Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Development and Modding
Old 10-01-2018, 05:06   #1 (permalink)
Member: 2844140
Thanks Meter: 2
What Is Magisk Manager and What Is It Used For
Magisk is the latest magic mask to modify the system invisibly
Index
  • What Is Magisk
  • Magisk System Requirments
  • Download Magisk
  • Install Magisk Manager App
What Is Magisk
Since most of Android features have been secured with Google’s SafetyNet system Magisk has become more popular than ever. With Magisk, users are able to have root and custom mods while the Google Pay services are being used. It works without system partition and modifying the boot partition. Therefore magisk is called as a “systemless” root method. It’s very easy to install and only require a few components. The Magisk Manager APK which can be used with Magisk is a very useful application to Root all the Android smart devices without any effect.
Before using the Magisk manager, the Magisk framework must be installed first.Magsik only requires a few requirements to be installed.
  • A device running Android 5.0+
  • Custom Recovery
Note: In this guide, TWRP recovery has been used
Download Magisk
  • Transfer the Magisk zip file to the Android phone or tablet
  • Boot the device into recovery mode
  • Find the folder where the Zip file is downloaded
  • Select the zip file
  • Swipe the slider to install Magisk
  • Tap Reboot System and reboot
After the Magisk framework is installed Magisk manager Apk is needed to manage it.Magisk Manager is the application that allows you to install modules
  • Enable “Unknown sources” on the device by Settings
  • Install the app and Open it
Uses
  • Allows to Adjust root settings
  • Installs MODs
  • Extend the functionality of Androids
Actually, the Magisk manager APK is the important part of all the procedure. Because it lets the users get more benefits of the rooting method.
Verifying Rooting
To verify everything is fine,
  • Open the Magisk Manager app
  • Check if there is a bunch of green check marks in the app
  • If so the rooting is successful
Checking Google’s SafetyNet
After doing everything it is essential to check if the device passes the Google’s SafetyNet check. Because SafetyNet blocks apps like Google Pay from working when the system is altered. In that case, Magisk works without the touching system. Let's check
  • Select the “Tap to start SafetyNet Check” button
  • Then two green checkmarks will be displayed under the button
  • It means the device has passed the check
Currently, the procedure going on like this. But the Google will occasionally restrict this by updates, but the Magisk developer will release fixes when that happens and be alert to catch the newly released Magisk updates.
The Following User Says Thank You to Alex express For This Useful Post:
Page generated in 0.11455 seconds with 8 queries
