Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Development and Modding
Old 10-08-2015, 21:22   #1 (permalink)
Member: 180148
Thanks Meter: 48
G900p BOOST to G900P Sprint
Hi guys do you know how i can convert BOOST firmware to SPRINT on G900P ?
Thank you !!!
Old 10-08-2015, 23:34   #2 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Flash Sprint firmware ...
Old 10-08-2015, 23:52   #3 (permalink)
Member: 180148
Thanks Meter: 48
Hi Jusmejose, i tried to do that but is the same ... my idea is on BOOST firmware there is no option to automatic or GSM network. and i did unlock but ... no network
Old 10-08-2015, 23:54   #4 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
flash "twrp" and wipe completely the Boostmobile OS and flash Sprint firmware ...
Old 10-09-2015, 22:49   #5 (permalink)
Member: 180148
Thanks Meter: 48
The same ... i wipe all stuff but the same may be i need 4 Files firmware if someone has it PLS Share
Old 10-11-2015, 23:30   #6 (permalink)
Member: 1228709
Thanks Meter: 268
Did you try to read SPC
After that, ##786# select reset and enter the SPC readed?
This reset phone and enable gsm mode
The Following User Says Thank You to JorgeVla For This Useful Post:
Old 10-12-2015, 01:19   #7 (permalink)
Member: 1025079
Thanks Meter: 311
You don't need to flash to sprint, I have done boost just do what above its mantion ##786# if it does not work first time try it again.
Old 10-21-2015, 12:01   #8 (permalink)
Fatalfury's Avatar
Member: 810122
Thanks Meter: 65
SOLUTION****** I noticed on boost phones APN is gone and no selection for GSM.. **SAMSUNG ONLY**
SOLUTION IS HERE....
1. Root phone
2. Install Root Explorer
3. Change write permission R/O in root Explorer
4. in root explorer navigate to...
5. efs .. IMEI .. MPS ... Select Text Editor
6. you will see 3 letters SPR is Sprint BST is Boost if want sprint change 3 letters to SPR
7. Save
reboot then do Factory Reset APN and baseband will be open for GSM unlock Plus sprint boot logo will show instead of Boost
Enjoy...
Page generated in 0.18561 seconds with 9 queries
