Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-02-2010, 21:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | Help! k810 detect as k700 in GDFS write E Rom(CID 52), and full flash the phone. Then i identify the phone and it show k810 in GDFS. Then I power on the phone but it blinking the white screen. After that I connect the phone to SE Tool again and identify the phone. This time it show K700 as GDFS. I tried 3 times by downgrade and write k810 GDFS, but still same. I also change the display and key pad. What is the problem.. please help...! |
07-03-2010, 06:54 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | Quote:
just re construct gdfs if u have setool or cruiser box and if u don't have both devices so contact me at [email protected] | |
07-03-2010, 07:05 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
phone has hardware problem (shortage inside) thatswhy whenever startup may corrupt the gdfs clean the board and give some heat then repair gdfs | |
07-03-2010, 09:31 | #6 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
so solution is simple: 1. flash LATEST firmware version. that is first step and you MUST do it always. 2. if phone has imei mismatch or gdfs structure damaged (gdfs open errors) - reset phone. 2.1 if gdfs okay - do not touch gdfs, just do reset operation and write erom on emptyboard tab (that will fix secunits) 2.2 if gdfs damaged - write gdfs template, then write gdfs package from working phone, then 2.1 3. try to power on phone. 4. if phone does not startup, forget about software problems and search hw problems. | |
07-03-2010, 16:41 | #7 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | Thanks all... of U..! OK I tried it with software in many ways but no luck. Then I think It may be a hardware faulty. OK then can anyone guide me, what may i check on hardware.( I already tall that i change display and key pad) I already checked voltages(vcore18, vdig etc.. )and no problem found. 1. Is this can be a chip level damage?(if yes what is the responsible chips on priority ) If anyone have this kind of hardware faulty please share how u solve it. Thank u all very much again.. |
07-03-2010, 21:30 | #8 (permalink) | |
now you can flash se tool new firmware thx.... | |
07-10-2010, 04:00 | #10 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Lamka, Manipur, India
Member: 1241659 Status: Offline Thanks Meter: 165 | yeah, this is not a software issue, probably it's hardware fault. Here's also another information : http://forum.gsmhosting.com/vbb/f261...6/#post6054604 |
