Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 07-07-2007, 07:31   #1 (permalink)
    doller's Avatar
    Member: 524817
    Thanks Meter: 206
    db2020 unlock problem in se tool
    sony erricson k800i unlock in se tool error "server not found"in baypass security and "that is fatal" help me for unlock thanx
    Old 07-07-2007, 07:38   #2 (permalink)
    Member: 305311
    Thanks Meter: 227
    do you have logs cridet?????????????
    Old 07-07-2007, 07:40   #3 (permalink)
    yousaf22us's Avatar
    Member: 113943
    Thanks Meter: 73
    did u get info about ur credits after giving ur account detail ???????? post log here about ur problem
    Old 07-07-2007, 07:47   #4 (permalink)
    doller's Avatar
    Member: 524817
    Thanks Meter: 206
    i have 28 log availeble server error "server not found"
    Old 07-07-2007, 07:49   #5 (permalink)
    Member: 322417
    Thanks Meter: 940
    check ip adress.....................
    Old 07-07-2007, 07:52   #6 (permalink)
    doller's Avatar
    Member: 524817
    Thanks Meter: 206
    i p adress save by me and user pass and credit chek it and chang pc but same problem some person says it is internet problem so i change but same problem
    Old 07-07-2007, 08:09   #7 (permalink)
    adnanali's Avatar
    Member: 207308
    Thanks Meter: 471
    try with a new / another pc will be ok
    Old 07-07-2007, 08:09   #8 (permalink)
    Member: 193003
    Thanks Meter: 46
    before to go unlock ..procedure verify your user/password..and the IP that you will use
    go to -INFO- option
    if evrey think it s ok..server will answer
    if it s not ok you can t unlock DB2020 device with seetool..
    dont forget to read user manuel of setool
    thanks
    Old 07-07-2007, 16:17   #9 (permalink)
    GSM MIND's Avatar
    Member: 20645
    Sonork: 100.1579175
    Thanks Meter: 635
    YES CHECK SERVER AVILABLITY AND ALSO CHECK CABLE PORT MUST BE SET ON 60 TO 59
    REGARDS
    GSM MIND
    Old 07-16-2007, 18:37   #10 (permalink)
    rirou's Avatar
    Member: 85312
    Sonork: 1576920
    Thanks Meter: 35
    for golden gsm
    u don't have logs ? i bye u mister silver gsm
    problem in se tool box safayat SETool2 4 02-25-2009 19:20
    Unlock DB2020 cid49-51 FREE in se tool manekmobile07 Sony Ericsson 1 12-03-2007 13:03
    db2020 unlock problem in se tool doller Sony Ericsson 2 07-02-2007 08:26
    In stock - DB2020 Simlock Logs for SE Tool techgsm Main Sales Section 0 02-28-2007 13:09
    New 3G lg`s unlock in SE Tool .::Indian::. Redbox 5 03-18-2005 12:47
    Page generated in 0.25337 seconds with 9 queries
