Acer Acer Phones Allegro Betouch E100 Betouch E101 Betouch E200 Betouch E110 Betouch E120 Betouch E210 Betouch E130 Betouch E140 Betouch E400 Betouch T500 CloudMobile S500 DX 900 Dx 650 F900 liquid E Liquid Liquid S1 Liquid E2 Liquid Z2 Liquid C1 Liquid E1 Liquid Z110 Liquid Gallant E350 Liquid Gallent Duo Liquid Glow E330 Liquid express E320 Liquid mini E310 liquid MT Iconia Smart M 900 NeoTouch NeoTouch P400 Neotouch p300 stream X960 Acer Tablets Iconia Tab A100 Iconia Tab A101 Iconia Tab A110 Iconia Tab A1-810 Iconia Tab A200 Iconia Tab A210 Iconia Tab A211 Iconia Tab A501 Iconia Tab A510 Iconia Tab A511 Iconia Tab A700 Iconia Tab A701 |
01-28-2014, 05:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | How To Acer E300 hard reset You may have to perform a reset if the device freezes (i.e., device no longer responds to the buttons on the screen). A soft reset allows your device to get a fresh start, similar to rebooting a computer. This will restart your device and adjust memory allocation. All records and entries are retained after a soft reset. GPS settings are also retained. To perform a soft reset: Hold the device securely; then press the soft reset button on the right side of your device. erforming a soft reset will not clear the RAM in the unit. To perform a hard reset: Hold the device securely; press and hold the power button and then press the soft reset button on the right side of your device. Performing a hard reset will clear the RAM in the unit and reset the GPS of the unit. Loading the factory default settings If you still encounter system errors even after soft and hard resetting the device, load the factory default settings to correct the error. These default settings have been selected to optimize your device’s performance. To load the factory default settings: 1. Tap “Settings” on the Main Menu panel. 2. Tap “Misc.” on the Settings panel. 3. Tap “Back to Factory Default” on the Misc. screen. 4. Tap “OK” on the dialog box. 5. After the factory reset, reconfigure your device’s user preferences. Performing a factory default will erase the RAM, reset the GPS and erase all the user/application data on the unit’s Flash disc. The data on the SD card will not be erased |
The Following User Says Thank You to Sukh007 For This Useful Post: |
