Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax > Micromax Hardware Repair
Old 04-17-2014, 06:50   #1 (permalink)
iqbalhasan62's Avatar
Member: 1807464
Thanks Meter: 35
Micromax x455 calling after lcd light off how Need solution
Micromaxx455 calling in light off?
phone fullflash but problem not solve
what's the problem help me please
Old 04-17-2014, 06:58   #2 (permalink)
abid jan's Avatar
Member: 1991257
Sonork: 100.1641038
Thanks Meter: 78
bro chek sensor r tuch ur problem salove
The Following User Says Thank You to abid jan For This Useful Post:
Old 04-17-2014, 06:58   #3 (permalink)
Member: 505752
Sonork: 1611502:zubair
Thanks Meter: 33
Asslamualikum
brother your problem is in hardware its a sensor problem
change your mobile phone sensor your problem solved 10000 %
The Following User Says Thank You to musa_bahi For This Useful Post:
Old 04-17-2014, 10:24   #4 (permalink)
Member: 1354113
Thanks Meter: 669
bro it is sensor problem first clean sensor or replace 1000000000% working
The Following User Says Thank You to kumar008 For This Useful Post:
Old 04-17-2014, 10:25   #5 (permalink)
Member: 1354113
Thanks Meter: 669
Micromax A110 Hard Reset
  • Press and Hold Volume UP + Volume Down + Power Key
  • Press Volume UP key to Recovery mode
  • select wipe data / factory reset.
  • now reboot device.
Old 04-17-2014, 10:28   #6 (permalink)
Member: 1354113
Thanks Meter: 669
Micromax Bolt A27 Hard Reset
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Fastboot Mode on screen.
  • Download Android Tool and Drivers
  • Install Drivers Manually.
  • now open tool and press "8" and hit Enter Key to wipe data / factory reset.
  • after format handset auto restart
  • hard reset done.
Old 04-20-2014, 10:59   #7 (permalink)
Member: 1807464
Thanks Meter: 35
thank's for all reply problem solve
i change touch then problem solve.........thank's all friend
Old 04-23-2014, 06:36   #8 (permalink)
Member: 1844598
chng the sensor...and remove it
Old 09-09-2014, 10:51   #9 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Can anyone post the pic of the sensor or where can we find it because i'm not getting schematics or another similar phone ......?
thanx.....!
Page generated in 0.16073 seconds with 8 queries
