[GUIDE] Basic adb/shell commands for noobs Basic adb/shell commands for noobs Here is a list of some of the adb and terminal command I have used it Android frequently. I found that I was always having to look up these commands so I figured I would start keeping track of the common ones in case they can help anyone else. If any of these needs corrections or if you have a good one to add please post it. Note, I type "cd C:\Android" to get to my Android folder before doing these commands in the command prompt in windows. That way when I do things like pull apps they end up in "C:\Android\apps", same thing if I want to send I file to my phone I throw it in my Android folder and send it to the phone from there. Through ADB Pull apps off phone onto computer Code: adb pull /system/sd/app app Code: adb push app /system/sd/app Code: adb shell rm -r /system/sd/app Partition SD card - This erases everything on your SD card (*size* being the size of the FAT32 partition) Code: $ su From the Recovery Screen Sending an update file to your SD card: Code: adb shell mount /sdcard Restoring a nandroid backup - Start command-prompt/terminal cd to the nandroid folder and enter following commands Code: fastboot erase boot |
Good work, but add other commands too like for fastboot and mmpeg Sent from my Nexus S using Tapatalk 2 |
bro help me ... i connect my android mobile and command in command prompt but it says that the given syntax is invalid and could not find the prompt ... thanks before ... explain me from first and gave me drivers for android ..thanks |
Now download the latest adb version And in the folder where you downloaded the adb and the other two files, shift+right click and select open command window Now you can use the adb commands once you connected your device You can find all the adb files in my devhost : http://d-h.st/vhZ Now it will be done DONT FORGET TO THANK ME MAN ?!!! Sent from my Nexus S using Tapatalk 2 |
is there any way to put in donwload mode using adb commands? thanks |
I can get the command prompt but my phone is dead so I need to find a way to get my PC to 'talk' to it somehow. |
it's important comands for adb Thanks you. |
use this command to put samsung handset normal to download mode. |
nice Guide. Bro try to add more |
i want to flash ny nokia 3 (TA-1032) with adb commands but its not getting recovery and fastboot mode plz help me seniors |
need qualcomm 9008 mode commands and mtk metamode commands |
Great work. You should add some more stuff about it! |
may paraan ba para maformat yung android gamit ang adb command? |
PLEASE POST Some Fastboot cmds with oem functions |
