Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 10-07-2003, 12:52   #1 (permalink)
    Member: 7444
    Sonork: 100.99999
    Question GDFS IMEI: FFFFFF-FF-FFFFFF-F , Help!!!!!!
    i have a T200 4 Locks closed,
    Tried SE-fighter (Make sucurity zone,upload gdfs,direct unlock,unterminate,calc crc,flash avr) and DIV 8.2 original , no one can repair my phone !
    Any one know how to repair this crap ?
    Here is result with SE-Fighter:
    **************SE-Fighter Attach to phone**************
    Fighter ready!
    Connecting via SE Fighter USB Cable...
    Activating phone...
    Bypassing authority check...
    Time spent entering bootstrap: 27s
    Initializing phone hardware...
    Phone hardware initialized OK
    OTP IMEI: 350404-45-346420-8
    ***************SE-Fighter Analyze GDFS***************
    Uploading GDFS applet...
    Baudrate = 921600Bd
    Waiting for GDFS applet to start...
    Checking GDFS status...
    ONE OR MORE GDFS VARIABLES HAVE BEEN DAMAGED.
    Phone has not been damaged by Cooler.
    Phone has not been damaged by Total Tool.
    Phone has not been locked by Terminator.
    Old 10-07-2003, 12:57   #2 (permalink)
    Member: 21978
    Sonork: sonork : 100.39764
    Use div 82
    Flash phone with normal flash file
    Upload gdfs in avr format
    Rebuild SParea using otp imei
    Worked for me
    Old 10-07-2003, 13:02   #3 (permalink)
    Member: 7444
    Sonork: 100.99999
    Already done,
    still same
    Old 10-07-2003, 14:09   #4 (permalink)
    Moderator
    Syed's Avatar
    Member: 19979
    1) flash Full GDFS in AVR format
    2) flash phones with normal files
    3) Remake CRC
    4) Manually change IMEI (dont use rebuild IMEI using OTP)
    Phone OK....
    tested on 3 phones using DIV 8.2_all Cracked by Laser
    WBR
    Syed
    Old 10-07-2003, 23:07   #5 (permalink)
    Member: 18234
    Change imei the best regals very well work.
    Old 10-08-2003, 07:43   #6 (permalink)
    Member: 7444
    Sonork: 100.99999
    3) Remake CRC
    Phone OK....
    WBR
    Syed
    I don't use cracked stuff, im using original div82 , and already tried this solution , still same !
    I think phone is HW Damaged , any other idea?
    Old 10-08-2003, 08:31   #7 (permalink)
    zulea's Avatar
    Member: 5325
    After write GDFS in AVR format (*.SBN file, not *.GDF file), what's the phone GDFS IMEI? Still FFFFFF.... ?
    Check this with *#06# or read with SE-Fighter (DIV 8.2 report only OTP IMEI).
    Regards,
    Zulea
    Old 10-08-2003, 13:10   #8 (permalink)
    Member: 22458
    use a clean full gdfs and try to change imei to the original one and do that whith div8.2 whith the terminator dongle.
    Old 10-08-2003, 20:20   #9 (permalink)
    Member: 7444
    Sonork: 100.99999
    Regards,
    Zulea
    -By DIV, Writed GDFS in SBN format , phone can be powered on , but still 4 locks closed & IMEI is 099999-00-123456-0 when i press *#06# , and when i read by Fighter, FFFFFF...
    -By Fighter, After write GDFS, phone can't powered on!
    Old 10-08-2003, 21:13   #10 (permalink)
    legija
    Guest
    Posts: n/a
    Member:
    So, you can only use SATURN IV now.
    Sory, i couldn't resist
    Sure you have HW problem. Becouse DIV8.2 work 100% (even if it's cracked), so, you should replace flash chip if possible. I think there is damaged area in it.
    Old 10-09-2003, 16:01   #11 (permalink)
    Member: 7444
    Sonork: 100.99999
    @legija
    Thanx mate..
    Old 10-10-2003, 06:52   #12 (permalink)
    zulea's Avatar
    Member: 5325
    After write GDFS in SBN format, IMEI stored in GDFS shoud be a valid one (e.g. 3512...... - the one of the phone from what was readed this GDFS SBN file), and not FFFFFF..... The 4 locks will be closed, because the CRC's need to be recalculated.
    So, sure you have an bad soldered flash chip (some high address line) or worst, a damaged flash chip. Try to resolder the chip (just small hot using an air or IR solder station).
    Regards,
    Zulea
    Old 10-10-2003, 07:50   #13 (permalink)
    mr_x4you's Avatar
    Member: 4989
    @VsH-GsM Are you sure this is not an empty board ? Did you try to treat it as an empty one ?
    Old 10-10-2003, 10:56   #14 (permalink)
    zulea's Avatar
    Member: 5325
    His phone have:
    Sure is NOT an empty board!!
    All empty board T200 have OTP IMEI FFFFFFF.....
    Refards,
    Zulea
    Old 10-10-2003, 22:25   #15 (permalink)
    legija
    Guest
    Posts: n/a
    Member:
    @Zulea
    How come DIV writes ARM even if phone is disconnected after booting ? (Ends with error, of course )
    IR station
    Anyway, where to buy it ? (For "normal" price)
    T630 imei FFFFF-FF-FFFFFF-F f.i.t Cruiser Suite 8 08-22-2007 11:38
    i need full avr gdfs to safe my p900 , pls help. aptech_knight Cruiser Suite 0 04-28-2005 13:10
    What can I do....GDFS IMEI: FFFFFF-FF-FFFFFF-F kosmonaft Cruiser Suite 9 03-26-2004 20:55
    T68m gdfs imei FFFFFF-FF-FFFFFF. Help! The Racer Cruiser Suite 11 01-14-2004 06:32
    IMEI FFFFFF-FF-FFFFFF cannot be repaired with Fighter. Phantom Cruiser Suite 7 11-30-2003 12:45
    Page generated in 0.35859 seconds with 11 queries
