Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
09-26-2007, 18:21 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Age: 34
Member: 51906 Status: Offline Thanks Meter: 0 | w810i unlock "CVX not supported" i tried to unlock my phone today using semctool_v8, that comes with the usb smart on the other thread. anyway, it did a few things, it asked me to remove the cable and attach it again and then it said something like CVX unsupported, and the phone wont turn on! im kinda worried and have no idea what to do. It will read the settings of the phone but not much more is there anything i can do? im really desperate right now, i cant afford to brick my phone.... if anybody wants i will post screenshots.. thank you ever so much |
09-26-2007, 22:46 | #3 (permalink) | |
Junior Member Join Date: Aug 2007
Member: 571847 Status: Offline Thanks Meter: 2 | Quote:
1. Check that your service cable is working (drivers installed etc) 2. Flash the "Magic W810 Firmware" using XS++ (just the MAIN will do) and make sure the phone comes on as normal. 3. Run SEMCTool 8.4 and configure the port for your service cable,speed etc. 4. Take out the phone battery and connect the crusier cable. 5. Click Read All Codes + Do selected job. 6. Pop in the battery. 7. While reading codes; the computer will ask you to take out the battery etc twice. Do what it says. 8. At the point where you get the codes and the phone is safe to take out, take the phone out the crusier cable. Take out the battery and switch on the phone. ...it asks you to remove the battery and not the cable. Why don't you repeat the whole process again and follow the instructions properly. So does it still turn on? What does it do? Just blinking red, flashing white, etc... | |
09-27-2007, 09:06 | #5 (permalink) |
Member: 571847 Status: Offline Thanks Meter: 2 | Check this forum (http://forums.se-nse.net/index.php?showtopic=5381). This could explain your issue. You might need to downgrade your firmware. Supported: W810_R4CE012_CXC1250316_GENERIC_HN W810_R4CE012_CXC1250317_CHINA_HN W810_R4CE012_CXC1250318_HONG_KONG_HN W810_R4CE012_CXC1250320_VODAFONE_HN W810_R4CF002_CXC1250317_CHINA_HN W810_R4CF002_CXC1250321_ORANGE_HN W810_R4CF002_CXC1250319_TAIWAN_HN W810_R4CK003_CXC1250316_GENERIC_HN W810_R4CK003_CXC1250317_CHINA_HN W810_R4CK003_CXC1250319_TAIWAN_HN W810_R4CK003_CXC1250318_HONG_KONG_HN |
09-27-2007, 13:56 | #6 (permalink) |
Member: 51906 Status: Offline Thanks Meter: 0 | how do i go about downgrading the firmware..... just so you know the phone responds to semctool, but using anything else where it asks me to hold down C and then connect the phone, the phone isnt seen by the program. can i flash the magic firmware using semc tool, or will i need to use xs++. |
09-29-2007, 00:29 | #7 (permalink) |
Member: 51906 Status: Offline Thanks Meter: 0 | SEking looks good, it might just work, apart from the phone does not do anything with any program when asked to press C and attach cable.... im unsure how im going to fix this.. |
10-01-2007, 09:03 | #9 (permalink) |
Member: 51906 Status: Offline Thanks Meter: 0 | UPDATE: It worked! i managed to do it now, and the phone is unlocked! Case closed! p.s if anybody else wants to know how i did it i dont mind explaining - in total "n00b" terms. all of this stuff is kinda daunting at first so feel free to pm me! Thanks for all your help guys |
11-13-2007, 16:59 | #10 (permalink) |
Junior Member Join Date: Mar 2005 Age: 50
Member: 123066 Status: Offline Thanks Meter: 2 | sayeds33-PLEASE POST SOLUTION FOR OTHERS Please share your solution with the rest of us that need a solution. PM'ing isn't a proper way of sharing the solution because it doesn't share freely. You started this post and it would be appropriate to share the solution in this post. Thanks Last edited by pctech101; 11-13-2007 at 17:04. |
Default Cannot unlock se j120i "FIRMWARE VERSION NOT SUPPORTED". | svchost | SETool2 | 3 | 09-21-2011 09:31 |
"feature not supported" | green bird | Nokia Hardware & Hardware Repair | 29 | 01-17-2007 11:40 |
8310 "bzzzz" sound and "accessory not supported" | andreic | Nokia Hardware & Hardware Repair | 6 | 07-16-2006 15:42 |
k700i "this flash id not supported" | nishantha | FuriouS II | 0 | 09-28-2005 11:25 |
6230. "file format not supported"??? | brogdan | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-29-2005 12:39 |
