01-17-2014, 04:31 | #1 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 693436 Status: Offline Thanks Meter: 72 | MTK Droid Tools Open the self-extracting archive of the MTK Droid ROOT and Tools and open the MTKdroidTools.exe be sure to run it as an Administrator,plug in your phone and be sure you have already root your phone and have installed the Driver for your phone, if not do that first before proceeding on the next step. Once you have open the MTK Droid Root and Tools it must detect the information of your Device similar with the Image below Once it has detected your phone information you will notice Your IMEI will show there but if you have error it will not show there and we will use this tool to restore it. Next you need to click the ROOT button so that it will temporary have Root shell access on your phone in order for it to make the script work on the background. it will prompt this window to gain root shell access and then once you have the root shell access click the IMEI/NVRAM button and this window will show now all you need to do is put your 15 Digits IMEI Number that you can get at the back of your phone inside not the back cover if you have 2 IMEI you need to put that. also in case you want to backup your IMEI you do it also here after restoring it, Usually you do this first before you flash any custom roms just to be safe always and then Press the REPLACE IMEI button and it will prompt you this window that it will replace your existing one after that just reboot your phone and your IMEI is back after the reboot , and be sure to backup your IMEI now before doing anything else Mtk_Android2.4.3 |
The Following 4 Users Say Thank You to elpop20102006 For This Useful Post: |
01-19-2014, 14:52 | #2 (permalink) |
Insane Poster Join Date: Nov 2011
Member: 1691037 Status: Offline Thanks Meter: 6 | link download MTKDroidTools 2.4.8 - Ge.tt |
01-19-2014, 15:04 | #3 (permalink) |
Junior Member Join Date: May 2013
Member: 1934582 Status: Offline Thanks Meter: 6 | DepositFiles new version 2.5.2 |
01-19-2014, 18:12 | #4 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1261483 Status: Offline Sonork: 100.1644685 Thanks Meter: 124 | Here Is 4shared new version 2.5.2 link........... MtkDroidTools_v2.5.2_Full Guide - Download - 4shared - Mc.Manik hosain |
