Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-26-2010, 12:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: tangub
Member: 823842 Status: Offline Thanks Meter: 33 | G900 flash file badly needed.. |
06-27-2010, 09:51 | #3 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | sir i try to flash your flash file but the problem still remain. what is the correct procedure in order to revive this phone.. i try to recovery and write erom but nothing happen problem remain white screen hang.. |
06-27-2010, 11:16 | #4 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | i finish to flash g900 but the problem still hang-up, white screen display here is the logs: SIGNED MODE (USING SERVER) CFG:100100000000 writing "D:\se tool file\SE Flash Files\G900\G900_MR2_ARABIC1__R9N002_R1F_R6K842_R6K 836_.zip" Processing package D:\se tool file\SE Flash Files\G900\G900_MR2_ARABIC1__R9N002_R1F_R6K842_R6K 836_.zip detected MASTER on COM27, SLAVE on COM28 PDA EROM VERSION: 1202-0238 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM27, SLAVE on COM28 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:115200 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602341784 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 2010 Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R6G804_CAH1621133_Settings_TY_LockRemoved.gdfs Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 PROCESSING: R6K842_CAH1621133_PUQData_TY_Arabic1.gdfs Writing GDFS var 0002/079E/0053 Elapsed: 1048 secs. |
The Following User Says Thank You to jecams For This Useful Post: |
06-27-2010, 12:49 | #5 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
this is l c d probem... u change lcd... i think pb solved thx..... | |
06-28-2010, 12:15 | #6 (permalink) |
Member: 823842 Status: Offline Thanks Meter: 33 | sir i think lcd is good because when i press power key the phone will affair white screen,if i press c button many times the display affair but only select language and hang.. any suggestion to revive this phone... |
09-07-2010, 14:03 | #9 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1105586 Status: Offline Thanks Meter: 112 | I have same Problem with G900 After Flashing hang select Language CFG:100010000000 writing "D:\SETOOL\G900_MR2_VIETNAMESE__R9N002_R1F_R6K842_ R6K836_.zip" Processing package D:\SETOOL\G900_MR2_VIETNAMESE__R9N002_R1F_R6K842_R 6K836_.zip DETECTED PORTS [MASTER COM5,SLAVE COM6] PDA EROM VERSION: 1202-0238 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! DETECTED PORTS [MASTER COM5,SLAVE COM6] NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:460800 OTP LOCKED:1 CID:52 PAF:1 IMEI:35388602164269 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 2010 Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R6G804_CAH1621133_Settings_TY_LockRemoved.gdfs Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 PROCESSING: R6K842_CAH1621133_PUQData_TY_Vietnamese.gdfs Writing GDFS var 0002/079E/0053 packet not acknowledged (01) csloader refused shutdown, that is minor error. Elapsed: 547 secs. What is it mean???????? Hardware or Firmware |
09-10-2010, 13:16 | #10 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: philippines
Member: 448980 Status: Offline Thanks Meter: 136 | Quote:
The Following User Says Thank You to ps_tech For This Useful Post: |
10-06-2010, 17:40 | #12 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1337202 Status: Offline Thanks Meter: 3 | RUNNING v0.915062/UNI CARD SERIAL USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100100000000 writing "D:\SE-setool3\Symbian\G_900\G900_MR2_ARABIC3__R9N002_R1F _R6K842_R6K836_.zip" Processing package D:\SE-setool3\Symbian\G_900\G900_MR2_ARABIC3__R9N002_R1F _R6K842_R6K836_.zip detected MASTER on COM16, SLAVE on COM57 PDA EROM VERSION: 1202-0238 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM16, SLAVE on COM57 ples help me |
10-06-2010, 20:50 | #13 (permalink) | |
10-07-2010, 12:18 | #14 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R6G804_CAH1621133_Settings_TY_LockRemoved.gdfs Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 PROCESSING: R6K842_CAH1621133_PUQData_TY_Arabic1.gdfs Writing GDFS var 0002/079E/0053 packet not acknowledged (01) csloader refused shutdown, that is minor error. Elapsed: 1545 secs. same problem......to me plz help |
10-17-2010, 03:13 | #15 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1254663 Status: Offline Thanks Meter: 0 | Hi All.... I have same problem, make me confuse... SE G900 is working before, I do flash by Stool to change laguage but after flashing I got the problem SE G900 stoped on "selection language" page after flashing by Setool was solved???? What solution? Whould you pls share ...... |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
