Acer Acer Phones Allegro Betouch E100 Betouch E101 Betouch E200 Betouch E110 Betouch E120 Betouch E210 Betouch E130 Betouch E140 Betouch E400 Betouch T500 CloudMobile S500 DX 900 Dx 650 F900 liquid E Liquid Liquid S1 Liquid E2 Liquid Z2 Liquid C1 Liquid E1 Liquid Z110 Liquid Gallant E350 Liquid Gallent Duo Liquid Glow E330 Liquid express E320 Liquid mini E310 liquid MT Iconia Smart M 900 NeoTouch NeoTouch P400 Neotouch p300 stream X960 Acer Tablets Iconia Tab A100 Iconia Tab A101 Iconia Tab A110 Iconia Tab A1-810 Iconia Tab A200 Iconia Tab A210 Iconia Tab A211 Iconia Tab A501 Iconia Tab A510 Iconia Tab A511 Iconia Tab A700 Iconia Tab A701 |
09-02-2016, 15:46 | #1 (permalink) |
Major Poster Join Date: Aug 2016 Location: Loading.........
Member: 2609092 Status: Offline Sonork: 233 Thanks Meter: 23 | Acer S200 hard reset If your screen is not responding to stylus input: Hold the Volume up and Volume down buttons while pressing reset until the screen shows “Clean Boot”. Resetting your Acer S200 smartphone You may have to perform a reset if your smartphone fails to respond when buttons are pressed or the screen is tapped. Note: Before performing a reset, ensure that your smartphone is not locked. Press any key or tap the screen to see if the phone responds. Reset A reset will clear the RAM of your smartphone. It is similar to turning a computer off and then turning it back on. Important: To reduce risking damage to your smartphone, only use the supplied stylus to reset the device. Use the tip of your stylus to lightly press the Reset button inside the hole on the side of your smartphone. Clean boot Warning! You should only perform a clean boot when all other reset options have failed to restore your smartphone to an operational state. A clean boot will restore your smartphone to the state it was when you got it from the factory. Warning! This will erase all your personal information, any contacts stored on your smartphone and any programs you installed. If your screen is responding to stylus input: Go to Start > Utilities > Default Settings. Read the warning information and enter the security code in the empty textbox. Tap OK to proceed. Acer S200 hard reset using buttons / keys If your screen is not responding to stylus input: Hold the Volume up and Volume down buttons while pressing reset until the screen shows “Clean Boot”. |
The Following User Says Thank You to shadrack1998 For This Useful Post: |
