10-17-2014, 15:34 | #17 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | tnx bro this firmware work for me ....:) tnx bro this firmware work for me .... 1.First run Flash Tool exe "UpgradeDownload.exe" 2.Then select "SC6820_W13.30_T136_KEW_041_TEST_V8.0_131022.p ac" in flash tool, 3.Press and hold Volume down key & Connect the cable,installation of drivers takes place automatically. 4.Then software auto start & wait for Pass. Firmware Link Br'Gsmforce1 |
11-11-2014, 09:07 | #18 (permalink) | |||
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | Quote:
Quote: my set problum was hang on logo | |||
04-04-2015, 13:00 | #21 (permalink) |
Junior Member Join Date: Jul 2007
Member: 552967 Status: Offline Thanks Meter: 7 | its done with gpg dragon.... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM283 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ECBC Flash Size:20000000->512M Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
The Following User Says Thank You to riyas2692 For This Useful Post: |
04-04-2015, 13:01 | #22 (permalink) |
Member: 552967 Status: Offline Thanks Meter: 7 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM283 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ECBC Flash Size:20000000->512M Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
04-20-2015, 07:57 | #24 (permalink) |
Junior Member Join Date: Dec 2011 Location: Bhilwara(Rajasthan)
Member: 1704735 Status: Offline Thanks Meter: 1 | PLEASE ANYBODY HELP ME BECAUSE I WAN A FLASH FILE GIVEN BELOW PLZ SHARE FLASH FILE WITH ME- Flash Name:NAND_SamSungK9K4G16Q0M CPU Name:6820/8810 |
