How to do a hard reset on acer e400? what is the manipulation to make a hard reset on acer e400? in fact the phone is locked to the scheme. thank you in advance |
anyone knows how to hard reset? |
For Reset (normal) The Reset button is found under your smartphone’s battery cover, next to the SIM slot. Press this with a stylus. Hard Reset Open Settings from the Applications tab, then tap Privacy > Factory data reset Click Reset phone and then Erase everything to format your phone. You can See this: http://forum.xda-developers.com/showthread.php?t=813460 Regards Haicha |
salam |
Fastboot : power+volup Download : power+camera recovery : power+voldown+camera or power+vol down Regards Haicha |
You can try Recover. recovery : power+voldown+camera or power+vol down you need to turn the device off, first than use the key combination Or try Fstboot Regards Haicha |
i need this file but i can not find this file its done download patch file Download extract it u will get update file don't extract that file just copy in SD CARD press camera+search button+on/off now handset will format and install the file http://forum.gsmhosting.com/vbb/f606/acer-e400-1309314/ |
1 Download 2 Select Smartphone 3 Select Liquid 4 Select Liquid E 5 Select Op System in Tab 6 Download File If your Phone have Android 2,2 I can upload File. Salam Haicha |
Acer E400 Google Lock Done by Fastboot : power+volup Quote:
its work for me by Fastboot : power+volup After fastboot connect with pc and install any ADB Driver then. Download Fastboot software and Open with CMD and Do Command as : fastboot -w fastboot reboot Done. Thanks |
Greetings to u all, pls hw cn I do hard reset on my acer e400 |
100% tested Solution. its work for me by Fastboot : power+volup After fastboot connect with pc and install any ADB Driver then. Download Fastboot software and Open with CMD and Do Command as : fastboot -w fastboot reboot Done. Thanks |
