[SOLVED]Any software problem in LAVA E-Tab Z7H Tablet INSIDE [SOLVED] Any software problem in LAVA E-Tab Z7H Tablet If you are facing any software problem with your tablet "LAVA Z7H / Z7H+" or it hangs at boot, no need to worry, you don't have to go to the LAVA Service Center. I am here to help you. Follow the following steps to format your tablet. It will remove everything from your tablet and make it as a new tablet like brand new tablet.) Requirements- 1. SD Card (It will be formatted, Please backup your data) 2. SD Card Reader 3. Your PC 4. Your Tablet 5. Data Cable Steps- 1. Download this two zip files. Flash tool for SD card 3 link flash tool umedia tablet.zip Download flash tool umedia tablet zip https://rapidshare.com/#!download|55...D9ED1E07A81946 Image file part-1-LAVA_Z7H_S005_20120829_withoutcontent.zip.001 part-2LAVA_Z7H_S005_20120829_withoutcontent.zip.002 part-3LAVA_Z7H_S005_20120829_withoutcontent.zip.003 2. Extract the "Flash tool umedia tablet.zip". 3. Open the "PhoenixCard.exe". 4.Click on "Image File" & browse to where you have downloaded the image file "LAVA_Z7H_S005_20120829_withoutcontent.img". 5. Insert your sd card to the card reader & insert in the usb port of your PC. 6. Click on "Format to Normal", then click Burn. 7. After finished the above step completely remove the SD Card from card reader & insert it in your tablet. Make sure the tablet is off. Then power on it. OR Insert a small pin in the reset hole. 8. Now you can see a red progress bar moving. After it is completed the tablet will be switched off. 9. Now remove the SD Card and Turn on you tablet. 10. Bingo!! You got your new Tablet. source : reviewonanything Br Umesh Gaba |
How to root LAVA E-Tab Z7H Tablet 1. Download this file. MediafireRoot_with_Restore_by_Bin4ry_v3.rar 2. Extract the zip file. 3. Connect your Lava Tab and enable debugging mode from setting. 4. Click on " RunMe.bat ". Restart The tablet. 5. Bingo!! You are now rooted. Directly access the LAVA software folder-My Files br Umesh Gaba |
CWM-based Recovery for LAVA Z7H Tablet Lava E-tab Z7H has a very worst recovery system. So I am giving a new CWM based recovery mode. Advantages of recovery mode- 1. You can backup your total tablet system to your internal/external SD card. 2. If you face software related any problem again you can enter into the recovery mode & restore the tablet back to the same position earlier you are at the time of backup. Steps- 1. Download this zip file CWM_Recovery_for_SoftwinerEvb.rar https://rapidshare.com/#!download|45...CEE789FD86AB06 2. Extract the zip file. 3. Connect your lava tablet & make sure it is on. 4. If you have not installed the driver for this driver in your pc then a) Go to device manager ("Win Key + r" then type "devmgmt.msc"). b) See an yellow unknown device which driver is not installed. Click on that & click update driver. c) Then "Browse my computer for driver" & browse to your extracted zip file folder. 5. After updation of driver finished you have to click "1.##Recovery.bat" from the extracted folder. Make sure your tab is connected to pc & switched on. 6. Click 'y' in the command window & press any key to continue when prompted by command window. 7. Now your tablet will reboot into CWM-based recovery mode. You can see a HAT. 8. Bingo!! You are done in installing your new CWM recovery. Read next very Important. How to backup you full System- 1. In the recovery menu you can see many option like "reboot system now"...to "advanced", with a HAT ;-). 2. Use your volume up & down button for navigate & power button to Enter. 3. Now go to "backup and restore". 4. Now click on "backup to internal sdcard" (Recommended) or if you have an external sd card just click "backup". 5. Now sit back for 5-10 min. & let it do the whole system backup. Don't touch your tab. ;-) 6. After it says finished backup shut down your tab by long press power button. 8. Bingo!! You have backed up your Total tablet. Now Go on no need of formatting the tablet & reinstalling of all your fav. apps again & again. How to restore to your previous backup- 1. This process is little bit harashing. 2. Switch on your tab & listen to a small sound (tap) 1sec. after you switch on at the time of small android logo. 3. Press the volume up key suddenly or it will enter into the home as usual. 4. If you miss it then you have to try again the above steps again. 5.After entering into the recovery mode go to the "backup and restore" and then "recover from internal memory". 6. Bingo!! Now you are done with your restoration. Switch off & then switch on your tab. Br Umesh Gaba |
Mr. Umesh Gaba, You have copied the content from my blog. Please do give credit to the original creator of the content. This is not just simple copy and paste operation. Here is the original blog. Remove your name and give my name as credit. Or give the link of my blog. |
lava e7h tab sir,i am still in problem.i could not restart my tab because the image file is not found every time.i tried it so many times. i hope u help me soon. regards abhi |
sir i got a problem to unlock my lava e7zh tab because umedia flash tool file is damaged anyhow. u helped me last time i hope u will help me again. regards abhi1992 |
bro... how to remove patarn lock in LAVA E-Tab Z7H Tablet ? |
100 % working lava z7h tab |
lava tablet z7h+ getting error during using flash tool umedia tablet 1 Attachment(s) Quote:
pls hepl sir..................... lava tablet z7h+ pattern lock . i am doing as you mention here , but i am getting this kind of error how to slove it pls hepl me .... |
how to join 3 file Quote:
hello sir how to join 3 file can you mention step by step and can you help me in lava tablet z7h+ pattern lock |
thanks lot sir i done it ..... thanks lottttttttttttttt. |
hello your link help to much to me ..if your link i did not show it then i cant done it this tablet due to your link i success in lava z7h + thnak lottttttttt |
LAVA_Z7H_S005_20120829_withoutcontent - Download - 4shared - gaurav sharma flash with live suit pack 100% ok |
