Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
11-02-2005, 12:30 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 194920 Status: Offline Thanks Meter: 0 | help needed for P910i for ttm5 Iam trying to open a AutoRun.exe file for ttm5 from a external memory stick duo source but iam getting a message Unrecognized format? "No viewer can be found on your device to open this file"... Can any bright person can help me out ..... i would be appreciated thanks for looking.... prad. |
11-02-2005, 15:19 | #2 (permalink) |
Junior Member Join Date: Nov 2005
Member: 196267 Status: Offline Thanks Meter: 0 | i have problem with ttm5 as well.. on my p910 although i managed to get it started..when i modify the parameters and it;s time to choose a map..it says.. "no maps found".. what could be possibly wrong? the directory is d:/ ..licenses ..voices ..maps ..itn ..schemes ..tomtom ..raster ..stystem/apps/ttmobile , ttnavcontacts folders itn,schemes and raster should be empty? i tried both installig the map in a new folder within the map folder or to just place all files directly to map folder but none of these ways worked out.. help please.. by the way..is there a map for greece? |
11-03-2005, 10:12 | #5 (permalink) |
Member: 196267 Status: Offline Thanks Meter: 0 | you transfer the folders that you have downloaded to your memory stick i used handy explorer and i placed folders: itn, licenses, tomtom, voices, maps, schemes, raster with all their contents directly to d:\ not at any subfolder..just straight away to d:\ at the same directory as you ll notice there is already a folder system.. you open it then open the apps folder and in there you add folders: ttmobile, ttnavcontacts with their contents.. and you have your program working! however in mine it doesn't recognise the maps so there may be some mistake in the structure of my installation.. |
11-03-2005, 12:40 | #7 (permalink) |
Member: 196267 Status: Offline Thanks Meter: 0 | it's not necessary to use handy explorer..there are other file explorers as well.. i.e sman.. give it a try at http://www.dotsis.com/vb/showthread.php?t=5287 you may find sth |
HELP!!! Need EEPROM dump for Bosch 509! | mastergsm | Various | 2 | 09-06-2001 18:07 |
Help!Need full backup for 7110 V4.94!!!!!!!! | starpho | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 05-26-2001 01:22 |
help.. need D2 flash for 5110 5.29 | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-26-2001 16:10 |
Help need full backup for 6110 5.30 | NBG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-09-2001 13:03 |
Please HELP need new flash for T10 (not 0014) | igor_m | Old Ericsson Phones & Sony Phones | 1 | 08-13-2000 04:24 |
