GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
11-08-2014, 21:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: UNLOCKER SINCE 2003 Age: 42
Member: 249497 Status: Offline Thanks Meter: 180 | write cert samsung using adb thks Br chagua |
11-10-2014, 15:13 | #4 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | You can only repair The IMEI on newer devices by AT commands over UART. You might be able to microcom to the UART port through ADB though. I haven't tried it. |
The Following User Says Thank You to ecs87 For This Useful Post: |
11-25-2014, 22:44 | #7 (permalink) | |
Freak Poster Join Date: May 2007 Location: somewhere in space
Member: 505345 Status: Offline Thanks Meter: 11 | Quote:
Hello Sir, Thanks in advance, would you explain more, like which new devices, sony,samsung,htc, which commands and setup i would wish to learn a few tricks | |
11-26-2014, 00:29 | #8 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I only have experience with Samsung and LG phones. What I posted above applies to devices Note 3 and newer. @dest and I have had an extensive conversation in this section under the Note 3 IMEI repair thread. All the information needed is in that thread. |
12-06-2014, 21:21 | #15 (permalink) |
Insane Poster Join Date: Oct 2009 Location: INN da STREETZ of LA
Member: 1138172 Status: Offline Thanks Meter: 5 | At over uart commands I was provided with few AT commands to be used through UART for use with SERVICE BOX(spt/z3x)... the problem I am having is converting .CERTS(n910t) format for signing in AT format, as I successfully written & signed IMEI/CERTS on a g900t due to a FILE already being converted... Any help??? is there a topic on this where i can get schematics... from what ive been researching SPT has files that have been converted as SUPER IMEI= CERT+ IMEI. THANKS |
