Acer Acer Phones Allegro Betouch E100 Betouch E101 Betouch E200 Betouch E110 Betouch E120 Betouch E210 Betouch E130 Betouch E140 Betouch E400 Betouch T500 CloudMobile S500 DX 900 Dx 650 F900 liquid E Liquid Liquid S1 Liquid E2 Liquid Z2 Liquid C1 Liquid E1 Liquid Z110 Liquid Gallant E350 Liquid Gallent Duo Liquid Glow E330 Liquid express E320 Liquid mini E310 liquid MT Iconia Smart M 900 NeoTouch NeoTouch P400 Neotouch p300 stream X960 Acer Tablets Iconia Tab A100 Iconia Tab A101 Iconia Tab A110 Iconia Tab A1-810 Iconia Tab A200 Iconia Tab A210 Iconia Tab A211 Iconia Tab A501 Iconia Tab A510 Iconia Tab A511 Iconia Tab A700 Iconia Tab A701 |
07-21-2011, 01:21 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Hello Brother! For Reset (normal) The Reset button is found under your smartphone’s battery cover, next to the SIM slot. Press this with a stylus. Hard Reset Open Settings from the Applications tab, then tap Privacy > Factory data reset Click Reset phone and then Erase everything to format your phone. You can See this: http://forum.xda-developers.com/showthread.php?t=813460 Regards Haicha |
07-21-2011, 01:23 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
salam | |
07-21-2011, 01:28 | #6 (permalink) | |
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
You can try Recover. recovery : power+voldown+camera or power+vol down you need to turn the device off, first than use the key combination Or try Fstboot Regards Haicha Last edited by Haicha; 07-21-2011 at 01:35. | |
07-21-2011, 01:35 | #7 (permalink) | |
i need this file but i can not find this file its done download patch file Download extract it u will get update file don't extract that file just copy in SD CARD press camera+search button+on/off now handset will format and install the file http://forum.gsmhosting.com/vbb/f606/acer-e400-1309314/ | |
07-21-2011, 01:40 | #8 (permalink) | |
1 Download 2 Select Smartphone 3 Select Liquid 4 Select Liquid E 5 Select Op System in Tab 6 Download File If your Phone have Android 2,2 I can upload File. Salam Haicha Last edited by Haicha; 07-21-2011 at 01:45. | |
04-10-2014, 20:08 | #9 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Acer E400 Google Lock Done by Fastboot : power+volup Quote:
its work for me by Fastboot : power+volup After fastboot connect with pc and install any ADB Driver then. Download Fastboot software and Open with CMD and Do Command as : fastboot -w fastboot reboot Done. Thanks | |
The Following User Says Thank You to razib143 For This Useful Post: |
06-20-2014, 10:58 | #11 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | 100% tested Solution. its work for me by Fastboot : power+volup After fastboot connect with pc and install any ADB Driver then. Download Fastboot software and Open with CMD and Do Command as : fastboot -w fastboot reboot Done. Thanks |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
