Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-03-2013, 07:48   #1 (permalink)
Member: 1888105
Thanks Meter: 11
WIMAX TUT BM622i / BM622 spoonfeed na
una sa lahat ito natutunan ko lang sa iba, di ako ang gumawa nito.
kaya ibahagi ko rin sa inyo..
getting admin pass for 2011 bm622
1. dl putty here Putty
2. Open nyo yung putty nyo tapos lagay nyo sa host 192.168.1.1 sa port naman 22, yung connection type dapat SSH, then click Open
Login as : Firefly <enter>
[email protected]'s password: $P4mb1h1r4N4m4nT0!! <enter>
Server refused to allocate pty
ATP> shell <enter>
shell
# cd var <enter>
cd var
# cat curcfg.xml <enter>
3. may lalabas na maraming text sa window ng putty nyo, copy nyo lang lahat yun, pinaka mabilis e i right click nyo ung title bar ng putty nyo tapos me makikita kayong Copy All to Clipboard i click nyo lang yon.
4. open kayo ng notepad then i paste nyo ung na copy nyong text then Find nyo ung "Admin" use F3 sa notepad then lagay nyo sa Find What ay Admin then click Find Next be sure na nasa i taas ang cursor nyo para ma search from the beginning to the end hehehehe...
5. ganto makikita nyo dapat
X_ATP_UserInfoInstance InstanceID="1" Username="admin" Userpassword="samplepassword123"
6. wag masyado exited hindi pa yan ang password nyo dahil naka encyrpt yan, i paste nyo d2 yung admin password na nakuha nyo at try natin i decrypt..
7. may nakita akong decoder sa internet just use this site to decode your password Welcome to OpinionatedGeek :: Part of the solution piliin nyo basecode 64
TUT For CHINGING MAC FOR BM622 2011 and 2012 package date
1st. Plug your modem
2nd. Open BM622_2011.exe and click start to get admin pass.
3rd. Copy decoded admin password from bM622_2011.exe
4th. Open Browser and type 192.168.1.1
5th. login.. Uername: admin password: decoded password frm BM622_2011.exe
6th. Go to Advance/ACL check the Box in the left side of telnet and apply.
close browser.
7th. click start/run and type telnet 192.168.1.1 enter
8th. Login:Firefly enter. Password:$P4mb1h1r4N4m4nT0!! enter
note: pag type nyo ng password wala kayong makikita
pero tuloy mo lang, o kaya copy paste nalang para mas simple.
9th. ATP>xiugai allmacdizhi xx:xx:xx:xx:xx:xx enter. change mac CMD.
note:Yong mga X palitan nyo ng mac address na buhay.
ito yung lalabas pag success ang pag palit nyo ng mac
WAN MAC ADDRESS UPDATE SUCCESS xx:xx:xx:xx:xx:xx
LAN MAC ADDRESS UPDATE SUCCESS xx:xx:xx:xx:xx:xx
10th. ATP>restoredef enter.
hintayin nyo lang mag reboot yung modem.
kung buhay yung mac address mo, after
mag reboot connected na yan
For bm622i package 2011 kung 2010 622i nyo di to gagana mas mabuti upgrade nyo para iwas blank wan na rin, pero kung tut ng 2010 gusto nyu. nasa baba.
Package date 2011 muna
1st po download nyo to...
BM622i_V100R001PHLC08B029PST03.exe
2nd: connect nyo bm622i nyo sa pc
3rd run nyo yung firmware upgrader pero wag nyo po i upgrade..yaan nyo lang nakaopen..
4th. click start/run and type telnet 192.168.254.1 enter
5th. Login:Firefly enter. Password:$P4mb1h1r4N4m4nT0!! enter
6th. ATP>xiugai macdizhi xx:xx:xx:xx:xx:xx enter. change mac CMD.
7th. ATP>diag restore default enter.
for BM622i 2010 ito rin,
click start/run/ type telnet 192.168.254.1
Login:wimax enter
Password:wimax820 enter
note pag type sa password wala kang makita pero patuloy mo lang
ATP>diag set macaddr xx:xx:xx:xx:xx enter ang mga x wag nya gayahin, palitan nyu ng live mac addres
mag reboot modem nyo, kung buhay yung mac na nilagay nyo. ayan connected na kayo
yung iba nilagay nila sa TUT diag reboot,. mali yun kailangan diag restore default para di kana papasok sa admin.
salamat at masaya ako kung makatulong ito sa inyo
uulitin ko di ako ang gumawa ng lahat ng yan, natutunan ko lang yan sa mabuting kaibigan salamat rin sa kanya,
The Following User Says Thank You to quadrosonic3 For This Useful Post:
Old 03-06-2013, 09:12   #2 (permalink)
Jhay-r's Avatar
Member: 109036
Thanks Meter: 56
still no admin password for 2011 package of 622i???
Old 03-06-2013, 09:27   #3 (permalink)
Member: 1888105
Thanks Meter: 11
yes sir, NO
I WANT ALSO TO MAKE ANOTHER THREAD FOR PARTIAL COMMAND FOR BM622M
BUT I HAVE NO PREVLAGE TO ACCES> MAY IM BAND OR WHAT? IM USING MY BM622M NOW CONNECTED USING BM622I MAC ADDRESS
Old 03-10-2013, 17:45   #4 (permalink)
Member: 1888105
Thanks Meter: 11
still no admin sir for BM622i but you can use this method
Login muna as USER
user
0SlO051O
192.168.254.1/html/
Then open tab, eto format after html ilagay nyo ung link na gusto nyong pasukin sa 622i nyo
sample : 192.168.254.1/html//status/internet.asp
Admin_0 = new MenuItem(eval('Status'));
Admin_0_0 = new MenuItem(eval('Device0'));
Admin_0_0_0 = new MenuItem(eval('Device1'),'../status/deviceinfo.asp');
Admin_0_1 = new MenuItem(eval('WAN'));
Admin_0_1_0 = new MenuItem(eval('Status0'),'../status/internetstatus.asp');
Admin_0_2 = new MenuItem(eval('LAN'));
Admin_0_2_0 = new MenuItem(eval('Internet'),'../status/internet.asp');
Admin_0_3 = new MenuItem(eval('VOIP'));
Admin_0_3_0 = new MenuItem(eval('VoIP0'),'../status/voipinfo.asp');
Admin_0_4 = new MenuItem(eval('WiMAX'));
Admin_0_4_0 = new MenuItem(eval('WiMAXStatus'),'../wimax/estate.asp');
Admin_0_4_1 = new MenuItem(eval('ScanInfo'),'../wimax/scanInfo.asp');
Admin_1 = new MenuItem(eval('Basic'));
Admin_1_0 = new MenuItem(eval('WAN'));
Admin_1_0_0 = new MenuItem(eval('WAN'),'../ntwkall/wan.asp');
Admin_1_1 = new MenuItem(eval('LAN'));
Admin_1_1_0 = new MenuItem(eval('DHCP'),'../ntwkall/dhcp.asp');
Admin_1_2 = new MenuItem(eval('VOIP'));
Admin_1_2_0 = new MenuItem(eval('VoIpAccount'),'../voip/sipbasic.asp');
Admin_1_2_1 = new MenuItem(eval('VoIpServer'),'../voip/sipserver.asp');
Admin_1_2_2 = new MenuItem(eval('SpeedDial'),'../voip/sipspeeddial.asp');
Admin_2 = new MenuItem(eval('Advanced'));
Admin_2_0 = new MenuItem(eval('FireWall'));
Admin_2_0_0 = new MenuItem(eval('FireWall'),'../security/firewall.asp');
Admin_2_1 = new MenuItem(eval('NAT'));
Admin_2_1_0 = new MenuItem(eval('ALG'),'../application/alg.asp');
Admin_2_1_1 = new MenuItem(eval('DMZ'),'../application/dmz.asp');
Admin_2_1_2 = new MenuItem(eval('PortMapping'),'../application/portmapping.asp');
Admin_2_1_3 = new MenuItem(eval('PortTrigger'),'../application/porttrigger.asp');
Admin_2_2 = new MenuItem(eval('QoS'));
Admin_2_2_0 = new MenuItem(eval('QoS'),'../network/qos.asp');
Admin_2_3 = new MenuItem(eval('VLAN'));
Admin_2_3_0 = new MenuItem(eval('VLAN'), '../network/vlan.asp');
Admin_2_4 = new MenuItem(eval('SNTP'));
Admin_2_4_0 = new MenuItem(eval('SNTP'),'../ntwkall/sntp.asp');
Admin_2_5 = new MenuItem(eval('CWMP'));
Admin_2_5_0 = new MenuItem(eval('TR069'),'../network/tr069.asp');
Admin_2_6 = new MenuItem(eval('VOIP'));
Admin_2_6_0 = new MenuItem(eval('SipAdvanced'),'../voip/sipadvanced.asp');
Admin_2_6_1 = new MenuItem(eval('VoiceCodec'),'../voip/sipvoicecodec.asp');
Admin_2_6_2 = new MenuItem(eval('Voice'),'../voip/voiceadvanced.asp');
Admin_3 = new MenuItem(eval('Maintain'));
Admin_3_0 = new MenuItem(eval('Device0'));
Admin_3_0_0 = new MenuItem(eval('Reset'),'../management/reset.asp');
Admin_3_0_1 = new MenuItem(eval('Firmware'),'../management/firmware.asp');
Admin_3_1 = new MenuItem(eval('Diagnose'));
Admin_3_1_0 = new MenuItem(eval('Diagnose'),'../management/diagnose.asp');
Admin_3_2 = new MenuItem(eval('LOG'));
Admin_3_2_0 = new MenuItem(eval('LOG'),'../management/logcfg.asp');
Admin_3_2_1 = new MenuItem(eval('LOG0'),'../management/logview.asp');
Admin_4 = new MenuItem(eval('WiMAX'));
Admin_4_0 = new MenuItem(eval('Security'));
Admin_4_0_0 = new MenuItem(eval('Security'),'..//wimax/security.asp');
Admin_4_0_1 = new MenuItem(eval('Certificate'),'../wimax/certificate.asp');
Admin_4_1 = new MenuItem(eval('Scanset'));
Admin_4_1_0 = new MenuItem(eval('Scanset'),'../wimax/scanset.asp');
Admin_5 = new MenuItem(eval('Wizard'),'',false);
Admin_5_0 = new MenuItem(eval('Wizard'),'',false);
Admin_5_0_0 = new MenuItem(eval('Wizard'),'../wizard/wizard.asp');
Admin_6 = new MenuItem(eval('Help'),'',false);
Admin_6_0 = new MenuItem(eval('Help'),'',false);
Admin_6_0_0 = new MenuItem(eval('Help'),'/lang/help_content.html');
ITO ANG PINA KA IMPORTANTE para maka change ng domain sa mga naka VIP MAC ITO:
Connect Frequency
http://192.168.254.1/html///wimax/scanset.asp
NAI, User ID, and Password at Domain
http://192.168.254.1/html///wimax/security.asp
ALG Settings
http://192.168.254.1/html//application/alg.asp
Old 03-14-2013, 18:07   #5 (permalink)
Member: 1900095
try mo na lang kaya yung partial aDmin para sa 622i 2011 para maconfigure mo setting ng wimax mo...tapos Lagyan mo nang ganitong macdo
Old 03-25-2013, 08:29   #6 (permalink)
Jhay-r's Avatar
Member: 109036
Thanks Meter: 56
can you please share me via PM a VIP MAC???
Old 03-18-2014, 00:54   #7 (permalink)
Member: 2147519
Sonork: gellabellin
bm 622m help nmn po wlang mac add yung bm622 ko ok nmn
Old 08-06-2014, 07:00   #8 (permalink)
Member: 1985993
Thanks Meter: 2
mga master pa share nman po mac add fro bm622 need lang po tnx load po kpalit
Page generated in 0.30848 seconds with 7 queries
