Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 12-09-2014, 21:22   #16 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
what have you tried then?
Originally Posted by ecs87 View Post
You can only repair The IMEI on newer devices by AT commands over UART. You might be able to microcom to the UART port through ADB though. I haven't tried it.
Old 12-10-2014, 00:21   #17 (permalink)
Member: 2076039
Thanks Meter: 648
UART. I have absolutely no reason to find an alternative way to send high level at commands.
Old 12-16-2014, 21:58   #18 (permalink)
Member: 2076039
Thanks Meter: 648
So...it appears that CERT writing can be done over "ADB" but it's not really using any specific ADB protocol but rather calling an "app" through ADB and utilizing that app through the shell. It's still using UART, but this nifty app eliminates the need for a UART interface. Sniff the USB port to see what I'm talking about. You should be able to find it relatively easily (under 30 minutes).
On another note (back to the topic at hand: writing the CERT), does anyone know what AT+MEIDAUTH command is for? I'd assume it's to write the MEID to the device seeing as how I didn't see any other MEID related functions in the high-level-UART-AT-commands? If so this is great news for Verizon and Sprint phone owners. Box developers will be able to add this into their programming to repair not only the IMEI but the MEID as well (IMEI+MEID must match in order to pass IMEI CERT on newer Sprint and Verizon CDMA devices).
Old 12-21-2014, 02:27   #19 (permalink)
Member: 1744748
Thanks Meter: 752
This is great information, I still have to research on this stuff... would love to do all through a usb
Old 12-22-2014, 03:24   #20 (permalink)
Member: 975562
Thanks Meter: 46
ecs87 send me mail or facebook
Old 12-22-2014, 22:43   #21 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Im able to send couple of AT Commands over at "Cdma Workshop" but since I have converted all my "certi" files to a z3x format, I would have to wait to able to log into and get some more "AT Cert" logs and try to send the Commands ...
Old 12-22-2014, 23:12   #22 (permalink)
Member: 955311
Thanks Meter: 241
How did u convert cert in z3x format? Can u explain please.
Page generated in 0.15737 seconds with 8 queries
