Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Lava
Old 06-06-2014, 14:26   #16 (permalink)
Member: 723248
Thanks Meter: 7
I have same problem in irish 352e
Old 06-07-2014, 10:37   #17 (permalink)
Member: 723248
Thanks Meter: 7
lava iris 352e w4213 flash file need
if u have plz send me link
Old 06-16-2014, 02:10   #18 (permalink)
Member: 2196395
lava iris 352e flash file need urgent
Old 06-18-2014, 05:42   #19 (permalink)
Crazy Poster
Member: 910026
Sonork: 159b11a2cf19c2e7a38e9ec3c
Thanks Meter: 4
Exclamation pls... halp me
Lava iris 352e flash file needed
Old 06-23-2014, 13:18   #20 (permalink)
Member: 2134343
Sonork: SK_ENERPRISES
Thanks Meter: 2
bro it's Iris349plus
need Lava iris 352e
Old 06-24-2014, 21:13   #21 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Iris 352e added on the support
Welcome to the ./downloads/Lava/Iris352e/ folder of GsmHosting support area
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 08-21-2014, 09:43   #22 (permalink)
Member: 2212919
Hi friends ...............
Pls help i want 352e w4213 flash file it cant be format
i also try read n write but not solved
pls pls pls help
Old 08-21-2014, 12:10   #23 (permalink)
Member: 2088075
Thanks Meter: 48
i have service center lava
Old 08-21-2014, 12:16   #24 (permalink)
Member: 2088075
Thanks Meter: 48
tell me your prob with detail or which model lava
Old 09-12-2014, 12:02   #25 (permalink)
NOKIA EXPERT's Avatar
Member: 2227489
Thanks Meter: 190
Arrow Lava iris 352e flashing
LAVA IRIS 352E FLASHING 1000% WORKING ME
xxxxxx this link been removed cos not been giving credits to the actual file owner xxxxxxxxxxxx
(OR)
DOWNLOAD FLASHING TOOL + FIRMWARE
HOW TO SELECT FIRMWARE HERE
DRIVER INSTALLED METHOD
PRESS VOL DOWN KEY (WITHOUT BATTERY}
CONNECT USB CABLE PC TO PHONE
ANY PROBLEM PM (OR) CONTACT ME
BR ,
NOKIA EXPERT .
Old 09-12-2014, 12:06   #26 (permalink)
Member: 2227489
Thanks Meter: 190
Arrow [TUT]MTK Android (Sp flash tool ) tutorial
What's needed:
  • USB data cable
  • MediaTek USB VCOM drivers
  • SP Flash Tool ( Latest version MTK Flash Tool v. 5.1343.01 (18.10.2013))
  • First of all, make sure that you have MediaTek DA USB VCOM drivers installed.
[IMG]http://3.bp.********.com/-1Gxo90bRgIs/T6oifHh6VRI/AAAAAAAABoQ/sXGBr8ZYWNg/s640/drivers.png[/IMG]
Flashing the whole ROM
  • First of all open SP Flash Tool, then click Scatter-loading button to load the correct scatter file
    (MT6575_Android_scatter_emmc.txt or MT6577_Android_scatter_emmc.txt, depending on which phone you have) for your device and ignore any message that may appear.
[IMG]http://3.bp.********.com/-RrYRRBm9s1o/T6pekhu6ReI/AAAAAAAABoc/GJXCY5wRMaQ/s640/sp0.png[/IMG]
  • Turn off your phone, remove the battery and replace it after some seconds (and don't turn on the phone).
  • Press F9 (or hit Download button) and connect your phone into the computer via USB data cable.
    The process will start and a red progress bar will appear.
[IMG]http://1.bp.********.com/-RrASSAGXEGQ/T6perIshToI/AAAAAAAABok/fK97aDwCMFU/s640/sp1.png[/IMG]
[IMG]http://1.bp.********.com/-Svb47VuzFUU/T6pesiuFI4I/AAAAAAAABow/pB9El1k6X-I/s640/sp3.png[/IMG]
  • After the red progress bar is complete, there will appear a purple progress bar.
[IMG]http://3.bp.********.com/-VIozjRN_Kw8/T6petC8e9yI/AAAAAAAABo4/5koWOVnIkWk/s640/sp4.png[/IMG]
  • Right after the purple progress bar is complete, a message will appear underneath it:
    Please insert USB cable in x seconds” and then the download will start right away (you will see the yellow progress bar filling up).
[IMG]http://1.bp.********.com/-AVRfz4ExeFU/T6pet9GOFWI/AAAAAAAABpA/owXnn9uTrUs/s640/sp5.png[/IMG]
  • When the yellow bar is complete, you'll get a popup with a green circle and Download OK message,
    which means that the process has been successfully terminated.
[IMG]http://4.bp.********.com/-IvFvMBgpN3E/T6peuktNpCI/AAAAAAAABpI/bQNPEVJ6FoA/s640/sp6.png[/IMG]
  • You can now safely disconnect your phone and turn it on. The process ends here.
Flashing only part of the ROM
  • In case you want to flash just one part of the ROM, that is also possible. In the shown example, only recovery image will be flashed.
    Deselect all parts except the one(s) you want to flash and then press F9 (or hit Download button).
[IMG]http://3.bp.********.com/-vZsQrYyNFlA/T6pevV8ptjI/AAAAAAAABpU/HGjxFwDowL4/s640/sp7.png[/IMG]
  • The tool will immediately show a warning because not all parts are selected, but you should continue anyway. Safely press Yes to continue.
[IMG]http://4.bp.********.com/-tda8yHWu76Y/T6pexQF9pUI/AAAAAAAABpc/LC8E6ZAJlvQ/s640/sp8.png[/IMG]
  • The download of the chosen partition image will start and after the yellow bar is complete, the popup with the green circle should appear.
[IMG]http://1.bp.********.com/-PCFU9ORmLEI/T6peyG1GoyI/AAAAAAAABpg/6v774s9ZAA4/s640/sp9.png[/IMG]
[IMG]http://3.bp.********.com/-CkVJDGOrIr8/T6per4bSQCI/AAAAAAAABoo/KsHZ1_Ywq-o/s640/sp10.png[/IMG]
  • Please note that, even though it isn't mandatory to select it on the list of images to flash,
    preloader file must be present in the same folder as the other partition(s) that you want to flash, or else phone will not be able to enter into download mode.
Old 03-16-2015, 16:13   #27 (permalink)
Member: 1963898
Thanks Meter: 52
how to flash lava iris 352e with sp flash tool.....I have tried but not success
Old 03-29-2015, 12:19   #28 (permalink)
Hatimhunk5's Avatar
Member: 2117717
Sonork: 100.1663585
Thanks Meter: 28
Lava Iris 352e Hang On Logo Not Solve Flash With Tool Or Miracle Box
Lava Iris 352e Hang On Logo Problem Not Solve Flash With Tool Or Miracle Box
Need Working Firmware Help Anyone
Flash With SP Tool Ok But Problem Not Solve
Flash With Miracle Box But Problem Not Solve
Old 03-29-2015, 12:41   #29 (permalink)
Hatimhunk5's Avatar
Member: 2117717
Sonork: 100.1663585
Thanks Meter: 28
Bro, Download This SP Tool And Proper MT65xx Usb Driver When Ask For Driver Give This Driver.....
1. Open Tool
2. Select Scatter File In Lava iris352e Firmware Path
3. Click Download
4.If ask Driver Give Them
5.After giving Driver Connect Without Battery For Fast Flash And Connect USB Again
Download Here:
Old 04-21-2015, 17:08   #30 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
lava 352e flash file is here
Welcome to the ./downloads/Lava/Iris352e/Firmware Versions/S010_17.09.2013/ folder of GsmHosting support area
Page generated in 0.25541 seconds with 8 queries
