Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Development and Modding
Old 07-05-2013, 11:50   #1 (permalink)
Member: 7805
Thanks Meter: 179
[GUIDE] Basic adb/shell commands for noobs
Here is a list of some of the adb and terminal command I have used it Android frequently. I found that I was always having to look up these commands so I figured I would start keeping track of the common ones in case they can help anyone else. If any of these needs corrections or if you have a good one to add please post it.
Note, I type "cd C:\Android" to get to my Android folder before doing these commands in the command prompt in windows. That way when I do things like pull apps they end up in "C:\Android\apps", same thing if I want to send I file to my phone I throw it in my Android folder and send it to the phone from there.
Through ADB
Pull apps off phone onto computer
adb pull /system/sd/app app
adb pull /system/sd/app-private app-private
Push apps back to phone from the computer
adb push app /system/sd/app
adb push app-private /system/sd/app-private
Delete existing apps on SD
adb shell rm -r /system/sd/app
adb shell rm -r /system/sd/app-private
Through Terminal
Partition SD card - This erases everything on your SD card (*size* being the size of the FAT32 partition)
$  su
# cd /data
# wget http://64.105.21.209/bin/lib/droid/sdsplit
# chmod 555 sdsplit
# /data/sdsplit -fs *size* (add -nc to the end for JFv1.5ADP)
From the Recovery Screen
Sending an update file to your SD card:
adb shell mount /sdcard
adb shell rm /sdcard/update.zip
adb push *filename* /sdcard/update.zip
From Fastboot
Restoring a nandroid backup - Start command-prompt/terminal cd to the nandroid folder and enter following commands
fastboot erase boot
fastboot erase recovery
fastboot flash system system.img
fastboot flash boot boot.img
fastboot flash userdata data.img
fastboot flash recovery recovery.img
fastboot reboot
The Following 15 Users Say Thank You to drozd For This Useful Post:
Old 08-31-2013, 19:24   #2 (permalink)
Member: 2011296
Thanks Meter: 12
Good work, but add other commands too like for fastboot and mmpeg
Sent from my Nexus S using Tapatalk 2
The Following User Says Thank You to protox 109 For This Useful Post:
Old 09-24-2013, 15:49   #3 (permalink)
Member: 1966092
Sonork: 100.1647263
Thanks Meter: 6
bro help me ... i connect my android mobile and command in command prompt but it says that the given syntax is invalid and could not find the prompt ... thanks before ... explain me from first and gave me drivers for android ..thanks
The Following User Says Thank You to praveen26 For This Useful Post:
Old 10-01-2013, 17:21   #4 (permalink)
Member: 2011296
Thanks Meter: 12
Firstly u need drivers for your device (google it)
Now download the latest adb version
And in the folder where you downloaded the adb and the other two files, shift+right click and select open command window
Now you can use the adb commands once you connected your device
You can find all the adb files in my devhost :
http://d-h.st/vhZ
Now it will be done
DONT FORGET TO THANK ME MAN ?!!!
The Following 5 Users Say Thank You to protox 109 For This Useful Post:
Old 02-06-2014, 16:56   #5 (permalink)
Member: 711770
Thanks Meter: 2
is there any way to put in donwload mode using adb commands? thanks
Old 05-04-2014, 19:20   #6 (permalink)
Member: 2179598
I can get the command prompt but my phone is dead so I need to find a way to get my PC to 'talk' to it somehow.
Old 05-19-2014, 13:33   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,449
For "to talk" in you Samsung Dead, (not write model), cannot via adb command but only via Jtag or Boot Card if you are lucky and is Sw problem...
The Following User Says Thank You to allumts For This Useful Post:
Old 01-16-2018, 09:28   #8 (permalink)
Member: 2741086
Sonork: mribraqdbra
Thanks Meter: 18
it's important comands for adb Thanks you.
Old 01-20-2018, 06:01   #9 (permalink)
Member: 12302
Thanks Meter: 22
adb reboot download
use this command to put samsung handset normal to download mode.
The Following User Says Thank You to gopidas For This Useful Post:
Old 02-03-2018, 10:46   #10 (permalink)
Member: 2741405
nice Guide. Bro try to add more
The Following User Says Thank You to rajpatel26 For This Useful Post:
Old 05-09-2018, 14:24   #11 (permalink)
Member: 2334147
Sonork: 100.1680702
Thanks Meter: 2
i want to flash ny nokia 3 (TA-1032) with adb commands but its not getting recovery and fastboot mode plz help me seniors
The Following User Says Thank You to Muhammad43 For This Useful Post:
Old 11-06-2018, 17:34   #12 (permalink)
Member: 2401939
Thanks Meter: 537
need qualcomm 9008 mode commands and mtk metamode commands
The Following User Says Thank You to owais a For This Useful Post:
Old 01-08-2019, 10:58   #13 (permalink)
Member: 2886968
Great work. You should add some more stuff about it!
The Following User Says Thank You to [email protected] For This Useful Post:
Old 02-13-2019, 18:54   #14 (permalink)
Member: 2894881
may paraan ba para maformat yung android gamit ang adb command?
Old 07-14-2019, 17:14   #15 (permalink)
Member: 1945974
Thanks Meter: 10
PLEASE POST Some Fastboot cmds with oem functions
Page generated in 0.35388 seconds with 7 queries
