03-12-2013, 13:08 | #2 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | always give full detail of your phone for batter replay. anyway: #1. If your phone make call incoming-outgoing,then try to change display. #2. If not make call only hang on white light then try with softwere(format phone using any china box tool) #3. If any other issue ,post it here |
03-12-2013, 14:46 | #5 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | now its time to do hardwere : open phone, #1. check if there any liqed damage.if it clean pcb well #2. re-solder lcd (remove and then re-solder) #3. shake power ic littly when hit it(be very careful,otherwise you set goes totaly dead) post result |
