Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-01-2007, 04:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 299797 Status: Offline Thanks Meter: 92 | HELP Z550a DEAD WITH SETOOL Friends please help tries to unlock a Z550a with my SETOOL and I thought that she already had all the bring up to date, but it was not this way......When unlocking the cellular one you turns off and flashear is not left for that leaves me an error that EMBEDDED BOOTLOADER NOT RESPONDS says.... That I can make friends helps me..... LOG ERROR: Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35350501041022 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Abort all operations. embedded bootloader not responds ! Elapsed:1175 secs. |
05-01-2007, 06:09 | #3 (permalink) |
Crazy Poster Join Date: Feb 2006
Member: 237607 Status: Offline Thanks Meter: 1 | double check your z550a, if your phone is from fido canada, it is a cid51. Download same version firmware from setool support, do recovery, flash main and fs, complete with server support (will use one credit). By the way, if this is from fido, you can't unlock this phone with setool since this is new security. Last edited by dc_civic1129; 05-01-2007 at 06:23. |
05-01-2007, 15:38 | #4 (permalink) |
Member: 299797 Status: Offline Thanks Meter: 92 | Thank you for the answers, but friend like you can see whenever I give IDENTIFY to my setool it recognizes it to me as CID 49 RED...And already hey attempted to return to flashear everything but the problem is that damned error which doesn't allow to run the complete flash.....EMBEDDED BOOTLOADERS NOT RESPONDS.......Do I add a small info, is this telephone acquired so in colombia I don't believe that it is a CID 51 or if???.......That but I can make friends helps me..... |
06-05-2007, 00:18 | #5 (permalink) |
Junior Member Join Date: Jun 2007
Member: 522012 Status: Offline Thanks Meter: 1 | I just got my z550a unlocked at the following store on Dundas in Toronto: http://www.torontophonerepair.com/ The guy apparently had to get the VERY latest software Good luck! |
06-14-2007, 07:48 | #14 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | wag kayo maniwala dyan mayabang yan na binubugbog ng customer at kapwa technician.......technician na tinalo pa ayon binugbog......customer naman nya akala ignoranti ayun binugbog uli |
J132 dead with setool | Gr8SightMan | Infinity-Box | 3 | 12-08-2008 16:05 |
sony ericsson z520i dead with setool | fmpacific | Sony Ericsson | 4 | 05-17-2007 08:41 |
M600i Dead with SeTool and DCU-60 cable | irstu | Sony Ericsson | 1 | 01-03-2007 09:54 |
need help for 8330 with setool | vangev | LG | 5 | 06-22-2006 09:27 |
z1010 dead with setool | mzbrd | SETool2 | 0 | 07-28-2005 10:50 |
