02-02-2014, 09:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | how to delete root ringtones from micromax from /system/media/ i root and install root file manager.it show as DELETED. but when restart phone it comes again.need help android masters. regards |
02-13-2014, 13:34 | #2 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1730478 Status: Offline Sonork: sahil_gsm Thanks Meter: 0 | hi friends how to update samsung tab2 p3100 with 4.4 how to Installing Flashing Android 4.4.2 Kitkat on Galaxy tab 2.7.0 p3100 regads... noor mohammad Last edited by sahil_791; 02-13-2014 at 13:40. |
03-03-2014, 20:47 | #3 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2138218 Status: Offline Thanks Meter: 2 | make sure when you delete the files that system is mounted as read/write enabled. also you can edit the build prop is system/build. prop using notepad ++ or root explorer on the phone and look for the default ringtone and change it from there. |
03-16-2014, 15:42 | #4 (permalink) |
Member: 2148510 Status: Offline Sonork: QQ 61587005 Thanks Meter: 0 | make sure when you delete the files that system is mounted as read/write enabled. also you can edit the build prop is system/build. prop using notepad ++ or root explorer on the phone and look for the default ringtone and change it from there. |
