11-23-2016, 08:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: chittagong,bangladeh
Member: 1260023 Status: Offline Sonork: 100.1614097 Thanks Meter: 91 | Lava iris 870 firmware hare file info Brand : Lava ProdName : iris 870 ProdModel : iris 870 Device : iris870 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 file name : MT6735__Lava__iris_870__iris870__6.0__alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 download link must beckup before flash br sajaldip |
The Following 10 Users Say Thank You to sajaldip For This Useful Post: |
12-20-2016, 15:30 | #2 (permalink) | |
Freak Poster Join Date: Jun 2016 Location: gods own country
Member: 2587375 Status: Offline Sonork: 100.1673985 Thanks Meter: 74 | Quote:
log here Downloading Boot8 ... EMMC Size: 0x03A3E00000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Reading infr(EMMC)... WIFI MAC:AC562CF3A13D BT_ADDR:AC562CF38DB5 IMEI1:358461075415689 IMEI2:358461075415697 id:LAVA_iris870_INT_S108_20160606 version:6.0 model:iris 870 brand:Lava manufacturer:LAVA PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 LK BaseAddr:0x1C80000 Size:0x80000 PARA BaseAddr:0x1D00000 Size:0x80000 BOOT BaseAddr:0x1D80000 Size:0x1000000 RECOVERY BaseAddr:0x2D80000 Size:0x1000000 LOGO BaseAddr:0x3D80000 Size:0x800000 EXPDB BaseAddr:0x4580000 Size:0xA00000 SECCFG BaseAddr:0x4F80000 Size:0x80000 OEMKEYSTORE BaseAddr:0x5000000 Size:0x200000 SECRO BaseAddr:0x5200000 Size:0x600000 KEYSTORE BaseAddr:0x5800000 Size:0x800000 TEE1 BaseAddr:0x6000000 Size:0x500000 TEE2 BaseAddr:0x6500000 Size:0x500000 NVDATA BaseAddr:0x6A00000 Size:0x2000000 METADATA BaseAddr:0x8A00000 Size:0x2600000 SYSTEM BaseAddr:0xB000000 Size:0xE0000000 CACHE BaseAddr:0xEB000000 Size:0x19000000 USERDATA BaseAddr:0x104000000 Size:0x29ED80000 FLASHINFO BaseAddr:0x3A2D80000 Size:0x1000000 | |
The Following 2 Users Say Thank You to sager 22 For This Useful Post: |
12-20-2016, 15:34 | #3 (permalink) |
Member: 2587375 Status: Offline Sonork: 100.1673985 Thanks Meter: 74 | need firmware LAVA IRIS 870 i need LAVA IRIS 870 working flash file .pls help its urgent log here CPU: MT6735 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x03A3E00000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Reading infr(EMMC)... WIFI MAC:AC562CF3A13D BT_ADDR:AC562CF38DB5 IMEI1:358461075415689 IMEI2:358461075415697 id:LAVA_iris870_INT_S108_20160606 version:6.0 model:iris 870 brand:Lava manufacturer:LAVA PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 LK BaseAddr:0x1C80000 Size:0x80000 PARA BaseAddr:0x1D00000 Size:0x80000 BOOT BaseAddr:0x1D80000 Size:0x1000000 RECOVERY BaseAddr:0x2D80000 Size:0x1000000 LOGO BaseAddr:0x3D80000 Size:0x800000 EXPDB BaseAddr:0x4580000 Size:0xA00000 SECCFG BaseAddr:0x4F80000 Size:0x80000 OEMKEYSTORE BaseAddr:0x5000000 Size:0x200000 SECRO BaseAddr:0x5200000 Size:0x600000 KEYSTORE BaseAddr:0x5800000 Size:0x800000 TEE1 BaseAddr:0x6000000 Size:0x500000 TEE2 BaseAddr:0x6500000 Size:0x500000 NVDATA BaseAddr:0x6A00000 Size:0x2000000 METADATA BaseAddr:0x8A00000 Size:0x2600000 SYSTEM BaseAddr:0xB000000 Size:0xE0000000 CACHE BaseAddr:0xEB000000 Size:0x19000000 USERDATA BaseAddr:0x104000000 Size:0x29ED80000 FLASHINFO BaseAddr:0x3A2D80000 Size:0x1000000 >>D |
01-03-2018, 17:15 | #4 (permalink) |
Freak Poster Join Date: Dec 2015 Location: pakistan
Member: 2503555 Status: Offline Thanks Meter: 90 | thank you Scatter Load Ok , BaseBand : MT6737 , Project : lava35p_sp501_int , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lava Device Model : iris870 Device CPU : MT6735 Device IntName : iris 870 Device Version : 6.0 Device Compile : 20-Aug-16 9:36:55 AM Device Project : alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 Device ExtInfo : iris 870 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238D524004277B6DBCE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D420024D5CEDB2377 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x3ADB68A3993462EAC0C7EA2B41FFABD2 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : lava35p_sp501_int , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3976 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lava35p_sp501_int.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:10:34 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:52 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:12:44 Reconnect Power/Cable! |
01-10-2018, 10:22 | #5 (permalink) |
Junior Member Join Date: Jan 2016 Location: pakistan
Member: 2509080 Status: Offline Thanks Meter: 24 | Thanks brother ur file working fine set flashed with cm2 logo hang problem solved Lava iris 870 firmware hare Lava iris 870 wanted firmware download file info Brand : Lava ProdName : iris 870 ProdModel : iris 870 Device : iris870 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 file name : MT6735__Lava__iris_870__iris870__6.0__alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 download link must beckup before flash br sajaldip |
01-11-2018, 06:07 | #6 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 411034 Status: Offline Thanks Meter: 26 | Quote:
01-11-2018, 11:22 | #7 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2632191 Status: Offline Thanks Meter: 10 | [Solved] Just open Scatter file using Notepad or Notepad++ and rename it to MT6737M to MT6735M now flash using spflash tool or any alternative Tools 100000% Working. |
The Following 2 Users Say Thank You to somumaradi For This Useful Post: |
01-11-2018, 11:36 | #8 (permalink) | |
Member: 2632191 Status: Offline Thanks Meter: 10 | Issue Solved Quote:
- general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT6737M project: lava35p_sp501_int storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 After: - general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT6735M project: lava35p_sp501_int storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 Hit Thanks If it Helps | |
The Following 4 Users Say Thank You to somumaradi For This Useful Post: |
01-20-2018, 13:05 | #9 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, Does This Model Available In Bangladesh Only? Because This Model Didn't Launch In India, If Launched In Bangladesh Only So I Want Modify Thread Title As [Bangladesh Region] Or Like That. Lava Is In Many Countries Like Thailand, Nepal, Bangladesh, Sri Lanka, Indonesia, Mexico, Middle East, Pakistan, And Russia, So Region Is Very Important Now. What's Your Opinion? Last edited by MyGSM World; 01-20-2018 at 13:14. |
05-29-2018, 12:54 | #12 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: MALDIVES
Member: 1324837 Status: Offline Sonork: jisankhan Thanks Meter: 58 | ALHAMDULILLAH SUCCESSFULLY FLASH DONE BY CM2: Scatter Load Ok , BaseBand : MT6735 , Project : lava35p_sp501_int , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lava Device Model : iris870 Device CPU : MT6735 Device IntName : iris 870 Device Version : 6.0 Device Compile : 23-Sep-16 4:58:00 AM Device Project : alps-mp-m0.mp1-V2.39.1_lava6735m.65u.m_P6 Device ExtInfo : iris 870 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238F80400423730C2C8 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D420004F8C8C28337 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x662013CD06612EA7BE9F3B5360053404 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : lava35p_sp501_int , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4191 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000003A1100000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lava35p_sp501_int.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:10:52 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:14 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:11:38 Reconnect Power/Cable! |
