09-08-2014, 07:28 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: India, Albania, Europe Age: 42
Member: 776103 Status: Offline Sonork: 100.1596478 Thanks Meter: 169 | Increase your Android Phone RAM using Memory Card RAM is a very essential part of any electronic machine that works on a software based platform and helps you achieve many things. Well normally high end devices come with a good amount of RAM that sufficient to play latest games and do more stuff. Well but if you unluckily went for the budget phone then you might be struggling with the lower RAM issues. Well today I will be showing you how you can easily convert your SD Card into phone RAM hence increasing your speed. So now this whole process includes few technical stuff, so I recommend that you sit aside and concentrate on this post step by step to get further insight. #1. Check if you phone supports Swapping or Not ? Well the first step is to check if you phone supports swapping or not. So your phone must support the swap function else its not possible. Well you can download any swap check application, well check here. #2. Partitioning your SD Card (Memory Card) Well now you have checked that your phone supports the swap function, we are going to partition your SD Card, so for this you need few tools check steps below.
After your phone's SD Card partitioning is done, now its time to install an App for actually rooting your phone.
Well now everything is done quiet accurately, its time to increase your smartphone RAM, well lets see how its going to be done.
Well there is another alternative but easier solution for expanding your android smartphone RAM using a paid application.
The Following User Says Thank You to rezwan_jack For This Useful Post: |
09-08-2014, 07:38 | #2 (permalink) |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | any body Done this plz share which phone do by this method can possible with Ace s5830 |
The Following User Says Thank You to Sukh007 For This Useful Post: |
