spice mi-424 how to hard reset spice mi-424 how to hard reset??? |
Turn off your mobile keep press power+volume up+option button until recovery mode comes press menu button to bring utility navigate to wipe data, press option to select again navigate to erase option and press option button to confirm, it will take some time to ready the phone to use. |
spice mi-424 how to hard reset |
format with volcano 100% tested by me select boot 6820 tick format b-rate 115200 run 1000000000000% success mobile on wait 1 min your mobile is ok |
problam not solve phone return to custmer |
Hi All, Use Modified Cable For Format This SPD Handset.....:) Boot = 6820 B.Rate = 115200 Regards, |
which type off modified cable pls explain full process |
sold rx-tx .........open valcano selet 6820 cpu ,then format 100%%%%% done |
thanks bro my problem solved with volcano |
open phone solder rx tx open volcano select spd tab select boot 14 6820/8810 select type com(rx/tx) select baud rate 115200 select format and run set to factory successfully 100% bypass google acount tested by me |
use 07b jig 100% detact with volcano, no need solder tx rx |
