10-07-2013, 12:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | [Root][CWM RECOVERY] ROOT and CWM Recovery For GIONEE E6 ROOT:- * Install framaroot .apk * select super su * click on Boromir * and reboot .... its Rooted CWM RECOVERY:- *Copy Recovery to root of internal storage *Install Mobile Uncle from Play store *Select Recovery Update From Storage *Reboot To Recovery ........ to boot into recovery just switch off phone and power it on while pressing volume + key .. Download Link for files:- https://mega.co.nz/#!jxJ1RC6I!SnA7rl...BC5R3EnibHqbfY |
The Following User Says Thank You to Javajohn For This Useful Post: |
10-24-2014, 10:14 | #7 (permalink) |
Junior Member Join Date: Jun 2013 Location: IN Site Unlocking Databass
Member: 1960977 Status: Offline Sonork: [email protected] Thanks Meter: 2 | off phone and turn on it while holding volume + button |
The Following User Says Thank You to (:.UNLOCK.ME.:) For This Useful Post: |
11-08-2014, 11:46 | #8 (permalink) |
Junior Member Join Date: Nov 2014 Location: Ireland
Member: 2287802 Status: Offline Thanks Meter: 0 | Hi, please do you in anyway have idea on how to fix my china android phone, I made a mistake when a message display on the phone screen that the internal SD card of the phone is bad ,and the phone message advise if I want to format it, I didn't read the message well but I thought it was the External SD card the message display was referring to and I format it ,now the phone won't allow me to boot into the operating system but it allowed me to reboot to the recovery but the touch screen stop responding so I can do factory reset, any idea of solution to this problem? Thanks... |
11-12-2015, 10:05 | #13 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2485541 Status: Offline Thanks Meter: 0 | CM flare S3 hanging logo can you give me some idea how to fix my phone problem i can't use my phone it start when there is android upgrading appeare to my phone till then i did not use my phone.... |
11-28-2015, 07:05 | #14 (permalink) |
Junior Member Join Date: Mar 2008 Location: London, United Kingdom
Member: 735806 Status: Offline Thanks Meter: 3 | The way in which one would enter recovery mode on a Gionee device is usually a universal operation. Please try turning off your device, reboot by holding the Volume Down + Power buttons together and keep pressing the two buttons until the new menu appears on your devices display. Now scroll using the Volume Up key and highlight the recovery mode from the menu. Once highlighted, confirm it with the Power button. Cheers. |
The Following User Says Thank You to unlesh For This Useful Post: |
11-28-2015, 07:24 | #15 (permalink) |
Member: 735806 Status: Offline Thanks Meter: 3 | You need to access the recovery mode on your device and take the hard reset or factory reset option. To do that, first turn off your Gionee device, then reboot by holding the Volume Up + Power buttons. Keep holding those keys until the Android logo appears and then let go. Press the Power button down for 3 seconds and your device will be in recovery mode. Now navigate to the factory reset option. Note: when you reset the device this way you are wiping all data. You need to backup your data before doing this. |
