Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Lava
Old 05-26-2013, 16:02   #1 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,008
[SOLVED]Any software problem in LAVA E-Tab Z7H Tablet INSIDE
[SOLVED] Any software problem in LAVA E-Tab Z7H Tablet
If you are facing any software problem with your tablet "LAVA Z7H / Z7H+" or it hangs at boot, no need to worry, you don't have to go to the LAVA Service Center. I am here to help you. Follow the following steps to format your tablet. It will remove everything from your tablet and make it as a new tablet like brand new tablet.)
Requirements-
1. SD Card (It will be formatted, Please backup your data)
2. SD Card Reader
3. Your PC
4. Your Tablet
5. Data Cable
Steps-
1. Download this two zip files.
Flash tool for SD card
3 link
flash tool umedia tablet.zip
Download flash tool umedia tablet zip
https://rapidshare.com/#!download|55...D9ED1E07A81946
Image file
part-1-LAVA_Z7H_S005_20120829_withoutcontent.zip.001
part-2LAVA_Z7H_S005_20120829_withoutcontent.zip.002
part-3LAVA_Z7H_S005_20120829_withoutcontent.zip.003
2. Extract the "Flash tool umedia tablet.zip".
3. Open the "PhoenixCard.exe".
4.Click on "Image File" & browse to where you have downloaded the image file "LAVA_Z7H_S005_20120829_withoutcontent.img".
5. Insert your sd card to the card reader & insert in the usb port of your PC.
6. Click on "Format to Normal", then click Burn.
7. After finished the above step completely remove the SD Card from card reader & insert it in your tablet. Make sure the tablet is off. Then power on it.
OR
Insert a small pin in the reset hole.
8. Now you can see a red progress bar moving. After it is completed the tablet will be switched off.
9. Now remove the SD Card and Turn on you tablet.
10. Bingo!! You got your new Tablet.
source : reviewonanything
Umesh Gaba
The Following User Says Thank You to Umesh_Arora For This Useful Post:
Old 05-26-2013, 16:08   #2 (permalink)
Member: 1792140
Thanks Meter: 6,008
How to root LAVA E-Tab Z7H Tablet
1. Download this file. MediafireRoot_with_Restore_by_Bin4ry_v3.rar
2. Extract the zip file.
3. Connect your Lava Tab and enable debugging mode from setting.
4. Click on " RunMe.bat ". Restart The tablet.
5. Bingo!! You are now rooted.
Directly access the LAVA software folder-My Files
br
Umesh Gaba
Old 05-26-2013, 16:15   #3 (permalink)
Member: 1792140
Thanks Meter: 6,008
CWM-based Recovery for LAVA Z7H Tablet
Lava E-tab Z7H has a very worst recovery system. So I am giving a new CWM based recovery mode.
Advantages of recovery mode-
1. You can backup your total tablet system to your internal/external SD card.
2. If you face software related any problem again you can enter into the recovery mode & restore the tablet back to the same position earlier you are at the time of backup.
Steps-
1. Download this zip file CWM_Recovery_for_SoftwinerEvb.rar
https://rapidshare.com/#!download|45...CEE789FD86AB06
3. Connect your lava tablet & make sure it is on.
4. If you have not installed the driver for this driver in your pc then
a) Go to device manager ("Win Key + r" then type "devmgmt.msc").
b) See an yellow unknown device which driver is not installed. Click on that & click update driver.
c) Then "Browse my computer for driver" & browse to your extracted zip file folder.
5. After updation of driver finished you have to click "1.##Recovery.bat" from the extracted folder. Make sure your tab is connected to pc & switched on.
6. Click 'y' in the command window & press any key to continue when prompted by command window.
7. Now your tablet will reboot into CWM-based recovery mode. You can see a HAT.
8. Bingo!! You are done in installing your new CWM recovery. Read next very Important.
How to backup you full System-
1. In the recovery menu you can see many option like "reboot system now"...to "advanced", with a HAT ;-).
2. Use your volume up & down button for navigate & power button to Enter.
3. Now go to "backup and restore".
4. Now click on "backup to internal sdcard" (Recommended) or if you have an external sd card just click "backup".
5. Now sit back for 5-10 min. & let it do the whole system backup. Don't touch your tab. ;-)
6. After it says finished backup shut down your tab by long press power button.
8. Bingo!! You have backed up your Total tablet. Now Go on no need of formatting the tablet & reinstalling of all your fav. apps again & again.
How to restore to your previous backup-
1. This process is little bit harashing.
2. Switch on your tab & listen to a small sound (tap) 1sec. after you switch on at the time of small android logo.
3. Press the volume up key suddenly or it will enter into the home as usual.
4. If you miss it then you have to try again the above steps again.
5.After entering into the recovery mode go to the "backup and restore" and then "recover from internal memory".
6. Bingo!! Now you are done with your restoration. Switch off & then switch on your tab.
Umesh Gaba
Old 05-29-2013, 13:21   #4 (permalink)
Crazy Poster
Member: 519737
Thanks Meter: 3
Requirements-
2. SD Card Reader
3. Your PC
4. Your Tablet
5. Data Cable
Steps-
3 link
Image file
OR
Umesh Gaba
hello sir, i have downloaded umedia flash tool and those three zip file, i formated the sd card with phoenixcard but when i click on img file in flash tool it doesn't show the img file because these three file not img file but zip file, please tell me how to convert those files in img..thanks in advance
Old 06-05-2013, 10:51   #5 (permalink)
Member: 1867387
Thanks Meter: 5
Requirements-
2. SD Card Reader
3. Your PC
4. Your Tablet
5. Data Cable
Steps-
3 link
Image file
OR
Umesh Gaba
Mr. Umesh Gaba, You have copied the content from my blog. Please do give credit to the original creator of the content. This is not just simple copy and paste operation. Here is the original blog. Remove your name and give my name as credit. Or give the link of my blog.
Old 06-05-2013, 10:55   #6 (permalink)
Member: 1867387
Thanks Meter: 5
Use HJSplit to join the 3 files.
Old 06-14-2013, 16:22   #7 (permalink)
Member: 1959732
Sonork: abhi1994
lava e7h tab
sir,i am still in problem.i could not restart my tab because the image file is not found every time.i tried it so many times.
i hope u help me soon.
regards
abhi
Old 08-02-2013, 13:42   #8 (permalink)
Member: 1959732
Sonork: abhi1994
sir
i got a problem to unlock my lava e7zh tab because umedia flash tool file is damaged anyhow. u helped me last time i hope u will help me again.
regards
abhi1992
Old 08-05-2013, 19:40   #9 (permalink)
guddu ahmad's Avatar
Member: 1345926
Sonork: 100.1671229
Thanks Meter: 137
bro...
how to remove patarn lock in LAVA E-Tab
Z7H Tablet ?
Old 09-20-2013, 19:45   #10 (permalink)
Member: 1146989
Thanks Meter: 6
100 % working lava z7h tab
Old 11-12-2013, 14:29   #11 (permalink)
Crazy Poster
Member: 1729347
Sonork: 100.002
Thanks Meter: 5
lava tablet z7h+ getting error during using flash tool umedia tablet
Requirements-
2. SD Card Reader
3. Your PC
4. Your Tablet
5. Data Cable
Steps-
3 link
Image file
OR
Umesh Gaba
pls hepl sir.....................
lava tablet z7h+ pattern lock .
i am doing as you mention here , but i am getting this kind of error how to slove it pls hepl me ....
Old 11-12-2013, 14:38   #12 (permalink)
Crazy Poster
Member: 1729347
Sonork: 100.002
Thanks Meter: 5
how to join 3 file
hello sir
how to join 3 file can you mention step by step
and can you help me in lava tablet z7h+ pattern lock
Old 11-12-2013, 15:38   #13 (permalink)
Crazy Poster
Member: 1729347
Sonork: 100.002
Thanks Meter: 5
Requirements-
2. SD Card Reader
3. Your PC
4. Your Tablet
5. Data Cable
Steps-
3 link
Image file
OR
Umesh Gaba
thanks lot sir i done it .....
thanks lottttttttttttttt.
Old 11-12-2013, 15:40   #14 (permalink)
Crazy Poster
Member: 1729347
Sonork: 100.002
Thanks Meter: 5
hello
your link help to much to me ..if your link i did not show it then i cant done it this tablet
due to your link i success in lava z7h +
thnak lottttttttt
Old 12-09-2013, 08:20   #15 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 179
LAVA_Z7H_S005_20120829_withoutcontent - Download - 4shared - gaurav sharma
flash with live suit pack 100% ok
Page generated in 0.47651 seconds with 8 queries
