GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-05-2015, 02:28 | #1 (permalink) |
Insane Poster Join Date: Mar 2015 Location: USA/AUS
Member: 2356197 Status: Offline Thanks Meter: 13 | Work with Captha for Post Submition or Used API for third party Captcha Solution? if any one can provide the solution or have worked with it we both can end up with mutual benefit COntact me Thanks |
07-13-2015, 17:37 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | I have the same problem with this new RECAPTCHA I can't bypassit This is New Google ReCaptcha "I'm not a robot" More info Here New Google ReCaptcha Last edited by josedavido; 07-13-2015 at 17:45. |
07-13-2015, 17:50 | #4 (permalink) |
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | I'm programming simple software in Vb.Net I load a form on a webbrowser, fill the textbox information and then press submit button but I have 2 problems. 1. Webbrowser object doesn't shows javascript objects (including recaptcha) 2. Even if I show it on my webbrowser I can't bypass it Any light? |
01-11-2016, 01:51 | #9 (permalink) |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | Old lazy way was to relay (proxify) the CAPTCHA to another human user. With static images this was quite easy, about JS-based CAPTCHAs I don't know - however most JS-based CAPTCHAs have a fallback mode for non-JS browsers. You can see this when you try to visit an Cloudflare-CDN'ed site using TOR. Let's say you want to register Gmail/hotmail/blog accounts for spamming (usually)... Make a ****ty free Huawei/whatever calculator, IMEI model verifier, iPhone GSX checker and require the user to complete a CAPTCHA -> Human will solve you this CAPTCHA to use your free service. However it is not your CAPTCHA, but from someone else In the moment that a human user visits your free service, your backend bot will start a new transaction on the CAPTCHA-protected remote service, retrieve the CAPTCHA and wait. A human will solve this to get his free service, and then your backend bot completes it's transaction. |
