Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-02-2007, 07:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: in
Member: 524817 Status: Offline Thanks Meter: 206 | db2020 unlock problem in se tool SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701991186 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing DB2020 security... server step1 error:10054 unlock failed, that is fatal Elapsed:16 secs. help me plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz |
07-02-2007, 08:22 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | some time its coz of ur internet speed is too low cant access setool server thats why first take info about ur credits if its alright then must be wrong with some communication setool server isnt found at a moment here check first |
07-02-2007, 08:26 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: WITH SOME SELFISH PEOPLE
Member: 294880 Status: Offline Sonork: 100.1587133 Thanks Meter: 132 | error 10054 has 2 causes: first: 1. accounts can be used only on single machine 2. if account is used on another machine, time on both machine must be same. (small FORWARD time difference is allowed) 3. because of that if you will use account on more that one machine with different time, you will get error:10054 WHEN DOING OPERATION, LOG INFO WILL BE DISPLAYED OK. 4. LOGS ARE NOT DECREASED IN THAT CASE. solution: if you meet with following problem, adjust time slightly forward (by 1 min) until it start to work. AND NEVER USE ACCOUNT ON SEVERAL PCs. second: connection was reset by somebody "on-the-way" (hub,switch,etc) LOG ARE DECREASED when such thing happens. WE ARE NOT RESPONSIBLE FOR THAT PROBLEMS AND WILL NOT RETURN LOG. that is all about error: 10054, i will never answer anything more about it. |
problem in se tool box | safayat | SETool2 | 4 | 02-25-2009 19:20 |
Unlock DB2020 cid49-51 FREE in se tool | manekmobile07 | Sony Ericsson | 1 | 12-03-2007 13:03 |
db2020 unlock problem in se tool | doller | Sony Ericsson | 9 | 07-16-2007 18:37 |
In stock - DB2020 Simlock Logs for SE Tool | techgsm | Main Sales Section | 0 | 02-28-2007 13:09 |
New 3G lg`s unlock in SE Tool | .::Indian::. | Redbox | 5 | 03-18-2005 12:47 |
