.....FROM HERE... DCC Tutorial (Basic System) - DCCWiki |
10-31-2011, 08:47 | #41 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | here are some info a4 cpu inside iphone 4 Apple A4 - Wikipedia, the free encyclopedia a5 cpu inside iphone 4s & ipad 2 Apple A5 - Wikipedia, the free encyclopedia also for iphone 4 baseband processor XMM 6180 - The iPhone Wiki and iphone 4s baseband processor MDM6610 - The iPhone Wiki hope this can help to develop jtag solution |
10-11-2012, 16:18 | #42 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Colombia Age: 48
Member: 197360 Status: Offline Thanks Meter: 25 | boot, dump and firmware well, another side of the coin, at less in mobile phones are bootloader, dumps and firmwares. teams make work for technicians so easy (i have ort jtag), but do you know tutos about how can we make our full flash, firms and boot-loaders? |
What is the Self Test | waqasmalik | HWK | 2 | 06-16-2007 16:22 |
What is version new Test Point SX1? | controllerz | E-Gold Based Phones | 1 | 07-14-2005 22:46 |
Reflowing - what it is? (dry joints?) | slider27 | Hardware Repair by brands | 4 | 06-26-2003 08:25 |
What is JTAG ??? | Mitya | Hardware Equipments for GSM | 1 | 01-31-2003 23:52 |
What is the DSP test for on the B-phreaks stuff? | Lonegunman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-11-2002 00:41 |
